External check windows
Re: External check windows
If it's not working, then allow arguments = 1 is in the wrong place. The document outlines specifically where it needs to be under which pertains directly to NRPE.
I would make sure it's there, and then restart the NSClient++ service. After doing so, attempt to run the check, and if it fails again please post your nsclient configuration file.
hello, finally works, thank you very much
at the end the problem is what we were saying, the nsclient.ini file must be very well ordered
so it did not work
and so all ok
thank you very much for the help, you can close the thread
so it did not work
[/ Settings / NRPE / server]
NRPEServer = 1
allow arguments = 1
nasty_meta allow chars = 1
use SSL = 1Code: Select all
NRPEServer = 1
allow arguments = 1
use SSL = 1
Reason: Please use [code][/code] tags around long output
Fixed external plugin check_tcp
But now I work the basic plugins check_nt
I get the following error
nSorolla address and connect to port 12489: Connection refused
For example: Server Uptime
CRITICAL 09-30-2016 9:13:26 0d 0h 8m 43s 3/3 nSorolla address and connect to port 12489: Connection refused
This is my configuration file nsclient.ini
# If you want to fill this file avalible With all options run the following command:
# Nscp settings --add-defaults --generate --load-all
# If you want to activate a module and bring all its options in use:
# Nscp settings --activate-module <module name> --add-defaults
; undocumented section
[/ Modules]
; undocumented key
CheckDisk = 1
; undocumented key
CheckEventLog = 1
; undocumented key
CheckExternalScripts = 1
; undocumented key
CheckHelpers = 1
; undocumented key
CheckNSCP = 1
; undocumented key
CheckSystem = 1
; undocumented key
CheckWMI = 1
; undocumented key
NRPEServer = 1
allow arguments = 1
; undocumented key
NSClientServer = 1
[/ Settings / default]
; undocumented key
allowed hosts = 172.19.96.35
; undocumented key
password = 62pass @ T
[/ Settings / external scripts]
allow arguments = true
allow = true nasty characters
timeout = 90
[/ Settings / external scripts / wrappings]
bat SCRIPT = scripts \\%%% ARGS%
ps1 = cmd / c I miss scripts SCRIPT \\%%% ARGS%; exit ($ lastexitcode) | powershell.exe -command -
vbs = cscript.exe // T: 90 // \\ lib \\ NoLogo scripts SCRIPT wrapper.vbs%%% ARGS%
exe = cmd / c% SCRIPT%% ARGS%
[/ Settings / external scripts / wrapped scripts]
test_bat = check_ok.bat
test_ps = check_test.ps1
test_vbs = check_test.vbs
test_ping = check_ping.bat
Test_files = check_files.vbs
test_battery = check_battery.vbs
test_printers = check_printer.vbs
checkProcState alias_process = "$ ARG1 $ = started"
check_test = check_test.ps1
[/ Settings / external scripts / scripts]
check_tcp = scripts \ check_tcp.exe -H $ ARG1 $ -p $ ARG2 $ -w $ ARG3 $ -c $ ARG4 $
I would suggest including the following settings above your [settings / NRPE / server section]:
I would also verify that Windows Firewall (or other firewalls) are not blocking traffic on port 12489
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
[/settings/NSClient/server]
; ENABLE SSL ENCRYPTION - This option controls if SSL should be enabled.
use ssl = 0
; PERFORMANCE DATA - Send performance data back to Nagios (set this to 0 to remove all performance data).
performance data = 1
; PORT NUMBER - Port to use for check_nt.
port = 12489Former Nagios employee
Hello
The port 12489 is open.
If I have this configuration, the standard plugins check_nt work and check_tcp external plugin does not work, it gives this error when I run
My file nsclient
If I make changes in the nsclient tell me file, I check_tcp external plugin works but let me run the standard plugins check_nt
Run the external plugin
but the basic plugins do not work
The port 12489 if it is open
and this is the configuration in this case
But I still fail the standard plugins, external plug-in this case works for me.
Sorry for the inconvenience and thank you very much for the help, see if you can continue helping me thanks
[Root @ server1 ~] # / usr / local / nagios / libexec / -H check_nrpe check_tcp -a -c server1 server1 80100200
Exception processing request: Request Contained arguments (not currently are allowed, check the arguments allow option).Code: Select all
[/ Modules]
; undocumented key
CheckDisk = 1
; undocumented key
CheckEventLog = 1
; undocumented key
; undocumented key
CheckHelpers = 1
; undocumented key
CheckNSCP = 1
; undocumented key
CheckSystem = 1
; undocumented key
CheckWMI = 1
; undocumented key
NRPEServer = 1
; undocumented key
NSClientServer = 1
; undocumented key
; undocumented key
timeout = 90
check_ex2013 = ex2013.ps1
check_ex2013dag = cmd / c I miss scriptsCheckEX2013DAG.ps1; exit ($ lastexitcode) | powershell.exe -command -
check_tcp = scripts \ check_tcp.exe -H $ ARG1 $ -p $ ARG2 $ -w $ ARG3 $ -c $ ARG4 $Run the external plugin
/ Usr / local / nagios / libexec / H check_nrpe check_tcp -a-c server1 server1 80100200
TCP OK - 0.000 second response time on port 80 | 'time' = 0.00039sCode: Select all
NSClient ++ Version
10/06/2016 10:03:56 CRITICAL 0d 0h 0m 6s 1/3 connect to server1 address and port 12489: Connection refusedand this is the configuration in this case
[/ Modules]
; undocumented key
CheckDisk = 1
; undocumented key
CheckEventLog = 1
; undocumented key
; undocumented key
CheckHelpers = 1
; undocumented key
CheckNSCP = 1
; undocumented key
CheckSystem = 1
; undocumented key
CheckWMI = 1
; undocumented key
NRPEServer = 1
allow arguments = 1
[/ Settings / NSClient / server]
; undocumented key
NSClientServer = 1
; undocumented key
; undocumented key
timeout = 90
I've added
; ENABLE SSL encryption - SSL This option controls if Should be enabled.
use ssl = 0
; PERFORMANCE DATA - Send performance data back to Nagios (set to 0 to remove esta all performance data).
port = 12489Sorry for the inconvenience and thank you very much for the help, see if you can continue helping me thanks
In your second configuration file, move this part -
To be under this part -
NSClientServer = 1 is what controls if check_nt is on or not. Once you make this change, and restart the service, both check_nrpe with exernal arguments and check_nt should work. If not, please post your current configuration file once again.
; undocumented key
NSClientServer = 1
[/ Modules]
Yes now
NSClient Server = 1
under [/ Modules]
It works !!!
Thank you very much, and you can close the thread
NSClient Server = 1
under [/ Modules]
It works !!!
- Former Nagios Staff
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
