Long apply configurations
avandemore
Re: Long apply configurations
Post by avandemore »
No I don't need to see the full output. The behavior you're seeing is normal as stall is when the file state is used, and the burst is when Nagios starts collecting data again.
What's concerning is that you are reporting Core shows hosts/services as down during an apply config. This is expected in XI, not Core when Core is set to use retention data.
I believe you answered this already, but I would like to confirm this. When doing an Apply Config the host and service status at http://<Your Nagios install>/nagios/ shows states incorrectly?
If that is true, a remote may be needed to see more of this behavior.
Previous Nagios employee
WillemDH
Post by WillemDH »
Avandemore,
Just tested this one more time. yes, I do see incorrect states in Nagios Core when applying configuration.
I'll pm you some screenshots.
Somewhere between the incorrect status'es, I also saw these two errors during my tests:
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
avandemore
Ok, that clears things up. The items in your screen shots appear to either have been in that state for some time or are directly related to the apply config.
So this is the same behavior as the other thread. Same thing applies as there. The Apply Config process is IO bound.
Things like a Linux RAMDisk or rrdcached can help. Ultimately, the solution needs to be something which greatly increase the IOPS of Nagios and NDO related processes and doesn't bog down under memory pressure. Linux RAMDisk doesn't fulfill this need. If all else is insufficient something like this might help:
https://www.sandisk.com/business/datace ... lash/sx350
http://www.thessdreview.com/our-reviews ... 3-storage/
This is not a recommendation or endorsement of those specific products, they are simply examples of ways to get more IOPS for your system.
WillemDH
Post by WillemDH »
Sorry Avandemore but my Nagios XI server is virtual and the the disks of the datastore are already on tier 1 RAID 50 with SSD. We are not seeing any disk io related performance issues, almost no iowait and read / write time.
I'm indeed already using a ramdisk.
Except maybe for rrdcached and offloading mysql I don't see any other options to improve performance. What is the downside of rrdcached?
To be honest if you ask me, the issue of acknowledged and downtimed hosts and services popping up is a Nagios issue related to non optimal programming.
I can understand better io would lessen the time needed to apply configuration, but a longer apply configuration shouldnt mean acknowledged and downtimed hosts and services have to show up.
Nagios XI 5.8.1
BanditBBS
Post by BanditBBS »
WillemDH wrote:Sorry Avandemore but my Nagios XI server is virtual and the the disks of the datastore are already on tier 1 RAID 50 with SSD. We are not seeing any disk io related performance issues, almost no iowait and read / write time.
+1 I see exact same stuff and have same opinion as Willem!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
avandemore
WillemDH wrote:Nagios XI server is virtual
That is irrelevant
BanditBBS wrote: We are not seeing any disk io related performance issues
Let's explore this a little, see below.
WillemDH wrote:disks of the datastore are already on tier 1 RAID 50 with SSD
As already mentioned, IOPS are important here, until you can tell me what IOPS the related block device does on random read and writes we're stuck in the same place.
WillemDH wrote:What is the downside of rrdcached?
RRD files would then be processed in intervals, not FIFO as they are without rrdcached. This means there may be more latency in displaying performance data. Also the daemon will be using its own resources eg RAM, CPU, and periodically increasing disk IO. https://oss.oetiker.ch/rrdtool/doc/rrdcached.en.html
WillemDH wrote:but a longer apply configuration shouldnt mean acknowledged and downtimed hosts and services have to show up
I'll try again to rephrase this. Core doesn't have a longer apply configuration delay. XI does because it gets data from the DB. The DB is overloaded until NDO is caught up, at that point XI would be current again. This is bottlenecked by disk IO.
Right before an Apply Configuration run the following:
# iostat -xtz 1 > /tmp/io.log
After the Apply Configuration has finished kill that process, compress the file and attach or PM it me.
WillemDH
Post by WillemDH »
Here you go:
Linux 2.6.32-642.6.2.el6.x86_64 (nagiosserver) 	12/07/2016 	_x86_64_	(6 CPU)
12/07/2016 10:38:06 PM
avg-cpu:  %user   %nice %system %iowait  %steal   %idle
          12.76    0.00    3.45    1.58    0.00   82.22
Device:         rrqm/s   wrqm/s     r/s     w/s   rsec/s   wsec/s avgrq-sz avgqu-sz   await r_await w_await  svctm  %util
sda               0.31  1188.00   19.74  464.69  1134.81 13221.68    29.64     0.05    0.11    2.51    0.01   0.27  13.17
dm-0              0.00     0.00    0.06    0.07     0.45     0.60     8.00     0.00   25.76    4.86   41.54   1.09   0.01
dm-1              0.00     0.00   20.00 1652.64  1134.34 13221.08     8.58     2.42    1.40    2.58    1.39   0.08  13.17
12/07/2016 10:38:07 PM
          13.90    0.00    5.19    1.17    0.00   79.73
sda               0.00 10093.00    0.00  107.00     0.00 81600.00   762.62     1.72   16.07    0.00   16.07   0.91   9.70
dm-1              0.00     0.00    0.00 10200.00     0.00 81600.00     8.00   193.85   19.01    0.00   19.01   0.01   9.70
12/07/2016 10:38:08 PM
           6.53    0.00    3.35    0.00    0.00   90.12
sda               0.00     2.00    0.00    2.00     0.00    32.00    16.00     0.00    1.00    0.00    1.00   1.00   0.20
dm-1              0.00     0.00    0.00    4.00     0.00    32.00     8.00     0.00    1.00    0.00    1.00   0.50   0.20
12/07/2016 10:38:09 PM
          16.61    0.00    3.86    0.00    0.00   79.53
sda               0.00     8.00    0.00   24.00     0.00   256.00    10.67     0.07    2.88    0.00    2.88   0.38   0.90
dm-1              0.00     0.00    0.00   32.00     0.00   256.00     8.00     0.09    2.75    0.00    2.75   0.28   0.90
12/07/2016 10:38:10 PM
          20.53    0.00    3.84    0.00    0.00   75.63
sda               0.00     2.00    0.00    2.00     0.00    32.00    16.00     0.00    1.50    0.00    1.50   1.50   0.30
dm-1              0.00     0.00    0.00    4.00     0.00    32.00     8.00     0.01    1.50    0.00    1.50   0.75   0.30
12/07/2016 10:38:11 PM
          11.17    0.00    4.17    0.17    0.00   84.50
sda               0.00     4.00    0.00    8.00     0.00    96.00    12.00     0.02    2.25    0.00    2.25   2.00   1.60
dm-1              0.00     0.00    0.00   12.00     0.00    96.00     8.00     0.03    2.50    0.00    2.50   1.33   1.60
12/07/2016 10:38:12 PM
          18.76    0.00    4.36    0.00    0.00   76.88
sda               0.00    58.00    0.00   13.00     0.00   568.00    43.69     0.01    0.92    0.00    0.92   0.62   0.80
dm-1              0.00     0.00    0.00   71.00     0.00   568.00     8.00     0.12    1.69    0.00    1.69   0.11   0.80
12/07/2016 10:38:13 PM
           4.68    0.00    3.01    0.17    0.00   92.14
12/07/2016 10:38:14 PM
           8.19    0.00    2.68    0.00    0.00   89.13
sda               0.00     2.00    0.00    8.00     0.00    80.00    10.00     0.01    1.25    0.00    1.25   0.62   0.50
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.01    1.20    0.00    1.20   0.50   0.50
12/07/2016 10:38:15 PM
           7.19    0.00    3.34    0.00    0.00   89.46
sda               0.00     1.00    0.00    1.00     0.00    16.00    16.00     0.00    2.00    0.00    2.00   2.00   0.20
dm-1              0.00     0.00    0.00    2.00     0.00    16.00     8.00     0.00    2.00    0.00    2.00   1.00   0.20
12/07/2016 10:38:16 PM
          14.88    0.00    4.52    0.17    0.00   80.43
sda               0.00    25.00    0.00    9.00     0.00   272.00    30.22     0.01    0.78    0.00    0.78   0.67   0.60
dm-1              0.00     0.00    0.00   34.00     0.00   272.00     8.00     0.03    0.76    0.00    0.76   0.18   0.60
12/07/2016 10:38:17 PM
          29.08    0.00   13.45    1.51    0.00   55.97
sda               0.00 11848.00    0.00  120.00     0.00 95744.00   797.87     2.43   20.24    0.00   20.24   1.07  12.80
dm-1              0.00     0.00    0.00 11968.00     0.00 95744.00     8.00   283.62   23.70    0.00   23.70   0.01  12.80
12/07/2016 10:38:18 PM
          15.72    0.00    8.53    0.00    0.00   75.75
sda               0.00    14.00    0.00    3.00     0.00   136.00    45.33     0.01    2.00    0.00    2.00   2.00   0.60
dm-1              0.00     0.00    0.00   17.00     0.00   136.00     8.00     0.05    2.94    0.00    2.94   0.35   0.60
12/07/2016 10:38:19 PM
          26.31    0.00    6.75    0.17    0.00   66.78
sda               0.00    40.00    0.00   83.00     0.00   984.00    11.86     0.39    4.66    0.00    4.66   0.25   2.10
dm-1              0.00     0.00    0.00  123.00     0.00   984.00     8.00     0.56    4.54    0.00    4.54   0.17   2.10
12/07/2016 10:38:20 PM
          22.82    0.00    3.19    0.00    0.00   73.99
12/07/2016 10:38:21 PM
          25.75    0.00    4.52    0.00    0.00   69.73
sda               0.00     3.00    0.00    3.00     0.00    48.00    16.00     0.00    1.33    0.00    1.33   1.33   0.40
dm-1              0.00     0.00    0.00    6.00     0.00    48.00     8.00     0.01    1.33    0.00    1.33   0.67   0.40
12/07/2016 10:38:22 PM
          39.09    0.00    8.39    0.50    0.00   52.01
sda               0.00  5212.00    0.00   67.00     0.00 42232.00   630.33     1.01   15.12    0.00   15.12   1.03   6.90
dm-1              0.00     0.00    0.00 5279.00     0.00 42232.00     8.00   113.17   21.44    0.00   21.44   0.01   6.90
12/07/2016 10:38:23 PM
          25.92    0.00    4.18    0.00    0.00   69.90
sda               0.00    16.00    0.00    6.00     0.00   176.00    29.33     0.01    0.83    0.00    0.83   0.67   0.40
dm-1              0.00     0.00    0.00   22.00     0.00   176.00     8.00     0.02    0.91    0.00    0.91   0.18   0.40
12/07/2016 10:38:24 PM
          36.41    0.00    5.87    3.02    0.00   54.70
sda               0.00  5464.00    0.00 1130.00     0.00 52752.00    46.68    21.90   19.38    0.00   19.38   0.21  23.50
dm-1              0.00     0.00    0.00 6594.00     0.00 52752.00     8.00   136.69   20.73    0.00   20.73   0.04  23.50
12/07/2016 10:38:25 PM
          36.89    0.00    7.01    0.00    0.00   56.09
sda               0.00     5.00    0.00    7.00     0.00    96.00    13.71     0.01    0.71    0.00    0.71   0.71   0.50
dm-1              0.00     0.00    0.00   12.00     0.00    96.00     8.00     0.01    0.75    0.00    0.75   0.42   0.50
12/07/2016 10:38:26 PM
          33.67    0.00    4.52    0.17    0.00   61.64
12/07/2016 10:38:27 PM
          40.20    0.00   10.55    0.67    0.00   48.58
sda               0.00  7084.00    0.00   74.00     0.00 57264.00   773.84     1.30   17.57    0.00   17.57   0.93   6.90
dm-1              0.00     0.00    0.00 7158.00     0.00 57264.00     8.00   154.27   21.55    0.00   21.55   0.01   6.90
12/07/2016 10:38:28 PM
          39.93    0.00    5.37    0.17    0.00   54.53
12/07/2016 10:38:29 PM
          39.50    0.00    5.55    0.00    0.00   54.96
sda               0.00   173.00    0.00    8.00     0.00  1448.00   181.00     0.02    2.00    0.00    2.00   0.75   0.60
dm-1              0.00     0.00    0.00  181.00     0.00  1448.00     8.00     0.64    3.55    0.00    3.55   0.03   0.60
12/07/2016 10:38:30 PM
          27.35    0.00    4.70    0.00    0.00   67.95
sda               0.00     1.00    0.00    3.00     0.00    32.00    10.67     0.00    1.00    0.00    1.00   0.67   0.20
12/07/2016 10:38:31 PM
          24.66    0.00    5.87    0.00    0.00   69.46
sda               0.00    31.00    0.00    8.00     0.00   312.00    39.00     0.02    2.25    0.00    2.25   2.12   1.70
dm-1              0.00     0.00    0.00   39.00     0.00   312.00     8.00     0.14    3.72    0.00    3.72   0.44   1.70
12/07/2016 10:38:32 PM
          24.07    0.00    6.06    0.17    0.00   69.70
sda               0.00   661.00    0.00   26.00     0.00  5496.00   211.38     0.08    3.08    0.00    3.08   1.69   4.40
dm-1              0.00     0.00    0.00  687.00     0.00  5496.00     8.00     3.81    5.55    0.00    5.55   0.06   4.40
12/07/2016 10:38:33 PM
          18.29    0.00    5.37    0.34    0.00   76.01
sda               0.00 11977.00    0.00  127.00     0.00 96832.00   762.46     2.09   16.43    0.00   16.43   1.53  19.40
dm-1              0.00     0.00    0.00 12104.00     0.00 96832.00     8.00   243.75   20.14    0.00   20.14   0.02  19.40
12/07/2016 10:38:34 PM
          10.35    0.00    3.01    2.84    0.00   83.81
sda               0.00   154.00    0.00 1252.00     0.00 11184.00     8.93    26.51   20.15    0.00   20.15   0.16  20.40
dm-1              0.00     0.00    0.00 1566.00     0.00 12528.00     8.00    29.36   17.92    0.00   17.92   0.13  20.40
12/07/2016 10:38:35 PM
          39.36    0.00   10.47   23.99    0.00   26.18
sda               0.00  5664.00   59.00 9678.00   472.00 122632.00    12.64   144.11   14.79   22.42   14.75   0.10 100.00
dm-1              0.00     0.00   61.00 15348.00   488.00 122784.00     8.00   322.36   20.89   21.70   20.88   0.06 100.10
12/07/2016 10:38:36 PM
          50.93    0.00   21.25    2.87    0.00   24.96
sda               0.00   483.00  154.00 1598.00  1232.00 16816.00    10.30     8.65    5.71    1.31    6.13   0.34  59.70
dm-1              0.00     0.00  152.00 1915.00  1216.00 15320.00     8.00    10.71    5.92    1.30    6.29   0.29  59.70
12/07/2016 10:38:37 PM
          42.81    0.00   12.52    0.00    0.00   44.67
sda               0.00     2.00    0.00    2.00     0.00    32.00    16.00     0.00    1.50    0.00    1.50   1.00   0.20
dm-1              0.00     0.00    0.00    4.00     0.00    32.00     8.00     0.01    1.25    0.00    1.25   0.75   0.30
12/07/2016 10:38:38 PM
          28.48    0.00    8.38    2.68    0.00   60.47
sda               0.00 13614.00    0.00  140.00     0.00 110032.00   785.94     3.48   24.89    0.00   24.89   1.52  21.30
dm-1              0.00     0.00    0.00 13754.00     0.00 110032.00     8.00   354.86   25.80    0.00   25.80   0.02  21.30
12/07/2016 10:38:39 PM
          25.71    0.00    5.38    0.00    0.00   68.91
sda               0.00     5.00    0.00    3.00     0.00    64.00    21.33     0.01    1.00    0.00    1.00   1.67   0.50
dm-1              0.00     0.00    0.00    9.00     0.00    72.00     8.00     0.01    0.89    0.00    0.89   0.56   0.50
12/07/2016 10:38:40 PM
          21.94    0.00    5.19    1.84    0.00   71.02
sda               0.00   145.00    0.00   84.00     0.00  1832.00    21.81     0.38    4.50    0.00    4.50   1.83  15.40
dm-1              0.00     0.00    0.00  228.00     0.00  1824.00     8.00     1.29    5.65    0.00    5.65   0.68  15.40
12/07/2016 10:38:41 PM
          35.62    0.00    5.02    0.17    0.00   59.20
sda               0.00     5.00    0.00    9.00     0.00   112.00    12.44     0.01    1.11    0.00    1.11   0.44   0.40
dm-1              0.00     0.00    0.00   14.00     0.00   112.00     8.00     0.02    1.14    0.00    1.14   0.36   0.50
12/07/2016 10:38:42 PM
          29.08    0.00    7.39    0.17    0.00   63.36
sda               0.00    11.00    0.00   11.00     0.00   176.00    16.00     0.02    2.00    0.00    2.00   1.82   2.00
dm-1              0.00     0.00    0.00   22.00     0.00   176.00     8.00     0.04    1.82    0.00    1.82   0.91   2.00
12/07/2016 10:38:43 PM
          20.57    0.00    4.85    0.00    0.00   74.58
sda               0.00     3.00    0.00    3.00     0.00    48.00    16.00     0.00    0.67    0.00    0.67   0.67   0.20
dm-1              0.00     0.00    0.00    6.00     0.00    48.00     8.00     0.00    0.67    0.00    0.67   0.33   0.20
12/07/2016 10:38:44 PM
          22.82    0.00    5.37    0.00    0.00   71.81
sda               0.00     1.00    0.00    1.00     0.00    16.00    16.00     0.00    1.00    0.00    1.00   1.00   0.10
dm-1              0.00     0.00    0.00    2.00     0.00    16.00     8.00     0.00    1.00    0.00    1.00   0.50   0.10
12/07/2016 10:38:45 PM
          30.03    0.00    5.20    0.17    0.00   64.60
sda               0.00   128.00    0.00   19.00     0.00  1176.00    61.89     0.04    2.05    0.00    2.05   1.74   3.30
dm-1              0.00     0.00    0.00  147.00     0.00  1176.00     8.00     0.55    3.75    0.00    3.75   0.22   3.30
12/07/2016 10:38:46 PM
          25.92    0.00    7.53    2.17    0.00   64.38
sda               0.00  7048.00    0.00   76.00     0.00 56992.00   749.89     1.38   18.09    0.00   18.09   1.99  15.10
dm-1              0.00     0.00    0.00 7124.00     0.00 56992.00     8.00   163.96   23.01    0.00   23.01   0.02  15.10
12/07/2016 10:38:47 PM
          31.83    0.00    4.86    0.00    0.00   63.32
sda               0.00     3.00    0.00    3.00     0.00    48.00    16.00     0.00    1.00    0.00    1.00   1.00   0.30
dm-1              0.00     0.00    0.00    6.00     0.00    48.00     8.00     0.01    1.00    0.00    1.00   0.50   0.30
12/07/2016 10:38:48 PM
          36.53    0.00    5.56    0.17    0.00   57.74
sda               0.00     6.00    0.00    7.00     0.00   104.00    14.86     0.02    3.29    0.00    3.29   3.14   2.20
dm-1              0.00     0.00    0.00   13.00     0.00   104.00     8.00     0.05    3.69    0.00    3.69   1.69   2.20
12/07/2016 10:38:49 PM
          64.82    0.00    7.20    0.17    0.00   27.81
sda               0.00    10.00    0.00   18.00     0.00   224.00    12.44     0.02    1.33    0.00    1.33   1.06   1.90
dm-1              0.00     0.00    0.00   28.00     0.00   224.00     8.00     0.04    1.36    0.00    1.36   0.71   2.00
12/07/2016 10:38:50 PM
          32.89    0.00    6.18    0.17    0.00   60.77
sda               0.00    10.00    1.00    8.00     8.00   144.00    16.89     0.01    1.00    0.00    1.12   1.00   0.90
dm-1              0.00     0.00    1.00   18.00     8.00   144.00     8.00     0.02    1.16    0.00    1.22   0.47   0.90
12/07/2016 10:38:51 PM
          21.25    0.00    6.41   13.32    0.00   59.02
sda               0.00  1346.00    0.00 8378.00     0.00 77576.00     9.26   136.78   16.17    0.00   16.17   0.11  95.90
dm-1              0.00     0.00    0.00 9874.00     0.00 78992.00     8.00   159.01   15.95    0.00   15.95   0.10  95.90
12/07/2016 10:38:52 PM
          27.59    0.00    5.69    1.84    0.00   64.88
sda               0.00   108.00    0.00 1116.00     0.00 10008.00     8.97    18.72   17.92    0.00   17.92   0.13  14.50
dm-1              0.00     0.00    0.00 1074.00     0.00  8592.00     8.00    20.77   20.75    0.00   20.75   0.14  14.50
12/07/2016 10:38:53 PM
          18.52    0.00    3.20    0.00    0.00   78.28
12/07/2016 10:38:54 PM
          31.49    0.00    5.03    0.00    0.00   63.48
sda               0.00     6.00    0.00    8.00     0.00   112.00    14.00     0.01    1.00    0.00    1.00   0.88   0.70
dm-1              0.00     0.00    0.00   14.00     0.00   112.00     8.00     0.01    0.93    0.00    0.93   0.50   0.70
12/07/2016 10:38:55 PM
          27.05    0.00    6.18    0.17    0.00   66.61
sda               0.00     3.00    0.00    7.00     0.00    80.00    11.43     0.01    1.14    0.00    1.14   0.86   0.60
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.01    1.20    0.00    1.20   0.60   0.60
12/07/2016 10:38:56 PM
          22.18    0.00    4.87    0.50    0.00   72.44
sda               0.00  7217.00    0.00   72.00     0.00 58312.00   809.89     1.25   17.33    0.00   17.33   0.75   5.40
dm-1              0.00     0.00    0.00 7289.00     0.00 58312.00     8.00   145.47   19.96    0.00   19.96   0.01   5.40
12/07/2016 10:38:57 PM
          28.81    0.00    5.53    0.17    0.00   65.49
sda               0.00  2030.00    0.00   45.00     0.00 16600.00   368.89     0.42    9.29    0.00    9.29   1.67   7.50
dm-1              0.00     0.00    0.00 2075.00     0.00 16600.00     8.00    21.99   10.60    0.00   10.60   0.04   7.50
12/07/2016 10:38:58 PM
          25.46    0.00    5.40    0.00    0.00   69.14
sda               0.00     6.00    0.00    6.00     0.00    96.00    16.00     0.01    1.17    0.00    1.17   1.17   0.70
dm-1              0.00     0.00    0.00   12.00     0.00    96.00     8.00     0.01    1.25    0.00    1.25   0.67   0.80
12/07/2016 10:38:59 PM
          38.80    0.00    8.70    0.00    0.00   52.51
sda               0.00     4.00    0.00    6.00     0.00    80.00    13.33     0.01    0.83    0.00    0.83   0.67   0.40
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.01    0.80    0.00    0.80   0.40   0.40
12/07/2016 10:39:00 PM
          17.20    0.00    6.91    0.00    0.00   75.89
sda               0.00     1.00    0.00    2.00     0.00    24.00    12.00     0.01    4.00    0.00    4.00   4.00   0.80
dm-1              0.00     0.00    0.00    3.00     0.00    24.00     8.00     0.01    3.00    0.00    3.00   2.67   0.80
12/07/2016 10:39:01 PM
          39.16    0.00   12.27    0.17    0.00   48.40
sda               0.00  1106.00    0.00  103.00     0.00  9672.00    93.90     0.69    6.64    0.00    6.64   0.62   6.40
dm-1              0.00     0.00    0.00 1210.00     0.00  9680.00     8.00    11.69    9.66    0.00    9.66   0.05   6.60
12/07/2016 10:39:02 PM
          21.02    0.00    9.83    2.37    0.00   66.78
sda               0.00  5413.00    0.00 1181.00     0.00 52752.00    44.67    21.45   18.16    0.00   18.16   0.15  17.50
dm-1              0.00     0.00    0.00 6593.00     0.00 52744.00     8.00   130.62   19.81    0.00   19.81   0.03  17.50
12/07/2016 10:39:03 PM
          31.66    0.00    8.04    0.17    0.00   60.13
sda               0.00     8.00    0.00   10.00     0.00   144.00    14.40     0.02    1.90    0.00    1.90   1.80   1.80
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.04    2.06    0.00    2.06   1.00   1.80
12/07/2016 10:39:04 PM
          23.31    0.00    5.24    0.00    0.00   71.45
sda               0.00     2.00    1.00    2.00     8.00    32.00    13.33     0.01    2.33    0.00    3.50   2.33   0.70
dm-1              0.00     0.00    1.00    4.00     8.00    32.00     8.00     0.01    2.80    0.00    3.50   1.40   0.70
12/07/2016 10:39:05 PM
          20.07    0.00    5.56    0.00    0.00   74.37
sda               0.00    31.00    0.00    5.00     0.00   288.00    57.60     0.01    2.40    0.00    2.40   2.20   1.10
dm-1              0.00     0.00    0.00   36.00     0.00   288.00     8.00     0.15    4.11    0.00    4.11   0.31   1.10
12/07/2016 10:39:06 PM
          26.77    0.00    7.91    2.36    0.00   62.96
sda               0.00  7992.00   51.00  463.00   408.00 67632.00   132.37     4.44    8.63    2.65    9.29   0.71  36.70
dm-1              0.00     0.00   51.00 8457.00   408.00 67656.00     8.00   265.12   31.16    2.63   31.33   0.04  36.70
12/07/2016 10:39:07 PM
          37.48    0.00    8.07    0.84    0.00   53.61
sda               0.00  1587.00   71.00  773.00   568.00 18888.00    23.05     5.42    6.43    0.61    6.97   0.58  49.00
dm-1              0.00     0.00   71.00 2358.00   568.00 18864.00     8.00    31.70   13.05    0.62   13.43   0.20  49.00
12/07/2016 10:39:08 PM
          24.28    0.00    5.73    0.00    0.00   69.98
12/07/2016 10:39:09 PM
          25.04    0.00    6.05    0.00    0.00   68.91
sda               0.00     3.00    0.00    4.00     0.00    56.00    14.00     0.01    1.75    0.00    1.75   1.75   0.70
dm-1              0.00     0.00    0.00    7.00     0.00    56.00     8.00     0.01    1.43    0.00    1.43   1.00   0.70
12/07/2016 10:39:10 PM
          19.39    0.00    4.72    0.00    0.00   75.89
sda               0.00     6.00    0.00    5.00     0.00    88.00    17.60     0.01    1.60    0.00    1.60   1.60   0.80
dm-1              0.00     0.00    0.00   11.00     0.00    88.00     8.00     0.01    1.27    0.00    1.27   0.73   0.80
12/07/2016 10:39:11 PM
          30.25    0.00    6.89    0.50    0.00   62.35
sda               0.00  1999.00    0.00   47.00     0.00 16368.00   348.26     0.40    8.47    0.00    8.47   0.87   4.10
dm-1              0.00     0.00    0.00 2046.00     0.00 16368.00     8.00    33.57   16.41    0.00   16.41   0.02   4.10
12/07/2016 10:39:12 PM
          15.35    0.00    4.22    0.17    0.00   80.27
sda               0.00   304.00    0.00   12.00     0.00  2528.00   210.67     0.03    2.67    0.00    2.67   0.58   0.70
dm-1              0.00     0.00    0.00  316.00     0.00  2528.00     8.00     1.31    4.15    0.00    4.15   0.02   0.70
12/07/2016 10:39:13 PM
          26.94    0.00    4.55    0.00    0.00   68.52
sda               0.00     7.00    0.00   11.00     0.00   144.00    13.09     0.01    1.18    0.00    1.18   1.00   1.10
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.11    0.00    1.11   0.61   1.10
12/07/2016 10:39:14 PM
          18.55    0.00    4.72    0.00    0.00   76.73
12/07/2016 10:39:15 PM
          32.83    0.00    5.39    0.17    0.00   61.62
sda               0.00     6.00    0.00    8.00     0.00   112.00    14.00     0.01    1.38    0.00    1.38   1.25   1.00
dm-1              0.00     0.00    0.00   14.00     0.00   112.00     8.00     0.02    1.36    0.00    1.36   0.71   1.00
12/07/2016 10:39:16 PM
          23.61    0.00    6.91    0.51    0.00   68.97
sda               0.00  7063.00    0.00   84.00     0.00 57176.00   680.67     1.51   17.98    0.00   17.98   0.65   5.50
dm-1              0.00     0.00    0.00 7147.00     0.00 57176.00     8.00   139.65   19.54    0.00   19.54   0.01   5.50
12/07/2016 10:39:17 PM
          20.10    0.00    4.22    0.00    0.00   75.68
sda               0.00     3.00    0.00    8.00     0.00    88.00    11.00     0.01    1.88    0.00    1.88   1.00   0.80
dm-1              0.00     0.00    0.00   11.00     0.00    88.00     8.00     0.02    1.64    0.00    1.64   0.73   0.80
12/07/2016 10:39:18 PM
          25.84    0.00    5.70    0.17    0.00   68.29
sda               0.00     2.00    0.00    6.00     0.00    64.00    10.67     0.01    1.33    0.00    1.33   1.00   0.60
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    1.38    0.00    1.38   0.75   0.60
12/07/2016 10:39:19 PM
          18.29    0.00    4.87    0.00    0.00   76.85
sda               0.00    34.00    0.00   10.00     0.00   352.00    35.20     0.02    1.90    0.00    1.90   1.50   1.50
dm-1              0.00     0.00    0.00   44.00     0.00   352.00     8.00     0.15    3.32    0.00    3.32   0.34   1.50
12/07/2016 10:39:20 PM
          28.69    0.00    6.38    0.00    0.00   64.93
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.01    1.00    0.00    1.00   0.60   0.60
12/07/2016 10:39:21 PM
          17.59    0.00    5.36    0.17    0.00   76.88
sda               0.00    42.00    0.00    8.00     0.00   400.00    50.00     0.01    1.38    0.00    1.38   0.62   0.50
dm-1              0.00     0.00    0.00   50.00     0.00   400.00     8.00     0.09    1.86    0.00    1.86   0.10   0.50
12/07/2016 10:39:22 PM
          42.18    0.00   10.08    2.86    0.00   44.87
sda               0.00   354.00  122.00  984.00   976.00 10696.00    10.55     2.90    2.62    1.36    2.77   0.51  56.20
dm-1              0.00     0.00  122.00 1341.00   976.00 10728.00     8.00     3.92    2.67    1.37    2.78   0.38  56.10
12/07/2016 10:39:23 PM
          29.82    0.00    8.54    0.34    0.00   61.31
sda               0.00   127.00   48.00  355.00   384.00  3864.00    10.54     0.89    2.20    0.62    2.42   0.52  20.90
dm-1              0.00     0.00   48.00  479.00   384.00  3832.00     8.00     1.26    2.39    0.62    2.56   0.40  21.00
12/07/2016 10:39:24 PM
          28.91    0.00    4.54    0.17    0.00   66.39
sda               0.00     8.00    0.00    8.00     0.00   128.00    16.00     0.01    1.25    0.00    1.25   1.25   1.00
dm-1              0.00     0.00    0.00   16.00     0.00   128.00     8.00     0.02    1.25    0.00    1.25   0.62   1.00
12/07/2016 10:39:25 PM
          38.63    0.00    8.70    0.00    0.00   52.68
sda               0.00     6.00    0.00   12.00     0.00   144.00    12.00     0.01    1.25    0.00    1.25   1.00   1.20
dm-1              0.00     0.00    0.00   18.00     0.00   144.00     8.00     0.02    1.28    0.00    1.28   0.67   1.20
12/07/2016 10:39:26 PM
          23.95    0.00    5.90    0.51    0.00   69.65
sda               0.00 10819.00    0.00  112.00     0.00 87448.00   780.79     1.77   15.85    0.00   15.85   0.62   7.00
dm-1              0.00     0.00    0.00 10931.00     0.00 87448.00     8.00   200.13   18.31    0.00   18.31   0.01   7.00
12/07/2016 10:39:27 PM
          29.34    0.00    6.24    0.00    0.00   64.42
sda               0.00   137.00    0.00   15.00     0.00  1216.00    81.07     0.03    1.93    0.00    1.93   1.27   1.90
dm-1              0.00     0.00    0.00  152.00     0.00  1216.00     8.00     0.45    2.98    0.00    2.98   0.12   1.90
12/07/2016 10:39:28 PM
          25.04    0.00    4.71    0.17    0.00   70.08
sda               0.00     5.00    0.00    5.00     0.00    80.00    16.00     0.01    1.60    0.00    1.60   1.60   0.80
dm-1              0.00     0.00    0.00   10.00     0.00    80.00     8.00     0.02    1.60    0.00    1.60   0.80   0.80
12/07/2016 10:39:29 PM
          28.76    0.00    8.80    0.00    0.00   62.44
sda               0.00     3.00    0.00    5.00     0.00    64.00    12.80     0.01    1.40    0.00    1.40   1.20   0.60
12/07/2016 10:39:30 PM
          14.38    0.00    8.05    0.00    0.00   77.57
12/07/2016 10:39:31 PM
          26.77    0.00    6.23    0.17    0.00   66.84
sda               0.00   105.00    0.00   33.00     0.00  1104.00    33.45     0.09    2.64    0.00    2.64   0.42   1.40
dm-1              0.00     0.00    0.00  138.00     0.00  1104.00     8.00     0.53    3.84    0.00    3.84   0.11   1.50
12/07/2016 10:39:32 PM
          16.16    0.00    3.37    0.00    0.00   80.47
sda               0.00   130.00    0.00   13.00     0.00  1144.00    88.00     0.02    1.62    0.00    1.62   0.46   0.60
dm-1              0.00     0.00    0.00  143.00     0.00  1144.00     8.00     0.41    2.88    0.00    2.88   0.04   0.60
12/07/2016 10:39:33 PM
          30.55    0.00    5.34    0.17    0.00   63.94
sda               0.00     6.00    0.00    8.00     0.00   112.00    14.00     0.01    1.12    0.00    1.12   1.00   0.80
dm-1              0.00     0.00    0.00   14.00     0.00   112.00     8.00     0.02    1.14    0.00    1.14   0.57   0.80
12/07/2016 10:39:34 PM
          28.26    0.00    4.35    0.00    0.00   67.39
sda               0.00    33.00    0.00   11.00     0.00   352.00    32.00     0.02    1.73    0.00    1.73   1.45   1.60
dm-1              0.00     0.00    0.00   44.00     0.00   352.00     8.00     0.14    3.25    0.00    3.25   0.36   1.60
12/07/2016 10:39:35 PM
          17.82    0.00    3.19    0.00    0.00   78.99
12/07/2016 10:39:36 PM
          28.57    0.00    6.05    0.50    0.00   64.87
sda               0.00  7085.00    0.00   76.00     0.00 57288.00   753.79     1.37   18.08    0.00   18.08   0.74   5.60
dm-1              0.00     0.00    0.00 7161.00     0.00 57288.00     8.00   160.90   22.47    0.00   22.47   0.01   5.60
12/07/2016 10:39:37 PM
          16.02    0.00    3.88    9.61    0.00   70.49
sda               0.00  3198.00    0.00 6662.00     0.00 76888.00    11.54   102.87   15.12    0.00   15.12   0.11  72.00
dm-1              0.00     0.00    0.00 9993.00     0.00 79944.00     8.00   151.49   14.75    0.00   14.75   0.07  72.00
12/07/2016 10:39:38 PM
          16.84    0.00    2.53    0.51    0.00   80.13
sda               0.00   699.00    0.00  564.00     0.00 12096.00    21.45     7.06   16.35    0.00   16.35   0.10   5.60
dm-1              0.00     0.00    0.00 1130.00     0.00  9040.00     8.00    17.17   18.85    0.00   18.85   0.05   5.60
12/07/2016 10:39:39 PM
          26.01    0.00    4.03    0.17    0.00   69.80
sda               0.00     4.00    0.00    4.00     0.00    64.00    16.00     0.01    1.25    0.00    1.25   1.25   0.50
dm-1              0.00     0.00    0.00    8.00     0.00    64.00     8.00     0.01    1.25    0.00    1.25   0.62   0.50
12/07/2016 10:39:40 PM
          26.55    0.00    4.37    0.00    0.00   69.08
sda               0.00     1.00    0.00    4.00     0.00    40.00    10.00     0.01    1.75    0.00    1.75   1.50   0.60
dm-1              0.00     0.00    0.00    5.00     0.00    40.00     8.00     0.01    1.60    0.00    1.60   1.20   0.60
12/07/2016 10:39:41 PM
          21.64    0.00    3.52    0.00    0.00   74.83
sda               0.00    68.00    0.00   35.00     0.00   824.00    23.54     0.11    3.14    0.00    3.14   0.23   0.80
dm-1              0.00     0.00    0.00  103.00     0.00   824.00     8.00     0.31    3.04    0.00    3.04   0.08   0.80
12/07/2016 10:39:42 PM
          31.88    0.00    5.03    0.17    0.00   62.92
sda               0.00     4.00    0.00   11.00     0.00   112.00    10.18     0.02    1.55    0.00    1.55   1.27   1.40
dm-1              0.00     0.00    0.00   16.00     0.00   128.00     8.00     0.02    1.31    0.00    1.31   0.88   1.40
12/07/2016 10:39:43 PM
          21.20    0.00    5.51    0.17    0.00   73.12
sda               0.00     9.00    0.00   11.00     0.00   168.00    15.27     0.02    1.73    0.00    1.73   1.45   1.60
dm-1              0.00     0.00    0.00   19.00     0.00   152.00     8.00     0.04    2.05    0.00    2.05   0.84   1.60
12/07/2016 10:39:44 PM
          16.97    0.00    2.69    0.00    0.00   80.34
12/07/2016 10:39:45 PM
          17.25    0.00    3.18    0.00    0.00   79.56
sda               0.00   108.00    0.00   18.00     0.00  1008.00    56.00     0.06    3.11    0.00    3.11   2.83   5.10
dm-1              0.00     0.00    0.00  126.00     0.00  1008.00     8.00     0.69    5.48    0.00    5.48   0.40   5.10
12/07/2016 10:39:46 PM
          31.65    0.00    4.21    0.51    0.00   63.64
sda               0.00  7069.00    0.00   83.00     0.00 57216.00   689.35     1.28   15.43    0.00   15.43   0.70   5.80
dm-1              0.00     0.00    0.00 7152.00     0.00 57216.00     8.00   148.54   20.77    0.00   20.77   0.01   5.80
12/07/2016 10:39:47 PM
          20.90    0.00    5.52    0.00    0.00   73.58
12/07/2016 10:39:48 PM
          18.43    0.00    4.19    0.00    0.00   77.39
sda               0.00     4.00    0.00    5.00     0.00    72.00    14.40     0.01    1.20    0.00    1.20   1.00   0.50
dm-1              0.00     0.00    0.00    9.00     0.00    72.00     8.00     0.01    1.00    0.00    1.00   0.56   0.50
12/07/2016 10:39:49 PM
          17.28    0.00    3.02    0.17    0.00   79.53
sda               0.00     2.00    0.00    2.00     0.00    32.00    16.00     0.00    0.50    0.00    0.50   0.50   0.10
dm-1              0.00     0.00    0.00    4.00     0.00    32.00     8.00     0.00    0.50    0.00    0.50   0.25   0.10
12/07/2016 10:39:50 PM
          16.28    0.00    2.85    0.00    0.00   80.87
12/07/2016 10:39:51 PM
          16.67    0.00    3.54    0.00    0.00   79.80
sda               0.00    35.00    1.00    6.00     8.00   328.00    48.00     0.01    1.14    1.00    1.17   0.86   0.60
dm-1              0.00     0.00    1.00   41.00     8.00   328.00     8.00     0.08    1.81    1.00    1.83   0.14   0.60
12/07/2016 10:39:52 PM
          16.28    0.00    3.36    0.00    0.00   80.37
12/07/2016 10:39:53 PM
          21.75    0.00    4.55   26.31    0.00   47.39
sda               0.00   571.00   31.00 3983.00   248.00 36352.00     9.12   138.44   33.45   27.84   33.49   0.24  95.80
dm-1              0.00     0.00   32.00 4690.00   256.00 37520.00     8.00   155.40   31.94   26.97   31.97   0.20  95.80
12/07/2016 10:39:54 PM
          38.38    0.00    8.59   23.40    0.00   29.63
sda               1.00   767.00   52.00 5419.00   424.00 49440.00     9.11   144.94   26.98   21.69   27.03   0.18 100.00
dm-0              0.00     0.00    3.00    0.00    24.00     0.00     8.00     0.09   30.67   30.67    0.00  20.00   6.00
dm-1              0.00     0.00   51.00 6221.00   408.00 49768.00     8.00   165.91   26.85   20.94   26.90   0.16 100.00
12/07/2016 10:39:55 PM
          26.05    0.00    5.88    1.34    0.00   66.72
sda               0.00   164.00   68.00  758.00   544.00  7528.00     9.77     5.92    9.03    1.81    9.68   0.53  44.00
dm-1              0.00     0.00   66.00  754.00   528.00  6032.00     8.00     7.10   10.77    1.86   11.55   0.54  44.00
12/07/2016 10:39:56 PM
          20.17    0.00    4.54    3.03    0.00   72.27
sda               0.00 11859.00    0.00  434.00     0.00 98344.00   226.60    22.89   52.74    0.00   52.74   0.48  20.80
dm-1              0.00     0.00    0.00 12293.00     0.00 98344.00     8.00  1069.71   87.02    0.00   87.02   0.02  20.80
12/07/2016 10:39:57 PM
          17.45    0.00    2.52    0.00    0.00   80.03
Sorry but I just can't believe there is 'no way' to not show hosts / services that are in downtime regardless of the load / apply time..
Willem
Nagios XI 5.8.1
avandemore
What is the output of:
# dmsetup ls
WillemDH
Post by WillemDH »
dmsetup ls
VolGroup00-LogVol01     (253:0)
VolGroup00-LogVol00     (253:1)
Nagios XI 5.8.1
avandemore
That's naming isn't helpful in tracking down what is what, try this:
# ls -la /dev/mapper/*
# cat /proc/mounts
I'm seeing peak IOPS of approximately 16000/ps. This is far less than the hardware I referenced earlier. And if it's anywhere close to the theoretical maximum for the block devices you have all the evidence you need to show a disk IO limitation.
