I think in the command definition, $CONTACTEMAIL$ -- -r [email protected] should be: -r [email protected] $CONTACTEMAIL$ --
Please let us know if that resolves the issue for you.
Nagios Email Notification Setup
- Former Nagios Staff
Re: Nagios Email Notification Setup
ok perfect, i made the change to use $CONTACTEMAIL$ at the end and now my from address shows up as i configured it, however the to address still shows up funny it shows my address im sending to (like its suppose to) but it also shows the servername "[email protected]; [email protected]"
as for sending email from nagios webpage im seeing some inconsistancy.
- sending a custom host check i get the email right away
- sending a custom service check i dont get the email
- doing a re-schedule check on a host that is down (to force a email alert) does not work, same for the service check
however in the log it shows the command was executed
10-07-2016 12:51:06] SERVICE NOTIFICATION: Urgent; myvmhost.mycompany.com;Datastore VM-10GDATASTORE-2;CUSTOM (CRITICAL);notify-service-by-email;CRITICAL - /usr/local/nagios/libexec/check_vmfs.sh: line 161: --username: command not found;System Admin;sc
Service Notification[10-07-2016 12:51:06] SERVICE NOTIFICATION: Warning;myvmhost.mycompany.com;Datastore VM-10GDATASTORE-2;CUSTOM (CRITICAL);notify-service-by-email;CRITICAL - /usr/local/nagios/libexec/check_vmfs.sh: line 161: --username: command not found;System Admin;sc
External Command[10-07-2016 12:51:06] EXTERNAL COMMAND: SEND_CUSTOM_SVC_NOTIFICATION;myvmhost.mycompany.com;Datastore VM-10GDATASTORE-2;0;System Admin;sc
- Box293
- Too Basu
dwhitfield wrote:I think in the command definition, $CONTACTEMAIL$ -- -r [email protected] should be: -r [email protected] $CONTACTEMAIL$ --
Did you also update the notify-service-by-email commandscheema31 wrote:- sending a custom service check i dont get the email
yes i made the same change to the notify-service-by-email command
i have also noticed that i do get emails from the nagios instance, just seems little lagged and the custom service one doesnt work.
do i need something different in my notify-service-by-email command?
thanks!
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "* Nagios Host *\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" -r [email protected] $CONTACTEMAIL$ --
command_line /usr/bin/printf "%b" "* Nagios Services *\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" --r [email protected] $CONTACTEMAIL$ --
avandemore
There is something wrong with your service definition, see:the custom service one doesnt work.
notify-service-by-email contains an extraneous --
SERVICESTATE$ **" --r [email protected] should be SERVICESTATE$ **" -r [email protected]
Previous Nagios employee
All is working well after the syntax change.
thanks for everyones help!
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
