NRPE: Unable to read output
natalia.fitsyk
Re: NRPE: Unable to read output
Post by natalia.fitsyk »
[root@client_nrpe ~]# cat /etc/redhat-release
Red Hat Enterprise Linux Server release 6.7 (Santiago)
2.6.32-573.7.1.el6.x86_64
Thanks.
Post by dwhitfield »
Could you post the output of ls -la /usr/local/nagios/libexec?
This is the piece I don't understand at the moment: sudo: ./check_nrpe: command not found paired with [root@client_nrpe ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_users
natalia.fitsyk
ls -la /usr/local/nagios/libexec/ > libexec.txt (see attached file)
[root@client ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_users
USERS OK - 1 users currently logged in |users=1;5;10;0
When I try to run the command ./check_nrpe by logging in with user nrpe I have this output:
Because the home directory for user nrpe is /var/run/nrpe
[root@client_nrpe ~]# grep nrpe /etc/passwd
nrpe:x:500:502::/var/run/nrpe:/bin/bash
bash-4.1$ sudo ./check_nrpe
[sudo] password for nrpe:
-bash-4.1$ pwd
/var/run/nrpe
Thanks.
libexec.txt
(3.93 KiB) Downloaded 574 times
You just need to add that directory to the nrpe user's PATH. Please let us know if you have any questions after looking through http://www.troubleshooters.com/linux/prepostpath.htm
natalia.fitsyk
I added on PATH for nrpe user: /usr/local/nagios/libexec
-bash-4.1$ echo $PATH
/usr/lib64/qt-3.3/bin:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/var/run/nrpe/bin:/usr/local/nagios/libexec
-bash-4.1$ whoami
nrpe
But don't solved a problem:
-bash-4.1$ /usr/local/nagios/libexec/check_nrpe -H localhost -c check_jmeter
-bash-4.1$ /usr/local/nagios/libexec/check_nrpe -H localhost -c check_users
USERS OK - 2 users currently logged in |users=2;5;10;0
Thanks.
Natalia.
Are you running NRPE through xinetd or stand-alone? If the second, did you allow it through the firewall? Did you add the server's IP into your allowed_from in your nrpe.cfg?
natalia.fitsyk
[root@client_nrpe ~]# /etc/init.d/iptables status
iptables: Firewall is not running.
[root@client_nrpe ~]# /etc/init.d/ip6tables status
ip6tables: Firewall is not running.
Selinux is off
NRPE is stand-alone service.
IP is allowed because another check_xx are running correctly.
[root@client_nrpe ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_load
OK - load average: 0.00, 0.00, 0.00|load1=0.000;15.000;30.000;0; load5=0.000;10.000;25.000;0; load15=0.000;5.000;20.000;0;
Thanks.
Natalia.
I believe the problem is with permissions due to the sudo in multiple places here -
    #!/bin/bash
    sudo -u nrpe sudo /home/nagios/apache-jmeter-3.0/bin/jmeter.pl -j /home/nagios/apache-jmeter-3.0/ -p /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx
Could you attempt the following from the client side?
su - nagios
/usr/bin/sudo /usr/local/nagios/libexec/check_site.sh -w 1 -c 1
(not sure why you're passing -w 1 and -c 1 when they are not passed in check_site.sh anywhere)
Let us know the error you receive when trying to run it, and also post your /etc/sudoers.
natalia.fitsyk
-bash-4.1$ sudo /home/nagios/apache-jmeter-3.0/bin/jmeter.pl -j /home/nagios/apache-jmeter-3.0/ -p /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx -w 15 -c 30
OK : sum:2309 : 2.309 seconds to complete.
-bash-4.1$ pwd
/var/run/nrpe
-bash-4.1$ whoami
nrpe
-bash-4.1$ grep check_jmeter /etc/nagios/nrpe.cfg
command[check_jmeter]=/usr/bin/sudo /usr/local/nagios/libexec/check_site.sh -w $ARG1$ -c $ARG2$
[root@client_nrpe ~]# grep nrpe /etc/sudoers
nrpe          ALL=(ALL) NOPASSWD: /usr/local/nagios/libexec/check_jmeter, /usr/local/nagios/libexec/check_nrpe, /usr/local/nagios/libexec/check_site.sh, /usr/local/nagios/libexec/script_jmeter.sh, /home/nagios/apache-jmeter-3.0/bin/jmeter, /home/nagios/apache-jmeter-3.0/bin/jmeter.pl, /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx
-bash-4.1$ /usr/bin/sudo /usr/local/nagios/libexec/check_site.sh -w $ARG1$ -c $ARG2$
OK : sum:2265 : 2.265 seconds to complete.
-bash-4.1$ cd /home/nagios/apache-jmeter-3.0/bin/
-bash-4.1$ sudo ./jmeter.pl -j /home/nagios/apache-jmeter-3.0/ -p /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx
OK : sum:2122 : 2.122 seconds to complete.
OK : sum:2241 : 2.241 seconds to complete.
But
Thanks.
Natalia.
Reason: Please use [code][/code] tags around long output
ssax
Dreams In Code
Post by ssax »
Please attach your nrpe.cfg file and also the jmeter.pl script, it may have to do with it not having the correct paths (meaning running from CLI manually will already have the paths set, when it runs as a service it may have different paths).
Thank you
