check_vmfs command
Re: check_vmfs command
Post by dwhitfield »
Yes.
Also, I doubt there's any point in re-running the check_vmfs.sh until you have vmware-install.pl finishing. I suppose it's possible most of vmware-install.pl gets installed and then check_vmfs.sh goes through, but I doubt it.
scheema31
Post by scheema31 »
so in my vmware-install.pl there are many lines with
uninstall_file($gInstallerMainDB);
exit 1;
which one exactly would i need to comment out?
im pretty new to linux environment so thanks for your patience
thanks,
My apologies for the confusion. The ones under if ( !( $ftpproxy && $httpproxy)) {
scheema31
Post by scheema31 »
okay so that made some progress in running ./vmware-install.pl, there is an msg about not being able to install Perl modules on the system manually. how would i go about installing those?
also once installed do i need to recompile anything in nagios? like nagios commands?
http_proxy not set. please set environment variable 'http_proxy' e.g. export
http_proxy=http://myproxy.mydomain.com:0000 .
ftp_proxy not set. please set environment variable 'ftp_proxy' e.g. export
ftp_proxy=http://myproxy.mydomain.com:0000 .
Please wait while configuring CPAN ...
Please wait while configuring perl modules using CPAN ...
CPAN is downloading and installing pre-requisite Perl module "Archive::Zip" .
CPAN is downloading and installing pre-requisite Perl module "Crypt::SSLeay" .
"Class::MethodMaker" .
CPAN is downloading and installing pre-requisite Perl module "UUID" .
CPAN is downloading and installing pre-requisite Perl module "Data::Dump" .
CPAN is downloading and installing pre-requisite Perl module "SOAP::Lite" .
CPAN is downloading and installing pre-requisite Perl module "XML::SAX" .
"XML::NamespaceSupport" .
"XML::LibXML::Common" .
CPAN is downloading and installing pre-requisite Perl module "XML::LibXML" .
"LWP::Protocol::https" .
CPAN not able to install following Perl modules on the system. These must be
installed manually for use by vSphere CLI:
Crypt::SSLeay 0.55 or newer
Class::MethodMaker 2.10 or newer
UUID 0.03 or newer
XML::LibXML::Common 0.13 or newer
XML::LibXML 1.63 or newer
Post by Box293 »
From here:
http://www.cpan.org/modules/INSTALL.html
Install cpanm to make installing other modules easier (you'll thank us later). You need to type these commands into a Terminal emulator (Mac OS X, Win32, Linux)
cpan App::cpanminus
Now install any module you can find.
cpanm Module::Name
scheema31
Post by scheema31 »
sorry im not entirely sure of what to search for here?
Ive run the cpan App::cpanminus command... not sure how to use cpanm Module::Name
thanks!
Post by Box293 »
These are examples.
In your previous output:
scheema31 wrote:CPAN not able to install following Perl modules on the system. These must be
UUID 0.03 or newer
So you need to install these, for example:
cpanm Crypt::SSLeay
scheema31
Post by scheema31 »
oh i see, perfect.
So i got 2/5 installed now, the other three failed
cpanm XML::LibXML
--> Working on XML::LibXML
Fetching http://www.cpan.org/authors/id/S/SH/SHLOMIF/XML-LibXML-2.0128.tar.gz ... OK
Configuring XML-LibXML-2.0128 ... N/A
! Configure failed for XML-LibXML-2.0128. See /root/.cpanm/work/1476224118.15062/build.log for details.
 cpanm XML::LibXML::Common
--> Working on XML::LibXML::Common
! Configure failed for XML-LibXML-2.0128. See /root/.cpanm/work/1476224088.14626/build.log for details.
these got installed without any errors,
UUID 0.03 or newer
thanks,
Post by Box293 »
Please upload the log files:
scheema31
Post by scheema31 »
cpanm (App::cpanminus) 1.7042 on perl 5.016003 built for x86_64-linux-thread-multi
Work directory is /root/.cpanm/work/1476224118.15062
You have make /usr/bin/make
You have LWP 6.15
You have /usr/bin/tar: tar (GNU tar) 1.26
Copyright (C) 2011 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
You have /usr/bin/unzip
Searching XML::LibXML () on cpanmetadb ...
-> OK
Unpacking XML-LibXML-2.0128.tar.gz
Entering XML-LibXML-2.0128
Checking configure dependencies from META.json
Checking if you have ExtUtils::MakeMaker 6.58 ... Yes (7.24)
Running Makefile.PL
enable native perl UTF8
running xml2-config...didn't manage to get libxml2 config, guessing
options:
  LIBS='-L/usr/local/lib -L/usr/lib -lxml2 -lm'
  INC='-I/usr/local/include -I/usr/include'
If this is wrong, Re-run as:
  $ /usr/bin/perl Makefile.PL LIBS='-L/path/to/lib' INC='-I/path/to/include'
Checking for ability to link against xml2...no
Checking for ability to link against libxml2...libxml2, zlib, and/or the Math library (-lm) have not been found.
Try setting LIBS and INC values on the command line
Or get libxml2 from
  http://xmlsoft.org/
If you install via RPMs, make sure you also install the -devel
RPMs, as this is where the headers (.h files) are.
Also, you may try to run perl Makefile.PL with the DEBUG=1 parameter
to see the exact reason why the detection of libxml2 installation
failed or why Makefile.PL was not able to compile a test program.
-> N/A
-> FAIL Configure failed for XML-LibXML-2.0128. See /root/.cpanm/work/1476224118.15062/build.log for details.
Work directory is /root/.cpanm/work/1476224088.14626
You have LWP 6.15
Searching XML::LibXML::Common () on cpanmetadb ...
-> OK
Running Makefile.PL
options:
Or get libxml2 from
  http://xmlsoft.org/
-> N/A
-> FAIL Configure failed for XML-LibXML-2.0128. See /root/.cpanm/work/1476224088.14626/build.log for details.
Thanks!
