NRPE with arguments issue
- Former Nagios Staff
Re: NRPE with arguments issue
For the sake of clarity, you did not modify the file in any way, correct? If you did, could you post the modified version?
[email protected]
No modifications done, and to me the error looks like the nrpe issue not really the all interfaces call error.
avandemore
Did you restart XINETD/NRPE after adding the definition?
Previous Nagios employee
[email protected]
Yes the services have been restarted several times.
From the sound of your configuration, it sounds like this could be a possible bug. Could you post the following things once again, so that we can try to replicate this in house?
1. A copy of your /usr/local/nagios/var/objects.cache
2. A screenshot of the error you're receiving on the service status page.
3. A copy of your /usr/local/nagios/etc/nrpe.cfg AND /etc/xinetd.d/nrpe
