---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Running configuration check...
Stopping nagios:. done.
Starting nagios: done.
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/var: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up NRDP...
Backing up Nagvis...
Backing up MySQL databases...
Backing up PostgresQL databases...
Backing up logrotate config files...
Backing up Apache config files...
Compressing backup...
BACKUP COMPLETE
Backup stored in /store/backups/nagiosxi/autoupgrade_backup.1477421950.tar.gz
---- Starting Nagios XI Upgrade ----
Cleaning up temp directory...
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd: [ OK ]
Starting httpd: httpd: Could not reliably determine the server's fully qualified domain name, using nagiostest.test.steelwedge.com for ServerName
[ OK ]
Checking required prereqs...
Please wait...
OLD VERSION: 530
Loaded plugins: fastestmirror
Setting up Remove Process
No Match for argument: rpmforge-release
Loading mirror speeds from cached hostfile
* base: centos-distro.1gservers.com
* epel: mirror.sjc02.svwh.net
* extras: bay.uchicago.edu
* updates: mirror.raystedman.net
No Packages marked for removal
Setting up Install Process
Package automake-1.11.1-4.el6.noarch already installed and latest version
Package autoconf-2.63-5.1.el6.noarch already installed and latest version
Package php-mbstring-5.3.3-48.el6_8.x86_64 already installed and latest version
Package 2:nmap-6.47-1.x86_64 already installed and latest version
Package subversion-1.6.11-15.el6_7.x86_64 already installed and latest version
Nothing to do
Package perl-Test-Simple-0.92-141.el6_7.1.x86_64 already installed and latest version
Package perl-Class-Accessor-0.31-6.1.el6.noarch already installed and latest version
Package perl-Params-Validate-0.92-3.el6.x86_64 already installed and latest version
Package perl-Config-Tiny-2.12-7.1.el6.noarch already installed and latest version
Package perl-Math-Calc-Units-1.07-6.el6.noarch already installed and latest version
Package perl-Number-Format-1.73-3.el6.noarch already installed and latest version
Nothing to do
Package php-pecl-ssh2-0.11.0-7.el6.x86_64 already installed and latest version
Nothing to do
no crontab for nagios
no crontab for root
Copying over new XI directory...
Updating NagiosQL...
NAGIOSQL-POST
Patching NDOUtils...
NDOUtils already patched at level 103
Updating sequences...
Could not open input file: /usr/local/nagiosxi/tmp/nagiosxi/nagiosxi/basedir/tools/import_xiconfig.php
Nagios XI Postgres Database Sequence Information
OLD VALUES
xi_commands_command_id_seq = 429
xi_events_event_id_seq = 584825
xi_meta_meta_id_seq = 584882
xi_options_option_id_seq = 163
xi_sysstat_sysstat_id_seq = 101
xi_usermeta_usermeta_id_seq = 2112
xi_users_user_id_seq = 83
NEW VALUES
Installing new PNP templates...
Updating init script...
Enabling large install tweaks...
Fixing config file permissions...
Fixing htpasswd permissions...
Checking group memberships...
Installing new XI templates...
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=n@gweb' -O nagiosql.login--2016-10-25 12:02:59-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... 127.0.0.1, ::1
Connecting to localhost|127.0.0.1|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://nagiostest.test.steelwedge.com/nagiosxi/includes/components/ccm/ [following]
--2016-10-25 12:02:59-- https://nagiostest.test.steelwedge.com/nagiosxi/includes/components/ccm/
Resolving nagiostest.test.steelwedge.com... 127.0.0.1
Connecting to nagiostest.test.steelwedge.com|127.0.0.1|:443... connected.
WARNING: cannot verify nagiostest.test.steelwedge.com’s certificate, issued by “/C=US/ST=California/L=Pleasanton/O=Steelwedge Software/OU=CloudIT/CN=nagiostest.test.steelwedge.com/[email protected]”:
Self-signed certificate encountered.
Length: unspecified [text/html]
Saving to: “nagiosql.login”
0K .......... ......... 422K=0.05s
2016-10-25 12:03:01 (422 KB/s) - “nagiosql.login” saved [20104]
NAGIOSQL LOGIN FAILED!
