Can't compile nagios 4.2.2 workers.c / workers.o errors
Re: Can't compile nagios 4.2.2 workers.c / workers.o errors
Post by dwhitfield »
I notice several packages different on our systems. The most likely candidate would seem to be gcc 4:4.9.2-2.
Here's my list, so that others can run their own diff.
ii  acl            2.2.52-2     amd64        Access control list utilities
ii  acpi           1.7-1        amd64        displays information on ACPI devi
ii  acpi-support-b 0.142-6      all          scripts for handling base ACPI ev
ii  acpid          1:2.0.23-2   amd64        Advanced Configuration and Power
ii  adduser        3.113+nmu3   all          add and remove users and groups
ii  apache2        2.4.10-10+de amd64        Apache HTTP Server
ii  apache2-bin    2.4.10-10+de amd64        Apache HTTP Server (modules and o
ii  apache2-data   2.4.10-10+de all          Apache HTTP Server (common files)
ii  apache2-utils  2.4.10-10+de amd64        Apache HTTP Server (utility progr
ii  apt            1.0.9.8.3    amd64        commandline package manager
ii  apt-listchange 2.85.13+nmu1 all          package change history notificati
ii  apt-utils      1.0.9.8.3    amd64        package management related utilit
ii  aptitude       0.6.11-1+b1  amd64        terminal-based package manager
ii  aptitude-commo 0.6.11-1     all          architecture independent files fo
ii  aptitude-doc-e 0.6.11-1     all          English manual for aptitude, a te
ii  at             3.1.16-1     amd64        Delayed job execution and batch p
ii  autoconf       2.69-8       all          automatic configure script builde
ii  automake       1:1.14.1-4+d all          Tool for generating GNU Standards
ii  autotools-dev  20140911.1   all          Update infrastructure for config.
ii  base-files     8+deb8u6     amd64        Debian base system miscellaneous
ii  base-passwd    3.5.37       amd64        Debian base system master passwor
ii  bash           4.3-11+b1    amd64        GNU Bourne Again SHell
ii  bash-completio 1:2.1-4      all          programmable completion for the b
ii  bc             1.06.95-9    amd64        GNU bc arbitrary precision calcul
ii  bind9-host     1:9.9.5.dfsg amd64        Version of 'host' bundled with BI
ii  binutils       2.25-5       amd64        GNU assembler, linker and binary
ii  bsd-mailx      8.1.2-0.2014 amd64        simple mail user agent
ii  bsdmainutils   9.0.6        amd64        collection of more utilities from
ii  bsdutils       1:2.25.2-6   amd64        basic utilities from 4.4BSD-Lite
ii  busybox        1:1.22.0-9+d amd64        Tiny utilities for small and embe
ii  bzip2          1.0.6-7+b3   amd64        high-quality block-sorting file c
ii  ca-certificate 20141019+deb all          Common CA certificates
ii  console-setup  1.123        all          console font and keymap setup pro
ii  console-setup- 1.123        all          Linux specific part of console-se
ii  coreutils      8.23-4       amd64        GNU core utilities
ii  cpio           2.11+dfsg-4. amd64        GNU cpio -- a program to manage a
ii  cpp            4:4.9.2-2    amd64        GNU C preprocessor (cpp)
ii  cpp-4.9        4.9.2-10     amd64        GNU C preprocessor
ii  cron           3.0pl1-127+d amd64        process scheduling daemon
ii  dash           0.5.7-4+b1   amd64        POSIX-compliant shell
ii  dbus           1.8.20-0+deb amd64        simple interprocess messaging sys
ii  dc             1.06.95-9    amd64        GNU dc arbitrary precision revers
ii  debconf        1.5.56       all          Debian configuration management s
ii  debconf-i18n   1.5.56       all          full internationalization support
ii  debian-archive 2014.3       all          GnuPG archive keys of the Debian
ii  debian-faq     5.0.3        all          Debian Frequently Asked Questions
ii  debianutils    4.4+b1       amd64        Miscellaneous utilities specific
ii  dictionaries-c 1.23.17      all          spelling dictionaries - common ut
ii  diffutils      1:3.3-1+b1   amd64        File comparison utilities
ii  discover       2.1.2-7      amd64        hardware identification system
ii  discover-data  2.2013.01.11 all          Data lists for Discover hardware
ii  dmidecode      2.12-3       amd64        SMBIOS/DMI table decoder
ii  dmsetup        2:1.02.90-2. amd64        Linux Kernel Device Mapper usersp
ii  dnsutils       1:9.9.5.dfsg amd64        Clients provided with BIND
ii  doc-debian     6.2          all          Debian Project documentation and
ii  docutils-commo 0.12+dfsg-1  all          text processing system for reStru
ii  docutils-doc   0.12+dfsg-1  all          text processing system for reStru
ii  dpkg           1.17.27      amd64        Debian package management system
ii  e2fslibs:amd64 1.42.12-2    amd64        ext2/ext3/ext4 file system librar
ii  e2fsprogs      1.42.12-2    amd64        ext2/ext3/ext4 file system utilit
ii  eject          2.1.5+deb1+c amd64        ejects CDs and operates CD-Change
ii  emacsen-common 2.0.8        all          Common facilities for all emacsen
ii  exim4          4.84.2-2+deb all          metapackage to ease Exim MTA (v4)
ii  exim4-base     4.84.2-2+deb amd64        support files for all Exim MTA (v
ii  exim4-config   4.84.2-2+deb all          configuration for the Exim MTA (v
ii  exim4-daemon-l 4.84.2-2+deb amd64        lightweight Exim MTA (v4) daemon
ii  file           1:5.22+15-2+ amd64        Determines file type using "magic
ii  findutils      4.4.2-9+b1   amd64        utilities for finding files--find
ii  fontconfig     2.11.0-6.3+d amd64        generic font configuration librar
ii  fontconfig-con 2.11.0-6.3+d all          generic font configuration librar
ii  fonts-dejavu-c 2.34-1       all          Vera font family derivate with ad
ii  ftp            0.17-31      amd64        classical file transfer client
ii  gcc            4:4.9.2-2    amd64        GNU C compiler
ii  gcc-4.8-base:a 4.8.4-1      amd64        GCC, the GNU Compiler Collection
ii  gcc-4.9        4.9.2-10     amd64        GNU C compiler
ii  gcc-4.9-base:a 4.9.2-10     amd64        GCC, the GNU Compiler Collection
ii  geoip-database 20150317-1   all          IP lookup command line tools that
ii  gettext-base   0.19.3-2     amd64        GNU Internationalization utilitie
ii  gnupg          1.4.18-7+deb amd64        GNU privacy guard - a free PGP re
ii  gnupg-agent    2.0.26-6+deb amd64        GNU privacy guard - password agen
ii  gnupg2         2.0.26-6+deb amd64        GNU privacy guard - a free PGP re
ii  gpgv           1.4.18-7+deb amd64        GNU privacy guard - signature ver
ii  grep           2.20-4.1     amd64        GNU grep, egrep and fgrep
ii  groff-base     1.22.2-8     amd64        GNU troff text-formatting system
ii  grub-common    2.02~beta2-2 amd64        GRand Unified Bootloader (common
ii  grub-pc        2.02~beta2-2 amd64        GRand Unified Bootloader, version
ii  grub-pc-bin    2.02~beta2-2 amd64        GRand Unified Bootloader, version
ii  grub2-common   2.02~beta2-2 amd64        GRand Unified Bootloader (common
ii  gzip           1.6-4        amd64        GNU compression utilities
ii  hicolor-icon-t 0.13-1       all          default fallback theme for FreeDe
ii  host           1:9.9.5.dfsg all          Transitional package
ii  hostname       3.15         amd64        utility to set/show the host name
ii  iamerican      3.3.02-6     all          American English dictionary for i
ii  ibritish       3.3.02-6     all          British English dictionary for is
ii  ienglish-commo 3.3.02-6     all          Common files for British and Amer
ii  ifupdown       0.7.53.1     amd64        high level tools to configure net
ii  info           5.2.0.dfsg.1 amd64        Standalone GNU Info documentation
ii  init           1.22         amd64        System-V-like init utilities - me
ii  init-system-he 1.22         all          helper tools for all init systems
ii  initramfs-tool 0.120+deb8u2 all          generic modular initramfs generat
ii  initscripts    2.88dsf-59   amd64        scripts for initializing and shut
ii  insserv        1.14.0-5     amd64        boot sequence organizer using LSB
ii  install-info   5.2.0.dfsg.1 amd64        Manage installed documentation in
ii  installation-r 2.58         all          system installation report
ii  iproute2       3.16.0-2     amd64        networking and traffic control to
ii  iptables       1.4.21-2+b1  amd64        administration tools for packet f
ii  iputils-ping   3:20121221-5 amd64        Tools to test the reachability of
ii  isc-dhcp-clien 4.3.1-6+deb8 amd64        DHCP client for automatically obt
ii  isc-dhcp-commo 4.3.1-6+deb8 amd64        common files used by all of the i
ii  iso-codes      3.57-1       all          ISO language, territory, currency
ii  ispell         3.3.02-6     amd64        International Ispell (an interact
ii  kbd            1.15.5-2     amd64        Linux console font and keytable u
ii  keyboard-confi 1.123        all          system-wide keyboard preferences
ii  klibc-utils    2.0.4-2      amd64        small utilities built with klibc
ii  kmod           18-3         amd64        tools for managing Linux kernel m
ii  krb5-locales   1.12.1+dfsg- all          Internationalization support for
ii  laptop-detect  0.13.7       amd64        attempt to detect a laptop
ii  less           458-3        amd64        pager program similar to more
ii  libacl1:amd64  2.2.52-2     amd64        Access control list shared librar
ii  libalgorithm-c 0.09-1       all          Perl module for merging hierarchi
ii  libapache2-mod 5.6.27+dfsg- amd64        server-side, HTML-embedded script
ii  libapr1:amd64  1.5.1-3      amd64        Apache Portable Runtime Library
ii  libaprutil1:am 1.5.4-1      amd64        Apache Portable Runtime Utility L
ii  libaprutil1-db 1.5.4-1      amd64        Apache Portable Runtime Utility L
ii  libaprutil1-ld 1.5.4-1      amd64        Apache Portable Runtime Utility L
ii  libapt-inst1.5 1.0.9.8.3    amd64        deb package format runtime librar
ii  libapt-pkg4.12 1.0.9.8.3    amd64        package management runtime librar
ii  libarchive-ext 0.72-1       all          generic archive extracting module
ii  libasan1:amd64 4.9.2-10     amd64        AddressSanitizer -- a fast memory
ii  libasprintf0c2 0.19.3-2     amd64        GNU library to use fprintf and fr
ii  libassuan0:amd 2.1.2-2      amd64        IPC library for the GnuPG compone
ii  libatk1.0-0:am 2.14.0-1     amd64        ATK accessibility toolkit
ii  libatk1.0-data 2.14.0-1     all          Common files for the ATK accessib
ii  libatomic1:amd 4.9.2-10     amd64        support library providing __atomi
ii  libattr1:amd64 1:2.4.47-2   amd64        Extended attribute shared library
ii  libaudit-commo 1:2.4-1      all          Dynamic library for security audi
ii  libaudit1:amd6 1:2.4-1+b1   amd64        Dynamic library for security audi
ii  libauthen-sasl 2.1600-1     all          Authen::SASL - SASL Authenticatio
ii  libavahi-clien 0.6.31-5     amd64        Avahi client library
ii  libavahi-commo 0.6.31-5     amd64        Avahi common data files
ii  libavahi-commo 0.6.31-5     amd64        Avahi common library
ii  libbind9-90    1:9.9.5.dfsg amd64        BIND9 Shared Library used by BIND
ii  libblkid1:amd6 2.25.2-6     amd64        block device id library
ii  libboost-iostr 1.55.0+dfsg- amd64        Boost.Iostreams Library
ii  libbsd0:amd64  0.7.0-2      amd64        utility functions from BSD system
ii  libbz2-1.0:amd 1.0.6-7+b3   amd64        high-quality block-sorting file c
ii  libc-bin       2.19-18+deb8 amd64        GNU C Library: Binaries
ii  libc-dev-bin   2.19-18+deb8 amd64        GNU C Library: Development binari
ii  libc6:amd64    2.19-18+deb8 amd64        GNU C Library: Shared libraries
ii  libc6-dev:amd6 2.19-18+deb8 amd64        GNU C Library: Development Librar
ii  libcairo2:amd6 1.14.0-2.1+d amd64        Cairo 2D vector graphics library
ii  libcap-ng0:amd 0.7.4-2      amd64        An alternate POSIX capabilities l
ii  libcap2:amd64  1:2.24-8     amd64        POSIX 1003.1e capabilities (libra
ii  libcap2-bin    1:2.24-8     amd64        POSIX 1003.1e capabilities (utili
ii  libcgi-fast-pe 1:2.04-1     all          CGI subclass for work with FCGI
ii  libcgi-pm-perl 4.09-1       all          module for Common Gateway Interfa
ii  libcilkrts5:am 4.9.2-10     amd64        Intel Cilk Plus language extensio
ii  libclass-acces 0.34-1       all          Perl module that automatically ge
ii  libclass-c3-pe 0.26-1       all          pragma for using the C3 method re
ii  libclass-c3-xs 0.13-2+b1    amd64        Perl module to accelerate Class::
ii  libclass-isa-p 0.36-5       all          report the search path for a clas
ii  libcloog-isl4: 0.18.2-1+b2  amd64        Chunky Loop Generator (runtime li
ii  libcomerr2:amd 1.42.12-2    amd64        common error description library
ii  libcpan-meta-p 2.142690-1   all          Perl module to access CPAN distri
ii  libcryptsetup4 2:1.6.6-5    amd64        disk encryption support - shared
ii  libcups2:amd64 1.7.5-11+deb amd64        Common UNIX Printing System(tm) -
ii  libcurl3-gnutl 7.38.0-4+deb amd64        easy-to-use client-side URL trans
ii  libcwidget3:am 0.5.17-2     amd64        high-level terminal interface lib
ii  libdata-optlis 0.109-1      all          module to parse and validate simp
ii  libdata-sectio 0.200006-1   all          module to read chunks of data fro
ii  libdatrie1:amd 0.2.8-1      amd64        Double-array trie library
ii  libdb5.3:amd64 5.3.28-9     amd64        Berkeley v5.3 Database Libraries
ii  libdbus-1-3:am 1.8.20-0+deb amd64        simple interprocess messaging sys
ii  libdebconfclie 0.192        amd64        Debian Configuration Management S
ii  libdevmapper1. 2:1.02.90-2. amd64        Linux Kernel Device Mapper usersp
ii  libdiscover2   2.1.2-7      amd64        hardware identification library
ii  libdns-export1 1:9.9.5.dfsg amd64        Exported DNS Shared Library
ii  libdns100      1:9.9.5.dfsg amd64        DNS Shared Library used by BIND
ii  libedit2:amd64 3.1-20140620 amd64        BSD editline and history librarie
ii  libencode-loca 1.03-1       all          utility to determine the locale e
ii  libestr0       0.1.9-1.1    amd64        Helper functions for handling str
ii  libevent-2.0-5 2.0.21-stabl amd64        Asynchronous event notification l
ii  libexpat1:amd6 2.1.0-6+deb8 amd64        XML parsing C library - runtime l
ii  libexpat1-dev: 2.1.0-6+deb8 amd64        XML parsing C library - developme
ii  libfcgi-perl   0.77-1+b1    amd64        helper module for FastCGI
ii  libffi6:amd64  3.1-2+b2     amd64        Foreign Function Interface librar
ii  libfile-listin 6.04-1       all          module to parse directory listing
ii  libfont-afm-pe 1.20-1       all          Font::AFM - Interface to Adobe Fo
ii  libfontconfig1 2.11.0-6.3+d amd64        generic font configuration librar
ii  libfreetype6:a 2.5.2-3+deb8 amd64        FreeType 2 font engine, shared li
ii  libfreetype6-d 2.5.2-3+deb8 amd64        FreeType 2 font engine, developme
ii  libfuse2:amd64 2.9.3-15+deb amd64        Filesystem in Userspace (library)
ii  libgc1c2:amd64 1:7.2d-6.4   amd64        conservative garbage collector fo
ii  libgcc-4.9-dev 4.9.2-10     amd64        GCC support library (development
ii  libgcc1:amd64  1:4.9.2-10   amd64        GCC support library
ii  libgcrypt20:am 1.6.3-2+deb8 amd64        LGPL Crypto library - runtime lib
ii  libgd-dev:amd6 2.1.0-5+deb8 amd64        GD Graphics Library (development
ii  libgd2-xpm-dev 2.1.0-5+deb8 amd64        GD Graphics Library (transitional
ii  libgd3:amd64   2.1.0-5+deb8 amd64        GD Graphics Library
ii  libgdbm3:amd64 1.8.3-13.1   amd64        GNU dbm database routines (runtim
ii  libgdk-pixbuf2 2.31.1-2+deb amd64        GDK Pixbuf library
ii  libgdk-pixbuf2 2.31.1-2+deb all          GDK Pixbuf library - data files
ii  libgeoip1:amd6 1.6.2-4      amd64        non-DNS IP-to-country resolver li
ii  libglib2.0-0:a 2.42.1-1+b1  amd64        GLib library of C routines
ii  libglib2.0-dat 2.42.1-1     all          Common files for GLib library
ii  libgmp10:amd64 2:6.0.0+dfsg amd64        Multiprecision arithmetic library
ii  libgnutls-deb0 3.3.8-6+deb8 amd64        GNU TLS library - main runtime li
ii  libgnutls-open 3.3.8-6+deb8 amd64        GNU TLS library - OpenSSL wrapper
ii  libgomp1:amd64 4.9.2-10     amd64        GCC OpenMP (GOMP) support library
ii  libgpg-error0: 1.17-3       amd64        library for common error values a
ii  libgpgme11:amd 1.5.1-6      amd64        GPGME - GnuPG Made Easy (library)
ii  libgpm2:amd64  1.20.4-6.1+b amd64        General Purpose Mouse - shared li
ii  libgraphite2-3 1.3.6-1~deb8 amd64        Font rendering engine for Complex
ii  libgssapi-krb5 1.12.1+dfsg- amd64        MIT Kerberos runtime libraries -
ii  libgtk2.0-0:am 2.24.25-3+de amd64        GTK+ graphical user interface lib
ii  libgtk2.0-bin  2.24.25-3+de amd64        programs for the GTK+ graphical u
ii  libgtk2.0-comm 2.24.25-3+de all          common files for the GTK+ graphic
ii  libharfbuzz0b: 0.9.35-2     amd64        OpenType text shaping engine (sha
ii  libhogweed2:am 2.7.1-5+deb8 amd64        low level cryptographic library (
ii  libhtml-form-p 6.03-1       all          module that represents an HTML fo
ii  libhtml-format 2.11-1       all          module for transforming HTML into
ii  libhtml-parser 3.71-1+b3    amd64        collection of modules that parse
ii  libhtml-tagset 3.20-2       all          Data tables pertaining to HTML
ii  libhtml-tree-p 5.03-1       all          Perl module to represent and crea
ii  libhttp-cookie 6.01-1       all          HTTP cookie jars
ii  libhttp-daemon 6.01-1       all          simple http server class
ii  libhttp-date-p 6.02-1       all          module of date conversion routine
ii  libhttp-messag 6.06-1       all          perl interface to HTTP style mess
ii  libhttp-negoti 6.00-2       all          implementation of content negotia
ii  libice-dev:amd 2:1.0.9-1+b1 amd64        X11 Inter-Client Exchange library
ii  libice6:amd64  2:1.0.9-1+b1 amd64        X11 Inter-Client Exchange library
ii  libicu52:amd64 52.1-8+deb8u amd64        International Components for Unic
ii  libidn11:amd64 1.29-1+deb8u amd64        GNU Libidn library, implementatio
ii  libintl-perl   1.23-1+deb8u all          Uniforum message translations sys
ii  libio-html-per 1.001-1      all          open an HTML file with automatic
ii  libio-socket-i 0.32-1       all          module for using IPv4 and IPv6 so
ii  libio-socket-s 2.002-2+deb8 all          Perl module implementing object o
ii  libio-string-p 1.08-3       all          Emulate IO::File interface for in
ii  libirs-export9 1:9.9.5.dfsg amd64        Exported IRS Shared Library
ii  libisc-export9 1:9.9.5.dfsg amd64        Exported ISC Shared Library
ii  libisc95       1:9.9.5.dfsg amd64        ISC Shared Library used by BIND
ii  libisccc90     1:9.9.5.dfsg amd64        Command Channel Library used by B
ii  libisccfg-expo 1:9.9.5.dfsg amd64        Exported ISC CFG Shared Library
ii  libisccfg90    1:9.9.5.dfsg amd64        Config File Handling Library used
ii  libisl10:amd64 0.12.2-2     amd64        manipulating sets and relations o
ii  libitm1:amd64  4.9.2-10     amd64        GNU Transactional Memory Library
ii  libjasper1:amd 1.900.1-debi amd64        JasPer JPEG-2000 runtime library
ii  libjbig-dev:am 2.1-3.1      amd64        JBIGkit development files
ii  libjbig0:amd64 2.1-3.1      amd64        JBIGkit libraries
ii  libjpeg-dev    1:1.3.1-12   all          Development files for the JPEG li
ii  libjpeg62-turb 1:1.3.1-12   amd64        libjpeg-turbo JPEG runtime librar
ii  libjpeg62-turb 1:1.3.1-12   amd64        Development files for the libjpeg
ii  libjson-c2:amd 0.11-4       amd64        JSON manipulation library - share
ii  libk5crypto3:a 1.12.1+dfsg- amd64        MIT Kerberos runtime libraries -
ii  libkeyutils1:a 1.5.9-5+b1   amd64        Linux Key Management Utilities (l
ii  libklibc       2.0.4-2      amd64        minimal libc subset for use with
ii  libkmod2:amd64 18-3         amd64        libkmod shared library
ii  libkrb5-3:amd6 1.12.1+dfsg- amd64        MIT Kerberos runtime libraries
ii  libkrb5support 1.12.1+dfsg- amd64        MIT Kerberos runtime libraries -
ii  libksba8:amd64 1.3.2-1+deb8 amd64        X.509 and CMS support library
ii  liblcms2-2:amd 2.6-3+b3     amd64        Little CMS 2 color management lib
ii  libldap-2.4-2: 2.4.40+dfsg- amd64        OpenLDAP libraries
ii  liblocale-gett 1.05-8+b1    amd64        module using libc functions for i
ii  liblockfile-bi 1.09-6       amd64        support binaries for and cli util
ii  liblockfile1:a 1.09-6       amd64        NFS-safe locking library
ii  liblog-message 0.8-1        all          powerful and flexible message log
ii  liblog-message 0.10-2       all          simplified interface to Log::Mess
ii  liblogging-std 1.0.4-1      amd64        easy to use and lightweight loggi
ii  liblognorm1:am 1.0.1-3      amd64        Log normalizing library
ii  liblsan0:amd64 4.9.2-10     amd64        LeakSanitizer -- a memory leak de
ii  liblua5.1-0:am 5.1.5-7.1    amd64        Shared library for the Lua interp
ii  liblwp-mediaty 6.02-1       all          module to guess media type for a
ii  liblwp-protoco 6.06-2       all          HTTPS driver for LWP::UserAgent
ii  liblwres90     1:9.9.5.dfsg amd64        Lightweight Resolver Library used
ii  liblzma-dev:am 5.1.1alpha+2 amd64        XZ-format compression library - d
ii  liblzma5:amd64 5.1.1alpha+2 amd64        XZ-format compression library
ii  libmagic1:amd6 1:5.22+15-2+ amd64        File type determination library u
ii  libmailtools-p 2.13-1       all          Manipulate email in perl programs
ii  libmnl0:amd64  1.0.3-5      amd64        minimalistic Netlink communicatio
ii  libmodule-buil 0.421000-2+d all          framework for building and instal
ii  libmodule-plug 5.1-1        all          module for giving  modules the ab
ii  libmodule-sign 0.73-1+deb8u all          module to manipulate CPAN SIGNATU
ii  libmount1:amd6 2.25.2-6     amd64        device mounting library
ii  libmpc3:amd64  1.0.2-1      amd64        multiple precision complex floati
ii  libmpfr4:amd64 3.1.2-2      amd64        multiple precision floating-point
ii  libmro-compat- 0.12-1       all          mro::* interface compatibility fo
ii  libncurses5:am 5.9+20140913 amd64        shared libraries for terminal han
ii  libncursesw5:a 5.9+20140913 amd64        shared libraries for terminal han
ii  libnet-http-pe 6.07-1       all          module providing low-level HTTP c
ii  libnet-smtp-ss 1.01-3       all          Perl module providing SSL support
ii  libnet-ssleay- 1.65-1+deb8u amd64        Perl module for Secure Sockets La
ii  libnetfilter-a 1.0.2-1.1    amd64        Netfilter acct library
ii  libnettle4:amd 2.7.1-5+deb8 amd64        low level cryptographic library (
ii  libnewt0.52:am 0.52.17-1+b1 amd64        Not Erik's Windowing Toolkit - te
ii  libnfnetlink0: 1.0.1-3      amd64        Netfilter netlink library
ii  libnfsidmap2:a 0.25-5       amd64        NFS idmapping library
ii  libonig2:amd64 5.9.5-3.2    amd64        Oniguruma regular expressions lib
ii  libopts25:amd6 1:5.18.4-3   amd64        automated option processing libra
ii  libp11-kit0:am 0.20.7-1     amd64        Library for loading and coordinat
ii  libpackage-con 0.04-1       all          List constants defined in a packa
ii  libpam-modules 1.1.8-3.1+de amd64        Pluggable Authentication Modules
ii  libpam-runtime 1.1.8-3.1+de all          Runtime support for the PAM libra
ii  libpam0g:amd64 1.1.8-3.1+de amd64        Pluggable Authentication Modules
ii  libpango-1.0-0 1.36.8-3     amd64        Layout and rendering of internati
ii  libpangocairo- 1.36.8-3     amd64        Layout and rendering of internati
ii  libpangoft2-1. 1.36.8-3     amd64        Layout and rendering of internati
ii  libpaper-utils 1.1.24+nmu4  amd64        library for handling paper charac
ii  libpaper1:amd6 1.1.24+nmu4  amd64        library for handling paper charac
ii  libparams-util 1.07-2+b1    amd64        Perl extension for simple stand-a
ii  libparse-debia 1.2.0-1.1    all          parse Debian changelogs and outpu
ii  libpci3:amd64  1:3.2.1-3    amd64        Linux PCI Utilities (shared libra
ii  libpcre3:amd64 2:8.35-3.3+d amd64        Perl 5 Compatible Regular Express
ii  libperl4-corel 0.003-1      all          libraries historically supplied w
ii  libpipeline1:a 1.4.0-1      amd64        pipeline manipulation library
ii  libpixman-1-0: 0.32.6-3     amd64        pixel-manipulation library for X
ii  libpng12-0:amd 1.2.50-2+deb amd64        PNG library - runtime
ii  libpng12-dev:a 1.2.50-2+deb amd64        PNG library - development
ii  libpod-latex-p 0.61-1       all          module to convert Pod data to for
ii  libpod-readme- 0.11-1       all          Perl module to convert POD to REA
ii  libpopt0:amd64 1.16-10      amd64        lib for parsing cmdline parameter
ii  libprocps3:amd 2:3.3.9-9    amd64        library for accessing process inf
ii  libpsl0:amd64  0.5.1-1      amd64        Library for Public Suffix List (s
ii  libpth20:amd64 2.0.7-20     amd64        GNU Portable Threads
ii  libpthread-stu 0.3-4        amd64        pthread stubs not provided by nat
ii  libpython-stdl 2.7.9-1      amd64        interactive high-level object-ori
ii  libpython2.7-m 2.7.9-2+deb8 amd64        Minimal subset of the Python lang
ii  libpython2.7-s 2.7.9-2+deb8 amd64        Interactive high-level object-ori
ii  libqdbm14      1.8.78-5+b1  amd64        QDBM Database Libraries without G
ii  libquadmath0:a 4.9.2-10     amd64        GCC Quad-Precision Math Library
ii  libreadline6:a 6.3-8+b3     amd64        GNU readline and history librarie
ii  libregexp-comm 2013031301-1 all          module with common regular expres
ii  librtmp1:amd64 2.4+20150115 amd64        toolkit for RTMP streams (shared
ii  libsasl2-2:amd 2.1.26.dfsg1 amd64        Cyrus SASL - authentication abstr
ii  libsasl2-modul 2.1.26.dfsg1 amd64        Cyrus SASL - pluggable authentica
ii  libselinux1:am 2.3-2        amd64        SELinux runtime shared libraries
ii  libsemanage-co 2.3-1        all          Common files for SELinux policy m
ii  libsemanage1:a 2.3-1+b1     amd64        SELinux policy management library
ii  libsepol1:amd6 2.3-2        amd64        SELinux library for manipulating
ii  libsigc++-2.0- 2.4.0-1      amd64        type-safe Signal Framework for C+
ii  libsigsegv2:am 2.10-4+b1    amd64        Library for handling page faults
ii  libslang2:amd6 2.3.0-2      amd64        S-Lang programming library - runt
ii  libsm-dev:amd6 2:1.2.2-1+b1 amd64        X11 Session Management library (d
ii  libsm6:amd64   2:1.2.2-1+b1 amd64        X11 Session Management library
ii  libsmartcols1: 2.25.2-6     amd64        smart column output alignment lib
ii  libsoftware-li 0.103010-3   all          module providing templated softwa
ii  libsqlite3-0:a 3.8.7.1-1+de amd64        SQLite 3 shared library
ii  libss2:amd64   1.42.12-2    amd64        command-line interface parsing li
ii  libssh2-1:amd6 1.4.3-4.1+de amd64        SSH2 client-side library
ii  libssl1.0.0:am 1.0.1t-1+deb amd64        Secure Sockets Layer toolkit - sh
ii  libstdc++6:amd 4.9.2-10     amd64        GNU Standard C++ Library v3
ii  libsub-exporte 0.986-1      all          sophisticated exporter for custom
ii  libsub-install 0.928-1      all          module for installing subroutines
ii  libsub-name-pe 0.12-1       amd64        module for assigning a new name t
ii  libswitch-perl 2.17-2       all          switch statement for Perl
ii  libsystemd0:am 215-17+deb8u amd64        systemd utility library
ii  libtasn1-6:amd 4.2-3+deb8u2 amd64        Manage ASN.1 structures (runtime)
ii  libterm-ui-per 0.42-1       all          Term::ReadLine UI made easy
ii  libtext-charwi 0.04-7+b3    amd64        get display widths of characters
ii  libtext-iconv- 1.7-5+b2     amd64        converts between character sets i
ii  libtext-sounde 3.4-1+b2     amd64        implementation of the soundex alg
ii  libtext-templa 1.46-1       all          perl module to process text templ
ii  libtext-unidec 1.22-1       all          Text::Unidecode -- US-ASCII trans
ii  libtext-wrapi1 0.06-7       all          internationalized substitute of T
ii  libthai-data   0.1.21-1     all          Data files for Thai language supp
ii  libthai0:amd64 0.1.21-1     amd64        Thai language support library
ii  libtiff5:amd64 4.0.3-12.3+d amd64        Tag Image File Format (TIFF) libr
ii  libtiff5-dev:a 4.0.3-12.3+d amd64        Tag Image File Format library (TI
ii  libtiffxx5:amd 4.0.3-12.3+d amd64        Tag Image File Format (TIFF) libr
ii  libtimedate-pe 2.3000-2     all          collection of modules to manipula
ii  libtinfo5:amd6 5.9+20140913 amd64        shared low-level terminfo library
ii  libtirpc1:amd6 0.2.5-1      amd64        transport-independent RPC library
ii  libtokyocabine 1.4.48-3     amd64        Tokyo Cabinet Database Libraries
ii  libtsan0:amd64 4.9.2-10     amd64        ThreadSanitizer -- a Valgrind-bas
ii  libubsan0:amd6 4.9.2-10     amd64        UBSan -- undefined behaviour sani
ii  libudev1:amd64 215-17+deb8u amd64        libudev shared library
ii  liburi-perl    1.64-1       all          module to manipulate and access U
ii  libusb-0.1-4:a 2:0.1.12-25  amd64        userspace USB programming library
ii  libustr-1.0-1: 1.0.4-3+b2   amd64        Micro string library: shared libr
ii  libuuid-perl   0.05-1+b1    amd64        Perl extension for using UUID int
ii  libuuid1:amd64 2.25.2-6     amd64        Universally Unique ID library
ii  libvpx-dev:amd 1.3.0-3      amd64        VP8 and VP9 video codec (developm
ii  libvpx1:amd64  1.3.0-3      amd64        VP8 and VP9 video codec (shared l
ii  libwebp5:amd64 0.4.1-1.2+b2 amd64        Lossy compression of digital phot
ii  libwebpdemux1: 0.4.1-1.2+b2 amd64        Lossy compression of digital phot
ii  libwebpmux1:am 0.4.1-1.2+b2 amd64        Lossy compression of digital phot
ii  libwrap0:amd64 7.6.q-25     amd64        Wietse Venema's TCP wrappers libr
ii  libwww-perl    6.08-1       all          simple and consistent interface t
ii  libwww-robotru 6.01-1       all          database of robots.txt-derived pe
ii  libx11-6:amd64 2:1.6.2-3    amd64        X11 client-side library
ii  libx11-data    2:1.6.2-3    all          X11 client-side library
ii  libx11-dev:amd 2:1.6.2-3    amd64        X11 client-side library (developm
ii  libx11-doc     2:1.6.2-3    all          X11 client-side library (developm
ii  libxapian22    1.2.19-1+deb amd64        Search engine library
ii  libxau-dev:amd 1:1.0.8-1    amd64        X11 authorisation library (develo
ii  libxau6:amd64  1:1.0.8-1    amd64        X11 authorisation library
ii  libxcb-render0 1.10-3+b1    amd64        X C Binding, render extension
ii  libxcb-shm0:am 1.10-3+b1    amd64        X C Binding, shm extension
ii  libxcb1:amd64  1.10-3+b1    amd64        X C Binding
ii  libxcb1-dev:am 1.10-3+b1    amd64        X C Binding, development files
ii  libxcomposite1 1:0.4.4-1    amd64        X11 Composite extension library
ii  libxcursor1:am 1:1.1.14-1+b amd64        X cursor management library
ii  libxdamage1:am 1:1.1.4-2+b1 amd64        X11 damaged region extension libr
ii  libxdmcp-dev:a 1:1.1.1-1+b1 amd64        X11 authorisation library (develo
ii  libxdmcp6:amd6 1:1.1.1-1+b1 amd64        X11 Display Manager Control Proto
ii  libxext6:amd64 2:1.3.3-1    amd64        X11 miscellaneous extension libra
ii  libxfixes3:amd 1:5.0.1-2+b2 amd64        X11 miscellaneous 'fixes' extensi
ii  libxi6:amd64   2:1.7.4-1+b2 amd64        X11 Input extension library
ii  libxinerama1:a 2:1.1.3-1+b1 amd64        X11 Xinerama extension library
ii  libxml-libxml- 2.0116+dfsg- amd64        Perl interface to the libxml2 lib
ii  libxml-namespa 1.11-1       all          Perl module for supporting simple
ii  libxml-parser- 2.41-3       amd64        Perl module for parsing XML files
ii  libxml-sax-bas 1.07-1       all          base class for SAX drivers and fi
ii  libxml-sax-exp 0.40-2       all          Perl module for a SAX2 driver for
ii  libxml-sax-per 0.99+dfsg-2  all          Perl module for using and buildin
ii  libxml2:amd64  2.9.1+dfsg1- amd64        GNOME XML library
ii  libxmuu1:amd64 2:1.1.2-1    amd64        X11 miscellaneous micro-utility l
ii  libxpm-dev:amd 1:3.5.11-1+b amd64        X11 pixmap library (development h
ii  libxpm4:amd64  1:3.5.11-1+b amd64        X11 pixmap library
ii  libxrandr2:amd 2:1.4.2-1+b1 amd64        X11 RandR extension library
ii  libxrender1:am 1:0.9.8-1+b1 amd64        X Rendering Extension client libr
ii  libxt-dev:amd6 1:1.1.4-1+b1 amd64        X11 toolkit intrinsics library (d
ii  libxt6:amd64   1:1.1.4-1+b1 amd64        X11 toolkit intrinsics library
ii  libxtables10   1.4.21-2+b1  amd64        netfilter xtables library
ii  linux-base     3.5          all          Linux image base package
ii  linux-image-3. 3.16.36-1+de amd64        Linux 3.16 for 64-bit PCs
ii  linux-image-am 3.16+63      amd64        Linux for 64-bit PCs (meta-packag
ii  linux-libc-dev 3.16.36-1+de amd64        Linux support headers for userspa
ii  locales        2.19-18+deb8 all          GNU C Library: National Language
ii  login          1:4.2-3+deb8 amd64        system login tools
ii  logrotate      3.8.7-1+b1   amd64        Log rotation utility
ii  lsb-base       4.1+Debian13 all          Linux Standard Base 4.1 init scri
ii  lsb-release    4.1+Debian13 all          Linux Standard Base version repor
ii  lsof           4.86+dfsg-1  amd64        Utility to list open files
ii  m4             1.4.17-4     amd64        macro processing language
ii  make           4.0-8.1      amd64        utility for directing compilation
ii  man-db         2.7.0.2-5    amd64        on-line manual pager
ii  manpages       3.74-1       all          Manual pages about using a GNU/Li
ii  manpages-dev   3.74-1       all          Manual pages about using GNU/Linu
ii  mawk           1.3.3-17     amd64        a pattern scanning and text proce
ii  mime-support   3.58         all          MIME files 'mime.types' & 'mailca
ii  mlocate        0.26-1       amd64        quickly find files on the filesys
ii  mount          2.25.2-6     amd64        Tools for mounting and manipulati
ii  multiarch-supp 2.19-18+deb8 amd64        Transitional package to ensure mu
ii  mutt           1.5.23-3     amd64        text-based mailreader supporting
ii  nano           2.2.6-3      amd64        small, friendly text editor inspi
ii  ncurses-base   5.9+20140913 all          basic terminal type definitions
ii  ncurses-bin    5.9+20140913 amd64        terminal-related programs and man
ii  ncurses-term   5.9+20140913 all          additional terminal type definiti
ii  net-tools      1.60-26+b1   amd64        NET-3 networking toolkit
ii  netbase        5.3          all          Basic TCP/IP networking system
ii  netcat-traditi 1.10-41      amd64        TCP/IP swiss army knife
ii  nfacct         1.0.1-1.1    amd64        netfilter accounting object tool
ii  nfs-common     1:1.2.8-9    amd64        NFS support files common to clien
ii  ntp            1:4.2.6.p5+d amd64        Network Time Protocol daemon and
ii  openssh-client 1:6.7p1-5+de amd64        secure shell (SSH) client, for se
ii  openssh-server 1:6.7p1-5+de amd64        secure shell (SSH) server, for se
ii  openssh-sftp-s 1:6.7p1-5+de amd64        secure shell (SSH) sftp server mo
ii  openssl        1.0.1t-1+deb amd64        Secure Sockets Layer toolkit - cr
ii  os-prober      1.65         amd64        utility to detect other OSes on a
ii  passwd         1:4.2-3+deb8 amd64        change and administer password an
ii  patch          2.7.5-1      amd64        Apply a diff file to an original
ii  pciutils       1:3.2.1-3    amd64        Linux PCI Utilities
ii  perl           5.20.2-3+deb amd64        Larry Wall's Practical Extraction
ii  perl-base      5.20.2-3+deb amd64        minimal Perl system
ii  perl-modules   5.20.2-3+deb all          Core Perl modules
ii  php5           5.6.27+dfsg- all          server-side, HTML-embedded script
ii  php5-cli       5.6.27+dfsg- amd64        command-line interpreter for the
ii  php5-common    5.6.27+dfsg- amd64        Common files for packages built f
ii  php5-json      1.3.6-1      amd64        JSON module for php5
ii  php5-readline  5.6.27+dfsg- amd64        Readline module for php5
ii  pinentry-gtk2  0.8.3-2      amd64        GTK+-2-based PIN or pass-phrase e
ii  pkg-config     0.28-1       amd64        manage compile and link flags for
ii  procmail       3.22-24      amd64        Versatile e-mail processor
ii  procps         2:3.3.9-9    amd64        /proc file system utilities
ii  psmisc         22.21-2      amd64        utilities that use the proc file
ii  python         2.7.9-1      amd64        interactive high-level object-ori
ii  python-apt     0.9.3.12     amd64        Python interface to libapt-pkg
ii  python-apt-com 0.9.3.12     all          Python interface to libapt-pkg (l
ii  python-chardet 2.3.0-1      all          universal character encoding dete
ii  python-debian  0.1.27       all          Python modules to work with Debia
ii  python-debianb 1.12         all          Python interface to Debian's Bug
ii  python-defused 0.4.1-2      all          XML bomb protection for Python st
ii  python-docutil 0.12+dfsg-1  all          text processing system for reStru
ii  python-minimal 2.7.9-1      amd64        minimal subset of the Python lang
ii  python-pil:amd 2.6.1-2+deb8 amd64        Python Imaging Library (Pillow fo
ii  python-pkg-res 5.5.1-1      all          Package Discovery and Resource Ac
ii  python-pygment 2.0.1+dfsg-1 all          syntax highlighting package writt
ii  python-reportb 6.6.3        all          Python modules for interacting wi
ii  python-roman   2.0.0-1      all          module for generating/analyzing R
ii  python-six     1.8.0-1      all          Python 2 and 3 compatibility libr
ii  python-soappy  0.12.22-1    all          SOAP Support for Python
ii  python-support 1.0.15       all          automated rebuilding support for
ii  python-wstools 0.4.3-2      all          WSDL parsing tools Python module
ii  python2.7      2.7.9-2+deb8 amd64        Interactive high-level object-ori
ii  python2.7-mini 2.7.9-2+deb8 amd64        Minimal subset of the Python lang
ii  readline-commo 6.3-8        all          GNU readline and history librarie
ii  rename         0.20-3       all          Perl extension for renaming multi
ii  reportbug      6.6.3        all          reports bugs in the Debian distri
ii  rpcbind        0.2.1-6+deb8 amd64        converts RPC program numbers into
ii  rsyslog        8.4.2-1+deb8 amd64        reliable system and kernel loggin
ii  sed            4.2.2-4+b1   amd64        The GNU sed stream editor
ii  sensible-utils 0.0.9        all          Utilities for sensible alternativ
ii  sgml-base      1.26+nmu4    all          SGML infrastructure and SGML cata
ii  shared-mime-in 1.3-1        amd64        FreeDesktop.org shared MIME datab
ii  ssl-cert       1.0.35       all          simple debconf wrapper for OpenSS
ii  startpar       0.59-3       amd64        run processes in parallel and mul
ii  systemd        215-17+deb8u amd64        system and service manager
ii  systemd-sysv   215-17+deb8u amd64        system and service manager - SysV
ii  sysv-rc        2.88dsf-59   all          System-V-like runlevel change mec
ii  sysvinit-utils 2.88dsf-59   amd64        System-V-like utilities
ii  tar            1.27.1-2+b1  amd64        GNU version of the tar archiving
ii  task-english   3.31+deb8u1  all          General English environment
ii  task-ssh-serve 3.31+deb8u1  all          SSH server
ii  tasksel        3.31+deb8u1  all          tool for selecting tasks for inst
ii  tasksel-data   3.31+deb8u1  all          official tasks used for installat
ii  tcpd           7.6.q-25     amd64        Wietse Venema's TCP wrapper utili
ii  telnet         0.17-36      amd64        The telnet client
ii  texinfo        5.2.0.dfsg.1 amd64        Documentation system for on-line
ii  time           1.7-25       amd64        GNU time program for measuring CP
ii  traceroute     1:2.0.20-2+b amd64        Traces the route taken by packets
ii  tzdata         2016h-0+deb8 all          time zone and daylight-saving tim
ii  ucf            3.0030       all          Update Configuration File(s): pre
ii  udev           215-17+deb8u amd64        /dev/ and hotplug management daem
ii  unzip          6.0-16+deb8u amd64        De-archiver for .zip files
ii  util-linux     2.25.2-6     amd64        Miscellaneous system utilities
ii  util-linux-loc 2.25.2-6     all          Locales files for util-linux
ii  vim-common     2:7.4.488-7  amd64        Vi IMproved - Common files
ii  vim-tiny       2:7.4.488-7  amd64        Vi IMproved - enhanced vi editor
ii  w3m            0.5.3-19     amd64        WWW browsable pager with excellen
ii  wamerican      7.1-1        all          American English dictionary words
ii  wget           1.16-1+deb8u amd64        retrieves files from the web
ii  whiptail       0.52.17-1+b1 amd64        Displays user-friendly dialog box
ii  whois          5.2.7        amd64        intelligent WHOIS client
ii  x11-common     1:7.7+7      all          X Window System (X.Org) infrastru
ii  x11proto-core- 7.0.26-1     all          X11 core wire protocol and auxili
ii  x11proto-input 2.3.1-1      all          X11 Input extension wire protocol
ii  x11proto-kb-de 1.0.6-2      all          X11 XKB extension wire protocol
ii  xauth          1:1.0.9-1    amd64        X authentication utility
ii  xdg-user-dirs  0.15-2       amd64        tool to manage well known user di
ii  xkb-data       2.12-1       all          X Keyboard Extension (XKB) config
ii  xml-core       0.13+nmu2    all          XML infrastructure and XML catalo
ii  xorg-sgml-doct 1:1.11-1     all          Common tools for building X.Org S
ii  xtrans-dev     1.3.4-1      all          X transport library (development
ii  xz-utils       5.1.1alpha+2 amd64        XZ-format compression utilities
ii  zlib1g:amd64   1:1.2.8.dfsg amd64        compression library - runtime
ii  zlib1g-dev:amd 1:1.2.8.dfsg amd64        compression library - development
