Monitoring IIS and httpd connections
rbizzell39
Re: Monitoring IIS and httpd connections
ok I will try this thanks and will follow up
- Former Nagios Staff
Fantastic. We'll keep the thread open as long as you need.
rbizzell39
rbizzell39
Is this what I need to put in the powershell script
There are two different powershell scripts:
1. https://raw.githubusercontent.com/ester ... ctions.ps1
2. https://raw.githubusercontent.com/ester ... _state.ps1
rbizzell39
I need to add this into my ini file
# Requires allow arguments=true
check_iis8_app_pool_state = powershell.exe scripts\check_iis8_app_pool_state.ps1 $ARG1$
check_default_app_pool = powershell.exe scripts\check_iis8_app_pool_state.ps1 DefaultAppPool
check_iis8_website = powershell.exe scripts\check_iis8_site.ps1 $ARG1$
check_default_website = powershell.exe scripts\check_iis8_site.ps1 'Default Web Site'
check_connections = powershell.exe scripts\check_iis8_connections.ps1 localhost 'Default Web Site' 3000 4000The full instructions for testing are included at https://github.com/esterniclos/nagios_iis
rbizzell39
okay thanks!
No problem. Let us know how it goes!
rbizzell39
One question I want to check multiple app pools can I just replace the the DefaultAppPool with my apps and separate them with commas or semicoln
