Need help upgrading php
Re: Need help upgrading php
hqnguyen wrote:I will deploy a RHEL 7 VM and install Nagios XI from source. Is this a supported configuration?
Yes - the issue is getting the PHP version up to 5.6 without the repositories. While it's possible, it goes against the repositories which is what we depend on.
Where are you seeing 5.6 in the official repositories?
I just tested on Centos 6.8, and it looks like PHP is still utilizing 5.3.3 -
[root@localhost libexec]# cat /etc/*release*
CentOS release 6.8 (Final)
cpe:/o:centos:linux:6:GA
[root@localhost libexec]# rpm -qa | grep php
php-pdo-5.3.3-48.el6_8.x86_64
php-mysql-5.3.3-48.el6_8.x86_64
php-ldap-5.3.3-48.el6_8.x86_64
php-php-gettext-1.0.11-12.el6.noarch
php-common-5.3.3-48.el6_8.x86_64
php-bcmath-5.3.3-48.el6_8.x86_64
php-process-5.3.3-48.el6_8.x86_64
php-tidy-5.3.3-48.el6_8.x86_64
php-tcpdf-dejavu-sans-fonts-6.2.11-1.el6.noarch
php-mcrypt-5.3.3-5.el6.x86_64
php-cli-5.3.3-48.el6_8.x86_64
php-pgsql-5.3.3-48.el6_8.x86_64
php-gd-5.3.3-48.el6_8.x86_64
php-mbstring-5.3.3-48.el6_8.x86_64
php-xml-5.3.3-48.el6_8.x86_64
phpMyAdmin-4.0.10.17-2.el6.noarch
php-5.3.3-48.el6_8.x86_64
php-snmp-5.3.3-48.el6_8.x86_64
php-tcpdf-6.2.11-1.el6.noarch
php-pear-1.9.4-5.el6.noarch
php-mssql-5.3.3-5.el6.x86_64
On CentOS 7 it appears to be php-5.4.16
[root@centos7x64 ~]# cat /etc/*release*
CentOS Linux release 7.2.1511 (Core)
Derived from Red Hat Enterprise Linux 7.2 (Source)
NAME="CentOS Linux"
VERSION="7 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="7"
PRETTY_NAME="CentOS Linux 7 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:7"
HOME_URL="https://www.centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
CENTOS_MANTISBT_PROJECT="CentOS-7"
CENTOS_MANTISBT_PROJECT_VERSION="7"
REDHAT_SUPPORT_PRODUCT="centos"
REDHAT_SUPPORT_PRODUCT_VERSION="7"
[root@centos7x64 ~]# rpm -qa | grep php
php-cli-5.4.16-36.3.el7_2.x86_64
php-snmp-5.4.16-36.3.el7_2.x86_64
php-pecl-ssh2-0.12-1.el7.x86_64
php-pdo-5.4.16-36.3.el7_2.x86_64
php-xml-5.4.16-36.3.el7_2.x86_64
php-mysql-5.4.16-36.3.el7_2.x86_64
php-pgsql-5.4.16-36.3.el7_2.x86_64
php-mbstring-5.4.16-36.3.el7_2.x86_64
php-ldap-5.4.16-36.3.el7_2.x86_64
php-pear-1.9.4-21.el7.noarch
php-pear-HTML-Template-IT-1.3.0-2.el5.noarch
php-mssql-5.4.16-5.el7.x86_64
php-mcrypt-5.4.16-5.el7.x86_64
php-common-5.4.16-36.3.el7_2.x86_64
php-5.4.16-36.3.el7_2.x86_64
php-process-5.4.16-36.3.el7_2.x86_64
php-gd-5.4.16-36.3.el7_2.x86_64
avandemore
Post by avandemore »
Yes installation from source on CentOS/RHEL 6/7 is supported. Here is our document:
Manual Installation Instructions
RHSCL packages are not supported by Nagios. That beginning said, other users have reported success using PHP 5.6.
It is not tested or vetted in any official manner from our end, nor can we help if problems arise as a result of switching to PHP 5.6.
Previous Nagios employee
hqnguyen
Post by hqnguyen »
Thank you, you can close the ticket now.
