About plugin time out state
Re: About plugin time out state
@tgriep is right, and some plugins have a -t parameter for you to specify a timeout.
Pitone_Maledetto
Post by Pitone_Maledetto »
I have increased by 5 seconds the plugin timeout option.
I have adjusted the service_check_timeout value to be greater than 5 seconds compared to in built plugin; hence Nagios will kill the plugin before the plugin itself and exit UNKNOWN (which will not notify via email).
I think I will apply the change for all my checks and cut the amount of alert sent out regarding plugin timeout states.
I am happy to set this post as resolved.
Thank you all for your help.
Regards
"It is impossible to work in information technology without also engaging in social engineering"
Jaron Lanier
Sounds good, I will mark this post as resolved and close it out.
Feel free to open a new one if you need assistance in the future.
