NLS Cluster Questions - How To
gimeb
Re: NLS Cluster Questions - How To
Post by gimeb »
So what would be the steps to add new instances to the cluster
Gary
Post by mcapra »
Here's our documentation for the process:
https://assets.nagios.com/downloads/nag ... luster.pdf
Essentially, you're taking a fresh installation of Nagios Log Server and selecting the "Add Node" instead of "New Install" radio button.
gimeb
Post by gimeb »
Let me summarize cluster installation/configuration steps the should be completed after I will upgrade my original instance to 1.4.3.
As per document you have provided
1. I will skip the installation steps for every additional instance since the latest NLS version 1.4.3 will be already packages with VM template
2. I will proceed with section "Final Installation Steps" for each instance
3. For each instance I will use "Add Node" radio button
4. For each instance I will provide Cluster ID and the host name should be the IP address of my original instance
Please confirm that above steps are correct and I can proceed
Gary
This is correct.
gimeb
Post by gimeb »
Thank you for your support. I will start the upgrade process and creation of the cluster. I will let you know if any issues are encountered
Gary
Sounds good - I'll leave this open should you have any further questions.
