Unable to apply configuration
avandemore
Re: Unable to apply configuration
Profile received.
The output seems the Apply Configuration to have completed aside from the warnings. Is it working for you now?
The Errors and Warnings are generated by Nagios Core, here is some information on what Core expects in its configuration.
Services must be defined as a real service not a template to be active. A service can inherit from a template or stack of templates.
https://assets.nagios.com/downloads/nag ... tance.html
When Core generates a warning or error like the ones you have been experiencing, it's not frivolous or inaccurate. Simply reading the output and investigating the referenced file should provide some insight.
Previous Nagios employee
I was attempting to make a minor change; adding the display name to a different host via the CCM then attempting to apply the configuration.
I got the following error: After checking the file the requirements are there. Host and service description:
Not sure why I still have an issue when trying to apply this config.
# Service configuration file
# Created by: Nagios Core Config Manager 2.3.3
# Date: 2016-12-06 14:11:45
# Version: Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
host_name devappbuild01
service_description check load
use tmpl_linadm_alert_waking_hours
hostgroup_name default_linux_silent
display_name check load -w 40,30,20 -c 50,40,30
check_command custom_check_xi_by_ssh!'./check_load -w 40,30,20 -c 50,40,30'!!!!!!!
contacts astuck
contact_groups null
register 1
# END OF FILE
/usr/local/nagios/etc/services/custom_linux_load_linadmin_waking_hours_test.cfg
avandemore
XI > Admin > System Profile > Download Profile
Please include the zip file in your response. You can PM myself or other support personnel if you have privacy concerns.
avandemore
Profile received.
Please send this:
XI > Configure > Core Config Manager > Configuration Snapshots > [D/L most recent Config Error snapshot]
Please include the file in your response. You can PM myself or other support personnel if you have privacy concerns.
Please send this:
avandemore
How are you creating that service? This the definition in the config:
As noted in the previous Object Definitions documentation, the service doesn't contain all the required fields.
notification_period 24x7
contacts astuck
contact_groups null
register 1
} Previous Nagios employee
The service that is creating the issue is a copy from an existing service named:
custom_linux_load_linadmin_waking_hours.cfg
It was simply copied and altered for testing, but now it's not allowing us to apply the config if we alter something or attempt to remove a host, etc.
I've added all the required parameters to problem service by going directly to the service and adding all the parameters thru the CCM ( custom_linux_load_linadmin_waking_hours_test.cfg see below ), but it's still giving me the same error when I try to apply the config:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/custom_linux_load_linadmin_waking_hours_test.cfg', starting on line 16)
Can you please share the path of the service definition you sent in the last reply? I'm not sure we're looking at the same service definition.
[root@prdmgtnag01 scripts]# cat /usr/local/nagios/etc/services/custom_linux_load_linadmin_waking_hours_test.cfg
# Date: 2016-12-12 14:24:05
use tmpl_linadm_silent
hostgroup_name rhel5_gf_silent
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 120
first_notification_delay 5
notification_period custom_waking_hours
notification_options w,c,u,r,f,s,
contacts avillalobos
contact_groups null
register 1
# END OF FILE
avandemore
In what way was it copied?
In CCM a copy of the service also brings across the associated hosts which you don't have in the failed apply config.
Also please note the header in the file:
All those files are generated on each apply config. You need to correctly define it in XI > Configure > CCM in order for the new configuration to apply.
# import your configs into the CCM by placing them in the 'import' directory.Previous Nagios employee
The service was copied using the CCM. It was not manually edited by directly accessing the files on the server.
Here's the original service as seen on the server:
At this point, I just want to delete the problem service (custom_linux_load_linadmin_waking_hours_test.cfg) and save the changes but it won't even let me do that.
[root@prdmgtnag01 services]# cat ./custom_linux_load_linadmin_waking_hours.cfg
# Date: 2015-05-26 14:49:34
hostgroup_name default_linux_alert
register 1
# END OF FILE
avandemore
XI > Configure > Core Config Manager > Config File Management > Delete Files
XI > Configure > Core Config Manager > Configuration Snapshots > [Restore most recent Config Ok]
Apply Configuration.
That will bring your system back to the most recent known good state and ensure no ill-formed definitions are laying about.
I don't see this:
The closest thing I see is 'Write config files' which has a delete button with the following description:
"Delete all host/service configuration files"
Is it safe to run this? The description makes it sound like a dangerous thing to do.
I don't see this:
