CHECK_NRPE: Received 0 bytes
avandemore
Re: CHECK_NRPE: Received 0 bytes
There are a lot of variables at play here so that requested debug.log would be useful.
Also from the nagios side, you can increase the check_nrpe timeout with the -t argument.
Previous Nagios employee
I thing I found the issue.
Can you edit the nsclient.ini file on that Windows system and change the following lines from
to
Restart NSClient and see if that fixes it.
check_process2 = cscript.exe //T:115 //NoLogo scripts\\check_process2.vbs $ARGS"$
check_cpu_queue = cscript.exe //T:115 //NoLogo scripts\\check_cpu_queue.vbs $ARGS"$Code: Select all
check_process2 = cscript.exe //T:115 //NoLogo scripts\\check_process2.vbs $ARG1$ $ARG2$
check_cpu_queue = cscript.exe //T:115 //NoLogo scripts\\check_cpu_queue.vbs $ARG1$ $ARG2$Be sure to check out our Knowledgebase for helpful articles and solutions!
Duh... That's does look wrong. Good eye.
They still do the same after the change. I remember the person who set things up with that extra quote said it was needed at the time...
Yesterday, avandemore suggested turning on debugging for the nsclient.log file, can you do that, restart nsclient, run the check a few times and post the nsclient.log file so we can view the errors?
Then, remove the debugging setting so the log file will not get really large.
Sorry, I missed the debug request. I'll get it.
No Problem, whenever you are ready.
I've attached the log (starting yesterday) and the events from midnight today . See line 2041 and 2043 for the 1st error after midnight at 00:59.
If you look at the log bit pasted below, you'll see 3 lines w/ --- showing the command sent, the failure, and the successful retry.
I don't see any useful info, but one odd thing is the times of the errors logged don't seem to quite match. I checked time sync, and compared time between the Nagios and app server and they were the same to the second.
# grep Win /usr/local/nagios/var/nagios.log | cut -c 1-105 | perl -pe 's/(\d+)/localtime($1)/e' | grep UNKNOWN | grep txslm2mwapp008
[Thu Nov 17 00:59:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 01:50:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
[Thu Nov 17 02:40:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 03:31:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
[Thu Nov 17 04:21:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 05:12:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
[Thu Nov 17 06:03:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
[Thu Nov 17 07:27:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 07:44:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
[Thu Nov 17 09:08:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 10:50:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
[Thu Nov 17 12:14:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 15:20:35 2016] SERVICE ALERT: txslm2mwapp008;FS_Win_IO;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from dae
[Thu Nov 17 16:11:05 2016] SERVICE ALERT: txslm2mwapp008;CPU_Win_Queue;UNKNOWN;SOFT;1;CHECK_NRPE: Received 0 bytes from
---2016-11-17 00:58:55: debug:D:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: cscript.exe //T:115 //NoLogo scripts\\winFSIO.vbs
2016-11-17 00:59:15: debug:D:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.133.134.84, count=1
2016-11-17 00:59:25: debug:D:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.133.134.84, count=1
2016-11-17 00:59:25: debug:D:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: cscript.exe //T:115 //NoLogo scripts\\check_cpu_queue.vbs 4 6
2016-11-17 00:59:35: debug:D:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.133.134.84, count=1
2016-11-17 00:59:35: debug:D:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: cscript.exe //T:115 //NoLogo scripts\\Virus_detected.vbs
---2016-11-17 00:59:41: error:D:\source\nscp\include\socket/connection.hpp:149: Failed to send data: The file handle supplied is not valid
2016-11-17 00:59:55: debug:D:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.133.134.84, count=1
---2016-11-17 00:59:55: debug:D:\source\nscp\modules\CheckExternalScripts\CheckExternalScripts.cpp:459: Command line: cscript.exe //T:115 //NoLogo scripts\\winFSIO.vbs
2016-11-17 00:59:57: debug:D:\source\nscp\include\nrpe/server/protocol.hpp:74: Accepting connection from: 10.133.134.84, count=1
2016-11-17 00:59:57: debug:D:\source\nscp\include\compat.cpp:22: Created command: warn=free<=20% crit=free<=10% "detail-syntax=%(drive): Total: %(size) - Used: %(used) (%(used_pct)%) - Free: %(free) (%(free_pct)%)" show-all "filter=type in ('fixed')"
I setup my Windows system with the scripts that you uploaded and configured the nsclient.ini file like yours.
I have the winfsio script running without any errors. See below
I an running an older version of NSClient 0.4.4.10, maybe there is a bug in the newer one.
I couldn't get the check_cpu_queue.vbs script to work, it has a compilation error.
It looks like the script that was uploaded is incomplete.
Also, it writes to a file in c:\temp make sure that exists on the Windows server.
./check_nrpe -H 192.168.5.223 -c winfsio
Total Summary: 0 IO/s, Write/s 99 Reads/s: 0 Transfers/s: 99|'split_total'=0 'tps_total'=99;;;0I couldn't get the check_cpu_queue.vbs script to work, it has a compilation error.
As I've said numerous times, the scripts work, they just fail a little less than once an hour on a few of the hundreds of boxes they run on. They succeed a few seconds later when retried, as shown in the log snippet and log.
See attached.
See attached.
