check_multi support
Re: check_multi support
Not currently, this remains on our TODO list, but we haven't gotten to it yet.
On the send_nrdp.php file, try editing lines 403-405 from this:
To this:
Let us know if that resolves the issue and we'll patch the send script.
while (!feof($fp)) {
$response .= fgets($fp, 128);
}}Code: Select all
$response .= fgets($fp);
}Re: check_multi support
From what i can see nothing has changed. The output of the dell script is as follows:
and the performance data as follows:
What i find strange is that the output of the script and performance data both been separated and only send part of the complete message. The complete message is as follows:
I do notice the br/ lines which are being sent as well but i doubt they are the cause since it stops somewhere in the middle of the line. The performance data doesn't even have line breaks.
OK - System: PowerEdge R510 II, SN: *******, 32 GB ram (8 dimms), 1 logical drives, 6 physical drivesbr/----- BIOS=1.5.3 10/25/2010, iDRAC6=1.54br/----- Ctrl 0 [PERC H700 Integrated]: Fw=12.10.0-0025, Dr=00.00.04.27-SL1br/----- Encl 0:0:0 [Backplane]: Fw=
T0_System_Board_Ambient=21C;45;50 W2_System_Board_System_Level=196W;0;0 A0_PS_1_Current=0.4A;0;0 A1_PS_2_Current=0.4A;0;0 V19_PS_1_Voltage=224V;0;0 V20_PS_2_Voltage=224V;0;0 F0_System_Board_FAN_MOD_1A=3240rpm;0;0 F1_System_Board_FAN_MOD_2A=3240rpm;0;0 F2_
OK - System: 'PowerEdge R510 II', SN: '*******', 32 GB ram (8 dimms), 1 logical drives, 6 physical drives
----- BIOS='1.5.3 10/25/2010', iDRAC6='1.54'
----- Ctrl 0 [PERC H700 Integrated]: Fw='12.10.0-0025', Dr='00.00.04.27-SL1'
----- Encl 0:0:0 [Backplane]: Fw='1.10'
----- Encl 0:1:0 [Backplane]: Fw='1.10'
----- OpenManage Server Administrator (OMSA) version: '6.4.0'
T0_System_Board_Ambient=21C;45;50 W2_System_Board_System_Level=196W;0;0 A0_PS_1_Current=0.4A;0;0 A1_PS_2_Current=0.4A;0;0 V19_PS_1_Voltage=224V;0;0 V20_PS_2_Voltage=224V;0;0 F0_System_Board_FAN_MOD_1A=3240rpm;0;0 F1_System_Board_FAN_MOD_2A=3240rpm;0;0 F2_System_Board_FAN_MOD_4A=3360rpm;0;0 F3_System_Board_FAN_MOD_5A=3240rpm;0;0 F4_System_Board_FAN_MOD_3A=3240rpm;0;0
Yeah, it's still cutting off at exactly 255 bytes. I'll keep looking and see if I can find out where the memory cap is.
Is there perhaps a way to check where its being capped off? For example does it happen on the slave or on the central.
Can you send me the entire output string that you're attempting to pass exactly as it's being passed to NRDP?
Ok, lets see.
The output you requested is below. This is the input found in the nagios.log after the service check has passed. Since i dont see any nrdp debugging information i cant show you this.
For some reason i dont see any log from the performance data which is also being transfered from the same check. I have added a screenshot showing this data. If there is a way to get debugging information from nrdp in the log please let me know how i can make it visible.
[1322694000] CURRENT SERVICE STATE: defauwes-xen01;adm-hardware;OK;HARD;1;OK - System: 'PowerEdge R510 II', SN: '*******', 32 GB ram (8 dimms), 1 logical drives, 6 physical drives<br/>----- BIOS='1.5.3 10/25/2010', iDRAC6='1.54'<br/>----- Ctrl 0 [PERC H700 Integrated]: Fw='12.10.0-0025', Dr='00.00.04.27-SL1'<br/>----- Encl 0:0:0 [Backplane]: Fw='1.10'<br/>----- Encl 0:1:0 [Backplane]: Fw='1.10'<br/>----- OpenManage Server Administrator (OMSA) version: '6.4.0'
For some reason i dont see any log from the performance data which is also being transfered from the same check. I have added a screenshot showing this data. If there is a way to get debugging information from nrdp in the log please let me know how i can make it visible./usr/local/nagios/var/perfdata.log
/usr/local/nagios/var/npcd.log
As for the plugin output, after doing some testing, and being confirmed by your screenshot as well. This isn't an issue with the data being chopped off by NRDP, Nagios is receiving the full output, and it can be viewed be looking at the service in Nagios Core. If it's not producing performance graphs, then the performance data has a syntax issue, or there could also be a problem with the graph template.
You can check an rrd to see if it has any data in it with the following commands:
cd /usr/local/nagios/share/perfdata/<hostname>
rrdtool fetch <rrdfile>.rrd AVERAGEIt would have been helpful to know that you were able to see the full plugin output in the Core interface, it would have saved some debugging time ; )
I just checked the rrd file of the host with all the data and i see all data passing by. On the end however i see 2 lines with nan nan nan nan.
I just checked the output but i cant see any char that might break the output. See the post below for a best guess.
1322765520: 2.2000000000e+01 1.8200000000e+02 4.0000000000e-01 4.0000000000e-01 2.2800000000e+02 2.2800000000e+02 3.3600000000e+03 3.2400000000e+03 3.3448000000e+03 3.2400000000e+03 3.2400000000e+03
1322765580: 2.2000000000e+01 1.8200000000e+02 4.0000000000e-01 4.0000000000e-01 2.2800000000e+02 2.2800000000e+02 3.3600000000e+03 3.2400000000e+03 3.3448000000e+03 3.2400000000e+03 3.2400000000e+03
1322765640: -nan -nan -nan -nan -nan -nan -nan -nan -nan -nan -nan
1322765700: -nan -nan -nan -nan -nan -nan -nan -nan -nan -nan -nan
I think i have some more info.
I was browsing all the logs when i came across the nagios.log. Here i found all the checks that where passed to the central from all slaves. Because of this i decided to search for the data that was being cut off and i found the following:
From this service the screenshot is
A other example is the following:
In this case its a multi check which sends massive amounts of data which according to the log are being received but not being shown on the page. A screenshot for this is as follows:
Seeing all this i would guess that the central cant show the complete output as its being limited to 255 characters. Is there a way to change this since we have multiple checks that have several 1000 chars to show.
[1322694000] CURRENT SERVICE STATE: defauwes-xen01;adm-hardware;OK;HARD;1;OK - System: PowerEdge R510 II, SN: *******, 32 GB ram (8 dimms), 1 logical drives, 6 physical drivesbr/----- BIOS=1.5.3 10/25/2010, iDRAC6=1.54br/----- Ctrl 0 [PERC H700 Integrated]: Fw=12.10.0-0025, Dr=00.00.04.27-SL1br/----- Encl 0:0:0 [Backplane]: Fw=1.10br/----- Encl 0:1:0 [Backplane]: Fw=1.10br/----- OpenManage Server Administrator (OMSA) version: 6.4.0
[1322694000] CURRENT SERVICE STATE: defauwes-ts002;events;CRITICAL;HARD;3;check_multi CRITICAL - 102 plugins checked, 1 critical (event_id_1074), 51 unknown (event_id_1501, event_id_1699, event_id_2001, event_id_2013, event_id_2019, event_id_2020, event_id_2025, event_id_2026, event_id_2027, event_id_2507, event_id_2511, event_id_3002, event_id_3003, event_id_3005, event_id_3020, event_id_3055, event_id_3056, event_id_3057, event_id_3096, event_id_4003, event_id_4005, event_id_4006, event_id_4102, event_id_4103, event_id_4105, event_id_4198, event_id_4199, event_id_4226, event_id_4319, event_id_5148, event_id_5149, event_id_5782, event_id_5789, event_id_6000, event_id_6008, event_id_7000, event_id_7016, event_id_7022, event_id_7023, event_id_7024, event_id_7025, event_id_7027, event_id_7031, event_id_7033, event_id_7034, event_id_7037, event_id_7038, event_id_12290, event_id_12302, event_id_12305, event_id_16387), 50 ok
