check_nwc_plugin interface-availability output html
liangwh
Re: check_nwc_plugin interface-availability output html
Post by liangwh »
I have added -v and the output is still truncated.
=( .. is there other things i can look into
thanks
nietonoshana
Post by nietonoshana »
Hello, this way of seeing the availability of the interfaces I like so try to get it obtaining the same results, but verifying a little I can comment something, the output I have complete in the database, where it is lost is in step In the status view, the output is complete until it passes through the function xmlentities in the file utilsx.inc.php, I suppose it is cut to be of a length greater than 4000, but to correct this file escapes my possibilities.
I think the nagios development team could verify this
ruffsense
Post by ruffsense »
which version of the plugin?
I don't insult, I diagnose.
Nagios Support
Post by Nagios Support »
We will have our developers look into this and will get back to you within the next 24 hours. Thank you!
As it's working in Core, but no XI, I filed a bug report for this. ID #10355. I suspect it's still being truncated somewhere at this point.
@liangwh
Make a backup of the "original" utilsx.inc.php file:
cp -p /usr/local/nagiosxi/html/includes/utilsx.inc.php /usr/local/nagiosxi/html/includes/utilsx.inc.php.backup
Download the zip file below:
utilsx.inc.php.zip
unzip it, and copy the extracted "utilsx.inc.php" to "/usr/local/nagiosxi/html/includes/" directory, overwriting the "original" file.
Let us know if this solves your issue. Thank you!
liangwh
Post by liangwh »
Hi ,
Thanks for the utilsx.
Instead of 6 output, it is now up to 70-80 interfaces, but the total interface is around 200-300..kindly assist.
Or kindly let me know which lines to change the limit of the output
Thankss :oops: :oops:
Post by dwhitfield »
It's possible that fix only works in 5.3. Any chance you could upgrade? Instructions at https://assets.nagios.com/downloads/nag ... nstall.pdf After you upgrade, you'll need to reapply the fix. If you run into upgrade issues, please post your upgrade log here. Thanks!
If you can't upgrade, you'll need to wait for the fix to go through our testing process.
nietonoshana
Hello
Can you create a backup?
And after try this faq
https://support.nagios.com/kb/article.php?id=478
I think whit this do you view all output
liangwh wrote:Hi ,
@liangwh were you able to perform the upgrade and reapply the patch?
