It could be the Open File limit on your server is too small and that is causing the issue. Try following this KB article and that should fix it for you.
https://support.nagios.com/kb/article.php?id=512
NagiosXI-WizardError
Re: NagiosXI-WizardError
What is the output of these commands:
Also, run this command:
Let that command run and then apply config again and send the entire output.
Thank you
sestatus
chage -l nagios
chage -l apache
grep nag /etc/group
grep "User \|Group " /etc/httpd/conf/httpd.confCode: Select all
tail -F /var/log/messages /var/log/httpd/*error_log /usr/local/nagios/var/cmdsubsys.logThank you
maartin.pii
ssax wrote:What is the output of these commands:
Also, run this command:Code: Select all
sestatus chage -l nagios chage -l apache grep nag /etc/group grep "User \|Group " /etc/httpd/conf/httpd.conf
Let that command run and then apply config again and send the entire output.Code: Select all
Thank you
[root@~]# sestatus
SELinux status: disabled
[root@~]# chage -l nagios
Last password change : Aug 04, 2016
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : 0
Maximum number of days between password change : 99999
Number of days of warning before password expires : 7
[root@~]# chage -l apache
Last password change : Aug 17, 2016
Minimum number of days between password change : -1
Maximum number of days between password change : -1
Number of days of warning before password expires : -1
[root@~]# grep nag /etc/group
nagios:x:994:nagios,apache
nagcmd:x:2001:nagios,apache
[root@~]# grep "User \|Group " /etc/httpd/conf/httpd.conf
User apache
Group apache
maartin.pii
These are my limits config:tgriep wrote:It could be the Open File limit on your server is too small and that is causing the issue. Try following this KB article and that should fix it for you.
* hard nofile 10000
* soft nofile 10000
root hard nofile 10000
root soft nofile 10000
I think that these values are bigger than the ones which are recommended - Should I modify them?
avandemore
Please post or PM the full output of this:
# cd /usr/local/nagiosxi/scripts/
# bash -x reconfigure_nagios.shPrevious Nagios employee
maartin.pii
+ ./import_nagiosql.sh
--2016-12-15 14:47:29-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:80... connected.
Length: unspecified [text/html]
Saving to: ânagiosql.loginâ
[ <=> ] 37,170 --.-K/s in 0.03s
2016-12-15 14:47:29 (1.35 MB/s) - ânagiosql.loginâ saved [37170]
+ ret=0
+ '[' 0 -gt 0 ']'
+ ./restart_nagios_with_export.sh
--2016-12-15 14:47:30-- http://localhost/nagiosxi/includes/components/ccm/
[ <=> ] 37,170 --.-K/s in 0.01s
2016-12-15 14:47:30 (2.40 MB/s) - ânagiosql.loginâ saved [37170]
--2016-12-15 14:47:31-- http://localhost/nagiosxi/includes/components/ccm/
Saving to: ânagiosql.export.monitoringâ
[ <=> ] 21,599 --.-K/s in 0.01s
2016-12-15 14:47:42 (1.50 MB/s) - ânagiosql.export.monitoringâ saved [21599]
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&backend=1&username=nagiosxi&password=n@gweb' -O nagiosql.loginLOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
CMDLINE
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'backend=1&cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
WARNING: Extinfo objects are deprecated and will be removed in future versions
Warning: Duplicate definition found for service 'SO : LOAD' on host '' (config file '/usr/local/nagios/etc/services/CLICKOS1.cfg', starting on line 66)
Warning: Duplicate definition found for service 'SO : DISK' on host '' (config file '/usr/local/nagios/etc/services/CLICKOS1.cfg', starting on line 50)
Warning: Duplicate definition found for service 'DBA : ORACLE : STATUS : ' on host 'clickos1' (config file '/usr/local/nagios/etc/services/CLICKOS1.cfg', starting on line 33)
Warning: Duplicate definition found for service 'DBA : ORACLE : SPACE : ' on host 'clickos1' (config file '/usr/local/nagios/etc/services/CLICKOS1.cfg', starting on line 16)
Warning: Duplicate definition found for service 'SO : LOAD' on host '' (config file '/usr/local/nagios/etc/services/BUHOP1.cfg', starting on line 69)
Warning: Duplicate definition found for service 'SO : DISK' on host '' (file '/usr/local/nagios/etc/services/BUHOP1.cfg', starting on line 52)
Warning: Duplicate definition found for service 'DBA : ORACLE : STATUS : ' on host 'buhop1' (config file '/usr/local/nagios/etc/services/BUHOP1.cfg', starting on line 34)
Warning: Duplicate definition found for service 'DBA : ORACLE : SPACE : ' on host 'buhop1' (config file '/usr/local/nagios/etc/services/BUHOP1.cfg', starting on line 16)
Warning: Duplicate definition found for service 'NET: MEM' on host '' (config file '/usr/local/nagios/etc/services/_multiple_hosts.cfg', starting on line 16)
Warning: Duplicate definition found for service 'SO : LOAD' on host 'buhor1' (config file '/usr/local/nagios/etc/services/buhor1.cfg', starting on line 66)
Warning: Duplicate definition found for service 'SO : DISK' on host '' (file '/usr/local/nagios/etc/services/buhor1.cfg', starting on line 50)
Warning: Duplicate definition found for service 'DBA : ORACLE : STATUS : ' on host 'buhor1' (config file '/usr/local/nagios/etc/services/buhor1.cfg', starting on line 33)
Warning: Duplicate definition found for service 'DBA : ORACLE : SPACE : ' on host 'buhor1' (config file '/usr/local/nagios/etc/services/buhor1.cfg', starting on line 16)
Warning: Duplicate definition found for service 'SO : LOAD' on host '' (config file '/usr/local/nagios/etc/services/buhod1.cfg', starting on line 66)
Warning: Duplicate definition found for service 'SO : DISK' on host '' (config file '/usr/local/nagios/etc/services/buhod1.cfg', starting on line 50)
Warning: Duplicate definition found for service 'DBA : ORACLE : STATUS : ' on host 'buhod1' (config file '/usr/local/nagios/etc/services/buhod1.cfg', starting on line 33)
Warning: Duplicate definition found for service 'DBA : ORACLE : SPACE : ' on host 'buhod1' (config file '/usr/local/nagios/etc/services/buhod1.cfg', starting on line 16)
Checking objects...
Warning: Service 'BPIEX' on host 'BPIEX' has no default contacts or contactgroups defined!
Checked 9703 services.
Warning: Host 'BPIEX' has no default contacts or contactgroups defined!
Checked 412 hosts.
Checked 31 host groups.
Checked 4 service groups.
Warning: Host recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify down and/or unreachable options as well
Warning: Service recovery notification option for contact 'nagiosadmin' doesn't make any sense - specify critical and/or warning options as well
Checked 52 contacts.
Checked 13 contact groups.
Checked 355 commands.
Checked 34 time periods.
Checked 0 host escalations.
Checked 412 hosts
Checked 0 host dependencies
Checked 34 timeperiods
Checking misc settings...
Total Warnings: 4
Total Errors: 0
RET: 0
+ ret=0
+ '[' 0 -gt 0 ']'
+ exit 0
Can you email in the /etc/php.ini file so I can view it's settings?
What version of XI is the server running and what is the version of the Network Stitch Router wizard is installed on the system?
To view that, go to the Admin > Manage Config Wizards menu to view it.
If it is not at the latest version, update it and see if that resolves the issue.
