Passive check freshness check not working
avandemore
Re: Passive check freshness check not working
Opps, that was supposed to be >= as shown by the 20 minutes value I suggested.
Previous Nagios employee
- snapon_admin
I tried that on one of the checks, it stayed green for the 20 minute interval and then went back to warning again with the "no passive checks" received script output.
avandemore
How are the passive checks received? SNMP traps, NRDP, NSCA, etc?
While I rather doubt this is the solution, you can restore a previous configuration via XI > Configure > CCM > Configuration Snapshots and doing an Apply Config. You would use the most recent one prior to yesterday if you do this. Also remember this will undo all configuration changes in Nagios XI since that point.
- snapon_admin
NSCA, and yeah I'd prefer not to do that, but I am saving that as a last resort.
avandemore
Perhaps a project for another day but NSCA has seen its first update in a long time:
https://github.com/NagiosEnterprises/ns ... ease-2.9.2
Are we absolutely sure checks are being received?
You can run that for one of these 20 minute durations and PM the resulting /tmp/capture.cap.
# tcpdump -i any -n "src host <remote ip> and dst port 5667" -w /tmp/capture.capPrevious Nagios employee
- snapon_admin
tcpdump appears to not be a thing on my server, getting syntax error when I try.
avandemore
Ok, try this:
Then retry.
# yum install -y -q tcpdumpPrevious Nagios employee
- snapon_admin
My bad, tcpdump wasn't the issue, it's the -n option that's the syntax error. I've used tcpdump before so it's definitely on there.
[root@lisl-ngos-01-pv ~]# tcpdump -h
tcpdump version 4.1-PRE-CVS_2016_05_10
libpcap version 1.4.0
Usage: tcpdump [-aAdDefhIJKlLnNOpqRStuUvxX] [ -B size ] [ -c count ]
[ -C file_size ] [ -E algo:secret ] [ -F file ] [ -G seconds ]
[ -i interface ] [ -j tstamptype ] [ -M secret ]
[ -Q|-P in|out|inout ]
[ -r file ] [ -s snaplen ] [ -T type ] [ -w file ]
[ -W filecount ] [ -y datalinktype ] [ -z command ]
[ -Z user ] [ expression ]-
avandemore
Perhaps you're on CentOS/RHEL 6, 7 has a newer tcpdump.
Anyways, you can just omit the -n, it isn't needed just perhaps nicer.
avandemore
pcap file received, you are getting the check data from that host.
Can you send over your /usr/local/nagios/etc/nsca.cfg?
Also in that file changing to debug=1 and restarting xinetd/nsca should show more verbose messages in /var/log/messages.
