could not installed nagios client on RHEL7
Re: could not installed nagios client on RHEL7
Post by dwhitfield »
Can you post or PM the output of history?
If you choose to PM the output, please update this thread. Updating this thread is the only way for it to show back up on our dashboard.
pcouas
Post by pcouas »
Which profile ? profile in this forum ?
I connect to my remote computer with putty on command line ? no GUI ?
I could send you history commands ?
If it's possible to relaunch my 4 linux commands ??, i could send you screen only in this case because putty tools buffer is too short.
Regards
pcouas
Post by pcouas »
Which directory removing before relaunch linux command ?
Currently i have two directory /usr/local/nagios/libexec and /usr/local/share, but nothing else ?
pcouas
Post by pcouas »
Hi
I have relaunched after moving /usr/local/nagios
Same problem
Logs
Regards
FIRST
[ec2-user@cprod nagios-plugins-release-2.1.3]$ sudo ./tools/setup
which: no gnumake in (/sbin:/bin:/usr/sbin:/usr/bin)
Found GNU Make at /bin/gmake ... good.
pcouas
Post by pcouas »
SECOND
sudo ./configure
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for Minix Amsterdam compiler... no
checking for ar... ar
checking for ranlib... ranlib
checking whether gcc and cc understand -c and -o together... yes
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether _XOPEN_SOURCE should be defined... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking whether gcc needs -traditional... no
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /bin/ld
checking if the linker (/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /bin/nm -B
checking the name lister (/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... (cached) ranlib
checking command to parse /bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for error_at_line... yes
checking for special C compiler options needed for large files... (cached) no
checking for _FILE_OFFSET_BITS value needed for large files... (cached) no
checking for working strtod... yes
checking for python... /bin/python
checking for sh... /bin/sh
checking for perl... /bin/perl
checking for libgnutls-config... no
checking for hostname... /bin/hostname
checking for basename... /bin/basename
checking for main in -ldce... no
checking for main in -lnsl... yes
checking for socket in -lsocket... no
checking for main in -lresolv... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking for floor in -lm... yes
checking mp.h usability... no
checking mp.h presence... no
checking for mp.h... no
checking for pow in -lbsd... no
checking for plan_tests in -ltap... no
checking for main in -lcrypt... yes
checking for PQsetdbLogin in -lpq... no
configure: WARNING: Skipping PostgreSQL plugin (check_pgsql)
configure: WARNING: LIBS="-lcrypt " CPPFLAGS=""
configure: WARNING: install PostgreSQL libs to compile this plugin (see REQUIREMENTS).
checking for dbi_initialize in -ldbi... no
configure: WARNING: Skipping dbi plugin
configure: WARNING: install DBI libs to compile this plugin (see REQUIREMENTS).
checking for rc_read_config in -lfreeradius-client... no
checking for rc_read_config in -lradiusclient-ng... no
checking for rc_read_config in -lradiusclient... no
configure: WARNING: Skipping radius plugin
configure: WARNING: install radius libs to compile this plugin (see REQUIREMENTS).
checking for main in -lldap... no
configure: WARNING: Skipping LDAP plugin
configure: WARNING: install LDAP libs to compile this plugin (see REQUIREMENTS).
checking linux/hdreg.h usability... yes
checking linux/hdreg.h presence... yes
checking for linux/hdreg.h... yes
checking linux/types.h usability... yes
checking linux/types.h presence... yes
checking for linux/types.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for mysql_config... no
configure: WARNING: Skipping mysql plugin
configure: WARNING: install mysql client libs to compile this plugin (see REQUIREMENTS).
checking utmpx.h usability... yes
checking utmpx.h presence... yes
checking for utmpx.h... yes
checking for wtsapi32.h... no
checking for IPv6 support... yes
checking krb5.h usability... yes
checking krb5.h presence... yes
checking for krb5.h... yes
checking for dlopen in -ldl... yes
checking for shl_load in -ldl... no
checking openssl/ssl.h usability... yes
checking openssl/ssl.h presence... yes
checking for openssl/ssl.h... yes
checking openssl/x509.h usability... yes
checking openssl/x509.h presence... yes
checking for openssl/x509.h... yes
checking openssl/rsa.h usability... yes
checking openssl/rsa.h presence... yes
checking for openssl/rsa.h... yes
checking openssl/pem.h usability... yes
checking openssl/pem.h presence... yes
checking for openssl/pem.h... yes
checking openssl/crypto.h usability... yes
checking openssl/crypto.h presence... yes
checking for openssl/crypto.h... yes
checking openssl/err.h usability... yes
checking openssl/err.h presence... yes
checking for openssl/err.h... yes
checking for CRYPTO_lock in -lcrypto... yes
checking for main in -lssl... yes
checking whether time.h and sys/time.h may both be included... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking uio.h usability... no
checking uio.h presence... no
checking for uio.h... no
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking for sys/time.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking sys/unistd.h usability... yes
checking sys/unistd.h presence... yes
checking for sys/unistd.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for an ANSI C-conforming const... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for pid_t... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for va_copy... yes
checking for memmove... yes
checking for select... yes
checking for socket... yes
checking for strdup... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoul... yes
checking for floor... no
checking for sigaction... yes
checking for poll... yes
checking return type of socket size... int
checking for ps... /bin/ps
checking for env... /bin/env
checking for ps syntax... /bin/ps axwwo 'stat uid pid ppid vsz rss pcpu cgroup:256 comm args'
checking for ping... /bin/ping
checking for ping6... /sbin/ping6
checking for ICMP ping syntax... /bin/ping -n -U -w %d -c %d %s
checking for ICMPv6 ping syntax... /sbin/ping6 -n -U -w %d -c %d %s
checking for nslookup... no
configure: WARNING: nslookup command not found
checking for number of online cpus... sysconf(_SC_NPROCESSORS_ONLN)
checking for number of available cpus... sysconf(_SC_NPROCESSORS_CONF)
checking for uptime... /bin/uptime
checking for rpcinfo... no
checking for lmstat... no
configure: WARNING: Get lmstat from Globetrotter Software to monitor flexlm licenses
checking for smbclient... no
configure: WARNING: Get smbclient from Samba.org to monitor SMB shares
checking for snmpget... no
configure: WARNING: Get snmpget from http://net-snmp.sourceforge.net to make check_hpjd and check_snmp plugins
checking for snmpgetnext... no
configure: WARNING: Tried /bin/perl - install Net::SNMP perl module if you want to use the perl snmp plugins
checking for quakestat... no
checking for qstat... no
configure: WARNING: Get qstat from http://www.activesw.com/people/steve/qstat.html in order to make check_game plugin
checking for fping... no
checking for fping6... no
configure: WARNING: Get fping from http://www.fping.com in order to make check_fping plugin
checking for ssh... /bin/ssh
checking for sudo... /bin/sudo
checking for mailq... /bin/mailq
checking for qmail-qstat... no
configure: WARNING: Could not find qmail-qstat or eqivalent
checking for swap... no
checking for swapinfo... no
checking for lsps... no
checking for sys/stat.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/swap.h... yes
checking whether swapctl is declared... no
checking for swaptbl_t... no
checking for swapent_t... no
checking for struct swapent.se_nblks... no
checking for struct msghdr.msg_control... no
checking for struct msghdr.msg_controllen... no
checking for /proc/meminfo... found /proc/meminfo
checking for dig... no
checking for apt-get... no
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking whether NLS is requested... yes
checking for msgfmt... /bin/msgfmt
checking for gmsgfmt... /bin/msgfmt
checking for xgettext... /bin/xgettext
checking for msgmerge... /bin/msgmerge
checking for ld used by gcc... /bin/ld -m elf_x86_64
checking if the linker (/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for main in -lpthread... yes
checking for working alloca.h... yes
checking for alloca... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for features.h... (cached) yes
checking for unistd.h... (cached) yes
checking for sys/param.h... (cached) yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/fs_types.h usability... no
checking sys/fs_types.h presence... no
checking for sys/fs_types.h... no
checking for sys/socket.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking xlocale.h usability... yes
checking xlocale.h presence... yes
checking for xlocale.h... yes
checking for math.h... (cached) yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking for stdint.h... (cached) yes
checking for strings.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking for sys/uio.h... yes
checking wctype.h usability... yes
checking wctype.h presence... yes
checking for wctype.h... yes
checking whether the preprocessor supports include_next... yes
checking whether system header files limit the line length... no
checking for C/C++ restrict keyword... __restrict
checking whether <wchar.h> uses 'inline' correctly... yes
checking for btowc... yes
checking for getuid... yes
checking for geteuid... yes
checking for getresuid... yes
checking for getgid... yes
checking for getegid... yes
checking for getresgid... yes
checking for setresuid... yes
checking for setreuid... yes
checking for seteuid... yes
checking for setresgid... yes
checking for setregid... yes
checking for setegid... yes
checking for symlink... yes
checking for mbsinit... yes
checking for mbrtowc... yes
checking for mprotect... yes
checking for _set_invalid_parameter_handler... no
checking for nl_langinfo... yes
checking for isblank... yes
checking for iswctype... yes
checking for wcscoll... yes
checking for setenv... yes
checking for snprintf... yes
checking for strndup... yes
checking for localtime_r... yes
checking for timegm... yes
checking for vasnprintf... no
checking for wcrtomb... yes
checking for iswcntrl... yes
checking for nl_langinfo and CODESET... yes
checking for a traditional french locale... fr_FR
checking whether byte ordering is bigendian... no
checking whether // is distinct from /... no
checking if environ is properly declared... yes
checking for complete errno.h... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... yes
checking whether <sys/socket.h> is self-contained... yes
checking for shutdown... yes
checking whether <sys/socket.h> defines the SHUT_* macros... yes
checking for struct sockaddr_storage... yes
checking for sa_family_t... yes
checking for struct sockaddr_storage.ss_family... yes
checking whether socket is declared without a macro... yes
checking whether connect is declared without a macro... yes
checking whether accept is declared without a macro... yes
checking whether bind is declared without a macro... yes
checking whether getpeername is declared without a macro... yes
checking whether getsockname is declared without a macro... yes
checking whether getsockopt is declared without a macro... yes
checking whether listen is declared without a macro... yes
checking whether recv is declared without a macro... yes
checking whether send is declared without a macro... yes
checking whether recvfrom is declared without a macro... yes
checking whether sendto is declared without a macro... yes
checking whether setsockopt is declared without a macro... yes
checking whether shutdown is declared without a macro... yes
checking whether accept4 is declared without a macro... yes
checking whether getaddrinfo is declared without a macro... yes
checking whether freeaddrinfo is declared without a macro... yes
checking whether gai_strerror is declared without a macro... yes
checking whether getnameinfo is declared without a macro... yes
checking for library containing gethostbyname... none required
checking for gethostbyname... yes
checking for library containing getservbyname... none required
checking for getservbyname... yes
checking for library containing inet_ntop... none required
checking whether inet_ntop is declared... yes
checking for IPv4 sockets... yes
checking for IPv6 sockets... yes
checking for getopt.h... (cached) yes
checking for getopt_long_only... yes
checking whether getopt is POSIX compatible... yes
checking for working GNU getopt function... yes
checking for working GNU getopt_long function... yes
checking whether getenv is declared... yes
checking for working fcntl.h... yes
checking whether getc_unlocked is declared... yes
checking whether we are using the GNU C Library >= 2.1 or uClibc... yes
checking for wchar_t... yes
checking whether NULL can be used in arbitrary expressions... yes
checking whether imported symbols can be declared weak... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for pthread_kill in -lpthread... yes
checking for multithread API to use... posix
checking whether malloc, realloc, calloc are POSIX compliant... yes
checking for stdlib.h... (cached) yes
checking for GNU libc compatible malloc... yes
checking for unsigned long long int... yes
checking for long long int... yes
checking for mbstate_t... yes
checking for a traditional japanese locale... ja_JP
checking for a transitional chinese locale... zh_CN.GB18030
checking for a french Unicode locale... fr_FR.UTF-8
checking for mmap... yes
checking for MAP_ANONYMOUS... yes
checking whether memchr works... yes
checking whether alarm is declared... yes
checking for inline... inline
checking for ssize_t... yes
checking whether setenv is declared... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking for tsearch... yes
checking whether snprintf returns a byte count as in C99... yes
checking whether snprintf is declared... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking whether stdint.h conforms to C99... yes
checking for strcasestr... yes
checking whether strcasestr works... yes
checking whether strerror(0) succeeds... yes
checking whether ffsl is declared without a macro... yes
checking whether ffsll is declared without a macro... yes
checking whether memmem is declared without a macro... yes
checking whether mempcpy is declared without a macro... yes
checking whether memrchr is declared without a macro... yes
checking whether rawmemchr is declared without a macro... yes
checking whether stpcpy is declared without a macro... yes
checking whether stpncpy is declared without a macro... yes
checking whether strchrnul is declared without a macro... yes
checking whether strdup is declared without a macro... yes
checking whether strncat is declared without a macro... yes
checking whether strndup is declared without a macro... yes
checking whether strnlen is declared without a macro... yes
checking whether strpbrk is declared without a macro... yes
checking whether strsep is declared without a macro... yes
checking whether strcasestr is declared without a macro... yes
checking whether strtok_r is declared without a macro... yes
checking whether strerror_r is declared without a macro... yes
checking whether strsignal is declared without a macro... yes
checking whether strverscmp is declared without a macro... yes
checking whether ffs is declared without a macro... yes
checking whether strcasecmp is declared without a macro... yes
checking whether strncasecmp is declared without a macro... yes
checking whether strndup is declared... (cached) yes
checking whether strnlen is declared... (cached) yes
checking for mode_t... yes
checking for struct timespec in <time.h>... yes
checking whether unsetenv is declared... yes
checking for wint_t... yes
checking for intmax_t... yes
checking where to find the exponent in a 'double'... word 1 bit 20
checking for snprintf... (cached) yes
checking for strnlen... yes
checking for wcslen... yes
checking for wcsnlen... yes
checking for mbrtowc... (cached) yes
checking for wcrtomb... (cached) yes
checking whether _snprintf is declared... no
checking whether vsnprintf is declared... yes
checking for alloca as a compiler built-in... yes
checking whether inet_ntop is declared without a macro... yes
checking whether inet_pton is declared without a macro... yes
checking whether btowc(0) is correct... yes
checking whether btowc(EOF) is correct... yes
checking whether // is distinct from /... (cached) no
checking for error_at_line... (cached) yes
checking whether conversion from 'int' to 'long double' works... yes
checking whether floorf is declared... yes
checking for sys/mount.h... yes
configure: checking how to get file system space usage
checking for statvfs function (SVR4)... yes
checking whether to use statvfs64... no
checking for two-argument statfs with statfs.f_frsize member... yes
checking dustat.h usability... no
checking dustat.h presence... no
checking for dustat.h... no
checking sys/fs/s5param.h usability... no
checking sys/fs/s5param.h presence... no
checking for sys/fs/s5param.h... no
checking sys/filsys.h usability... no
checking sys/filsys.h presence... no
checking for sys/filsys.h... no
checking sys/statfs.h usability... yes
checking sys/statfs.h presence... yes
checking for sys/statfs.h... yes
checking for statfs that truncates block counts... no
configure: checking how to do getaddrinfo, freeaddrinfo and getnameinfo
checking for library containing getaddrinfo... none required
checking for getaddrinfo... yes
checking whether gai_strerror is declared... (cached) yes
checking whether gai_strerrorA is declared... no
checking for gai_strerror with POSIX signature... yes
checking for struct sockaddr.sa_len... no
checking whether getaddrinfo is declared... (cached) yes
checking whether freeaddrinfo is declared... (cached) yes
checking whether getnameinfo is declared... (cached) yes
checking for struct addrinfo... yes
checking for gethostname... yes
checking for HOST_NAME_MAX... yes
checking for getloadavg... yes
checking sys/loadavg.h usability... no
checking sys/loadavg.h presence... no
checking for sys/loadavg.h... no
checking whether getloadavg is declared... yes
checking for library containing gethostbyname... (cached) none required
checking for gethostbyname... (cached) yes
checking for library containing inet_ntop... (cached) none required
checking whether inet_ntop is declared... (cached) yes
checking whether langinfo.h defines CODESET... yes
checking whether langinfo.h defines T_FMT_AMPM... yes
checking whether langinfo.h defines ERA... yes
checking whether langinfo.h defines YESEXPR... yes
checking whether nl_langinfo is declared without a macro... yes
checking whether locale.h conforms to POSIX:2001... yes
checking whether locale.h defines locale_t... yes
checking whether struct lconv is properly defined... yes
checking whether setlocale is declared without a macro... yes
checking whether duplocale is declared without a macro... yes
checking for pthread_rwlock_t... yes
checking for GNU libc compatible malloc... (cached) yes
checking whether NAN macro works... yes
checking whether HUGE_VAL works... yes
checking whether acosf is declared without a macro... yes
checking whether acosl is declared without a macro... yes
checking whether asinf is declared without a macro... yes
checking whether asinl is declared without a macro... yes
checking whether atanf is declared without a macro... yes
checking whether atanl is declared without a macro... yes
checking whether cbrt is declared without a macro... yes
checking whether cbrtf is declared without a macro... yes
checking whether cbrtl is declared without a macro... yes
checking whether ceilf is declared without a macro... yes
checking whether ceill is declared without a macro... yes
checking whether copysign is declared without a macro... yes
checking whether copysignf is declared without a macro... yes
checking whether copysignl is declared without a macro... yes
checking whether cosf is declared without a macro... yes
checking whether cosl is declared without a macro... yes
checking whether coshf is declared without a macro... yes
checking whether expf is declared without a macro... yes
checking whether expl is declared without a macro... yes
checking whether exp2 is declared without a macro... yes
checking whether exp2f is declared without a macro... yes
checking whether exp2l is declared without a macro... yes
checking whether expm1 is declared without a macro... yes
checking whether expm1f is declared without a macro... yes
checking whether expm1l is declared without a macro... yes
checking whether fabsf is declared without a macro... yes
checking whether fabsl is declared without a macro... yes
checking whether floorf is declared without a macro... yes
checking whether floorl is declared without a macro... yes
checking whether fma is declared without a macro... yes
checking whether fmaf is declared without a macro... yes
checking whether fmal is declared without a macro... yes
checking whether fmod is declared without a macro... yes
checking whether fmodf is declared without a macro... yes
checking whether fmodl is declared without a macro... yes
checking whether frexpf is declared without a macro... yes
checking whether frexpl is declared without a macro... yes
checking whether hypotf is declared without a macro... yes
checking whether hypotl is declared without a macro... yes
checking whether ilogb is declared without a macro... yes
checking whether ilogbf is declared without a macro... yes
checking whether ilogbl is declared without a macro... yes
checking whether ldexpf is declared without a macro... yes
checking whether ldexpl is declared without a macro... yes
checking whether log is declared without a macro... yes
checking whether logf is declared without a macro... yes
checking whether logl is declared without a macro... yes
checking whether log10 is declared without a macro... yes
checking whether log10f is declared without a macro... yes
checking whether log10l is declared without a macro... yes
checking whether log1p is declared without a macro... yes
checking whether log1pf is declared without a macro... yes
checking whether log1pl is declared without a macro... yes
checking whether log2 is declared without a macro... yes
checking whether log2f is declared without a macro... yes
checking whether log2l is declared without a macro... yes
checking whether logb is declared without a macro... yes
checking whether logbf is declared without a macro... yes
checking whether logbl is declared without a macro... yes
checking whether modf is declared without a macro... yes
checking whether modff is declared without a macro... yes
checking whether modfl is declared without a macro... yes
checking whether powf is declared without a macro... yes
checking whether remainder is declared without a macro... yes
checking whether remainderf is declared without a macro... yes
checking whether remainderl is declared without a macro... yes
checking whether rint is declared without a macro... yes
checking whether rintf is declared without a macro... yes
checking whether rintl is declared without a macro... yes
checking whether round is declared without a macro... yes
checking whether roundf is declared without a macro... yes
checking whether roundl is declared without a macro... yes
checking whether sinf is declared without a macro... yes
checking whether sinl is declared without a macro... yes
checking whether sinhf is declared without a macro... yes
checking whether sqrtf is declared without a macro... yes
checking whether sqrtl is declared without a macro... yes
checking whether tanf is declared without a macro... yes
checking whether tanl is declared without a macro... yes
checking whether tanhf is declared without a macro... yes
checking whether trunc is declared without a macro... yes
checking whether truncf is declared without a macro... yes
checking whether truncl is declared without a macro... yes
checking whether mbrtowc handles incomplete characters... yes
checking whether mbrtowc works as well as mbtowc... yes
checking whether mbrtowc handles a NULL pwc argument... yes
checking whether mbrtowc handles a NULL string argument... yes
checking whether mbrtowc has a correct return value... yes
checking whether mbrtowc returns 0 when parsing a NUL character... yes
checking whether mbrtowc handles incomplete characters... (cached) yes
checking whether mbrtowc works as well as mbtowc... (cached) yes
checking for working mktime... yes
checking for __mktime_internal... no
checking for listmntent... no
checking for getmntinfo... no
checking for sys/ucred.h... no
checking for sys/mount.h... (cached) yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking for sys/fs_types.h... (cached) no
checking for struct fsstat.f_fstypename... no
checking for library containing getmntent... none required
checking for getmntent... yes
checking for listmntent of Cray/Unicos-9... no
checking for mntctl function and struct vmount... no
checking for one-argument getmntent function... yes
checking sys/mntent.h usability... no
checking sys/mntent.h presence... no
checking for sys/mntent.h... no
checking for struct statfs.f_fstypename... no
checking whether getaddrinfo is declared without a macro... (cached) yes
checking whether freeaddrinfo is declared without a macro... (cached) yes
checking whether gai_strerror is declared without a macro... (cached) yes
checking whether getnameinfo is declared without a macro... (cached) yes
checking whether <netinet/in.h> is self-contained... yes
checking whether YESEXPR works... yes
checking for working re_compile_pattern... yes
checking for library containing getservbyname... (cached) none required
checking for getservbyname... (cached) yes
checking whether setenv validates arguments... yes
checking for SIZE_MAX... yes
checking whether snprintf respects a size of 1... yes
checking whether printf supports POSIX/XSI format strings with positions... yes
checking for library containing setsockopt... none needed
checking for socklen_t... yes
checking for ssize_t... (cached) yes
checking for working stdalign.h... yes
checking whether NULL can be used in arbitrary expressions... (cached) yes
checking whether dprintf is declared without a macro... yes
checking whether fpurge is declared without a macro... no
checking whether fseeko is declared without a macro... yes
checking whether ftello is declared without a macro... yes
checking whether getdelim is declared without a macro... yes
checking whether getline is declared without a macro... yes
checking whether gets is declared without a macro... no
checking whether pclose is declared without a macro... yes
checking whether popen is declared without a macro... yes
checking whether renameat is declared without a macro... yes
checking whether snprintf is declared without a macro... yes
checking whether tmpfile is declared without a macro... yes
checking whether vdprintf is declared without a macro... yes
checking whether vsnprintf is declared without a macro... yes
checking whether _Exit is declared without a macro... yes
checking whether atoll is declared without a macro... yes
checking whether canonicalize_file_name is declared without a macro... yes
checking whether getloadavg is declared without a macro... yes
checking whether getsubopt is declared without a macro... yes
checking whether grantpt is declared without a macro... yes
checking whether initstate is declared without a macro... yes
checking whether initstate_r is declared without a macro... yes
checking whether mkdtemp is declared without a macro... yes
checking whether mkostemp is declared without a macro... yes
checking whether mkostemps is declared without a macro... yes
checking whether mkstemp is declared without a macro... yes
checking whether mkstemps is declared without a macro... yes
checking whether posix_openpt is declared without a macro... yes
checking whether ptsname is declared without a macro... yes
checking whether ptsname_r is declared without a macro... yes
checking whether random is declared without a macro... yes
checking whether random_r is declared without a macro... yes
checking whether realpath is declared without a macro... yes
checking whether rpmatch is declared without a macro... yes
checking whether secure_getenv is declared without a macro... yes
checking whether setenv is declared without a macro... yes
checking whether setstate is declared without a macro... yes
checking whether setstate_r is declared without a macro... yes
checking whether srandom is declared without a macro... yes
checking whether srandom_r is declared without a macro... yes
checking whether strtod is declared without a macro... yes
checking whether strtoll is declared without a macro... yes
checking whether strtoull is declared without a macro... yes
checking whether unlockpt is declared without a macro... yes
checking whether unsetenv is declared without a macro... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking whether strncasecmp is declared... (cached) yes
checking whether strcasestr works in linear time... no
checking for strcasestr... (cached) yes
checking whether strcasestr works... (cached) yes
checking for working strerror function... yes
checking for working strndup... yes
checking for working strnlen... yes
checking for strsep... yes
checking whether strstr works... yes
checking whether <sys/socket.h> is self-contained... (cached) yes
checking for shutdown... (cached) yes
checking whether <sys/socket.h> defines the SHUT_* macros... (cached) yes
checking for struct sockaddr_storage... (cached) yes
checking for sa_family_t... (cached) yes
checking for struct sockaddr_storage.ss_family... (cached) yes
checking whether socket is declared without a macro... (cached) yes
checking whether connect is declared without a macro... (cached) yes
checking whether accept is declared without a macro... (cached) yes
checking whether bind is declared without a macro... (cached) yes
checking whether getpeername is declared without a macro... (cached) yes
checking whether getsockname is declared without a macro... (cached) yes
checking whether getsockopt is declared without a macro... (cached) yes
checking whether listen is declared without a macro... (cached) yes
checking whether recv is declared without a macro... (cached) yes
checking whether send is declared without a macro... (cached) yes
checking whether recvfrom is declared without a macro... (cached) yes
checking whether sendto is declared without a macro... (cached) yes
checking whether setsockopt is declared without a macro... (cached) yes
checking whether shutdown is declared without a macro... (cached) yes
checking whether accept4 is declared without a macro... (cached) yes
checking whether localtime_r is declared... yes
checking whether localtime_r is compatible with its POSIX signature... yes
checking whether chdir is declared without a macro... yes
checking whether chown is declared without a macro... yes
checking whether dup is declared without a macro... yes
checking whether dup2 is declared without a macro... yes
checking whether dup3 is declared without a macro... yes
checking whether environ is declared without a macro... yes
checking whether euidaccess is declared without a macro... yes
checking whether faccessat is declared without a macro... yes
checking whether fchdir is declared without a macro... yes
checking whether fchownat is declared without a macro... yes
checking whether fdatasync is declared without a macro... yes
checking whether fsync is declared without a macro... yes
checking whether ftruncate is declared without a macro... yes
checking whether getcwd is declared without a macro... yes
checking whether getdomainname is declared without a macro... yes
checking whether getdtablesize is declared without a macro... yes
checking whether getgroups is declared without a macro... yes
checking whether gethostname is declared without a macro... yes
checking whether getlogin is declared without a macro... yes
checking whether getlogin_r is declared without a macro... yes
checking whether getpagesize is declared without a macro... yes
checking whether getusershell is declared without a macro... yes
checking whether setusershell is declared without a macro... yes
checking whether endusershell is declared without a macro... yes
checking whether group_member is declared without a macro... yes
checking whether isatty is declared without a macro... yes
checking whether lchown is declared without a macro... yes
checking whether link is declared without a macro... yes
checking whether linkat is declared without a macro... yes
checking whether lseek is declared without a macro... yes
checking whether pipe is declared without a macro... yes
checking whether pipe2 is declared without a macro... yes
checking whether pread is declared without a macro... yes
checking whether pwrite is declared without a macro... yes
checking whether readlink is declared without a macro... yes
checking whether readlinkat is declared without a macro... yes
checking whether rmdir is declared without a macro... yes
checking whether sethostname is declared without a macro... yes
checking whether sleep is declared without a macro... yes
checking whether symlink is declared without a macro... yes
checking whether symlinkat is declared without a macro... yes
checking whether ttyname_r is declared without a macro... yes
checking whether unlink is declared without a macro... yes
checking whether unlinkat is declared without a macro... yes
checking whether usleep is declared without a macro... yes
checking for unsetenv... yes
checking for unsetenv() return type... int
checking whether unsetenv obeys POSIX... yes
checking for ptrdiff_t... yes
checking for vasprintf... yes
checking for vsnprintf... yes
checking whether snprintf respects a size of 1... (cached) yes
checking whether printf supports POSIX/XSI format strings with positions... (cached) yes
checking whether btowc is declared without a macro... yes
checking whether wctob is declared without a macro... yes
checking whether mbsinit is declared without a macro... yes
checking whether mbrtowc is declared without a macro... yes
checking whether mbrlen is declared without a macro... yes
checking whether mbsrtowcs is declared without a macro... yes
checking whether mbsnrtowcs is declared without a macro... yes
checking whether wcrtomb is declared without a macro... yes
checking whether wcsrtombs is declared without a macro... yes
checking whether wcsnrtombs is declared without a macro... yes
checking whether wcwidth is declared without a macro... yes
checking whether wmemchr is declared without a macro... yes
checking whether wmemcmp is declared without a macro... yes
checking whether wmemcpy is declared without a macro... yes
checking whether wmemmove is declared without a macro... yes
checking whether wmemset is declared without a macro... yes
checking whether wcslen is declared without a macro... yes
checking whether wcsnlen is declared without a macro... yes
checking whether wcscpy is declared without a macro... yes
checking whether wcpcpy is declared without a macro... yes
checking whether wcsncpy is declared without a macro... yes
checking whether wcpncpy is declared without a macro... yes
checking whether wcscat is declared without a macro... yes
checking whether wcsncat is declared without a macro... yes
checking whether wcscmp is declared without a macro... yes
checking whether wcsncmp is declared without a macro... yes
checking whether wcscasecmp is declared without a macro... yes
checking whether wcsncasecmp is declared without a macro... yes
checking whether wcscoll is declared without a macro... yes
checking whether wcsxfrm is declared without a macro... yes
checking whether wcsdup is declared without a macro... yes
checking whether wcschr is declared without a macro... yes
checking whether wcsrchr is declared without a macro... yes
checking whether wcscspn is declared without a macro... yes
checking whether wcsspn is declared without a macro... yes
checking whether wcspbrk is declared without a macro... yes
checking whether wcsstr is declared without a macro... yes
checking whether wcstok is declared without a macro... yes
checking whether wcswidth is declared without a macro... yes
checking whether wcrtomb return value is correct... yes
checking whether iswcntrl works... yes
checking for towlower... yes
checking for wctype_t... yes
checking for wctrans_t... yes
checking whether wctype is declared without a macro... yes
checking whether iswctype is declared without a macro... yes
checking whether wctrans is declared without a macro... yes
checking whether towctrans is declared without a macro... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating gl/Makefile
config.status: creating nagios-plugins.spec
config.status: creating tools/build_perl_modules
config.status: creating Makefile
config.status: creating tap/Makefile
config.status: creating lib/Makefile
config.status: creating plugins/Makefile
config.status: creating lib/tests/Makefile
config.status: creating plugins-root/Makefile
config.status: creating plugins-scripts/Makefile
config.status: creating plugins-scripts/utils.pm
config.status: creating plugins-scripts/utils.sh
config.status: creating perlmods/Makefile
config.status: creating test.pl
config.status: creating pkg/solaris/pkginfo
config.status: creating po/Makefile.in
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
--with-apt-get-command:
--with-ping6-command: /sbin/ping6 -n -U -w %d -c %d %s
--with-ping-command: /bin/ping -n -U -w %d -c %d %s
--with-ipv6: yes
--with-mysql: no
--with-openssl: yes
--with-gnutls: no
--enable-extra-opts: yes
--with-perl: /bin/perl
--enable-perl-modules: no
--with-cgiurl: /nagios/cgi-bin
--with-trusted-path: /usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
--enable-libtap: no
pcouas
Post by pcouas »
THIRD
[ec2-user@cprod nagios-plugins-release-2.1.3]$ sudo make
make all-recursive
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3'
Making all in gl
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/gl'
rm -f alloca.h-t alloca.h && \
{ echo '/* DO NOT EDIT! GENERATED AUTOMATICALLY! */'; \
cat ./alloca.in.h; \
} > alloca.h-t && \
mv -f alloca.h-t alloca.h
/bin/mkdir -p arpa
rm -f arpa/inet.h-t arpa/inet.h && \
sed -e 's|@''GUARD_PREFIX''@|GL|g' \
-e 's|@''INCLUDE_NEXT''@|include_next|g' \
-e 's|@''PRAGMA_SYSTEM_HEADER''@|#pragma GCC system_header|g' \
-e 's|@''PRAGMA_COLUMNS''@||g' \
-e 's|@''HAVE_FEATURES_H''@|1|g' \
-e 's|@''NEXT_ARPA_INET_H''@|<arpa/inet.h>|g' \
-e 's|@''HAVE_ARPA_INET_H''@|1|g' \
-e 's/@''GNULIB_INET_NTOP''@/1/g' \
-e 's/@''GNULIB_INET_PTON''@/0/g' \
-e 's|@''HAVE_DECL_INET_NTOP''@|1|g' \
-e 's|@''HAVE_DECL_INET_PTON''@|1|g' \
-e 's|@''REPLACE_INET_NTOP''@|0|g' \
-e 's|@''REPLACE_INET_PTON''@|0|g' \
-e '/definitions of _GL_FUNCDECL_RPL/r c++defs.h' \
-e '/definition of _GL_ARG_NONNULL/r arg-nonnull.h' \
-e '/definition of _GL_WARN_ON_USE/r warn-on-use.h' \
< ./arpa_inet.in.h; \
} > arpa/inet.h-t && \
mv arpa/inet.h-t arpa/inet.h
rm -f configmake.h-t && \
echo '#define PREFIX "/usr/local/nagios"'; \
echo '#define EXEC_PREFIX "/usr/local/nagios"'; \
echo '#define BINDIR "/usr/local/nagios/bin"'; \
echo '#define SBINDIR "/usr/local/nagios/sbin"'; \
echo '#define LIBEXECDIR "/usr/local/nagios/libexec"'; \
echo '#define DATAROOTDIR "/usr/local/nagios/share"'; \
echo '#define DATADIR "/usr/local/nagios/share"'; \
echo '#define SYSCONFDIR "/usr/local/nagios/etc"'; \
echo '#define SHAREDSTATEDIR "/usr/local/nagios/com"'; \
echo '#define LOCALSTATEDIR "/usr/local/nagios/var"'; \
echo '#define INCLUDEDIR "/usr/local/nagios/include"'; \
echo '#define OLDINCLUDEDIR "/usr/include"'; \
echo '#define DOCDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define INFODIR "/usr/local/nagios/share/info"'; \
echo '#define HTMLDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define DVIDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define PDFDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define PSDIR "/usr/local/nagios/share/doc/nagios-plugins"'; \
echo '#define LIBDIR "/usr/local/nagios/lib"'; \
echo '#define LISPDIR "/usr/local/nagios/share/emacs/site-lisp"'; \
echo '#define LOCALEDIR "/usr/local/nagios/share/locale"'; \
echo '#define MANDIR "/usr/local/nagios/share/man"'; \
echo '#define MANEXT ""'; \
echo '#define PKGDATADIR "/usr/local/nagios/share/nagios-plugins"'; \
echo '#define PKGINCLUDEDIR "/usr/local/nagios/include/nagios-plugins"'; \
echo '#define PKGLIBDIR "/usr/local/nagios/lib/nagios-plugins"'; \
echo '#define PKGLIBEXECDIR "/usr/local/nagios/libexec/nagios-plugins"'; \
} | sed '/""/d' > configmake.h-t && \
mv -f configmake.h-t configmake.h
rm -f langinfo.h-t langinfo.h && \
-e 's|@''HAVE_LANGINFO_H''@|1|g' \
-e 's|@''NEXT_LANGINFO_H''@|<langinfo.h>|g' \
-e 's/@''GNULIB_NL_LANGINFO''@/1/g' \
-e 's|@''HAVE_LANGINFO_CODESET''@|1|g' \
-e 's|@''HAVE_LANGINFO_T_FMT_AMPM''@|1|g' \
-e 's|@''HAVE_LANGINFO_ERA''@|1|g' \
-e 's|@''HAVE_LANGINFO_YESEXPR''@|1|g' \
-e 's|@''HAVE_NL_LANGINFO''@|1|g' \
-e 's|@''REPLACE_NL_LANGINFO''@|0|g' \
< ./langinfo.in.h; \
} > langinfo.h-t && \
mv langinfo.h-t langinfo.h
rm -f locale.h-t locale.h && \
{ echo '/* DO NOT EDIT! GENERATED AUTOMATICALLY! */' && \
-e 's|@''NEXT_LOCALE_H''@|<locale.h>|g' \
-e 's/@''GNULIB_LOCALECONV''@/1/g' \
-e 's/@''GNULIB_SETLOCALE''@/0/g' \
-e 's/@''GNULIB_DUPLOCALE''@/0/g' \
-e 's|@''HAVE_DUPLOCALE''@|1|g' \
-e 's|@''HAVE_XLOCALE_H''@|1|g' \
-e 's|@''REPLACE_LOCALECONV''@|0|g' \
-e 's|@''REPLACE_SETLOCALE''@|0|g' \
-e 's|@''REPLACE_DUPLOCALE''@|0|g' \
-e 's|@''REPLACE_STRUCT_LCONV''@|0|g' \
< ./locale.in.h; \
} > locale.h-t && \
mv locale.h-t locale.h
rm -f math.h-t math.h && \
-e 's|@''INCLUDE_NEXT_AS_FIRST_DIRECTIVE''@|include_next|g' \
-e 's|@''NEXT_AS_FIRST_DIRECTIVE_MATH_H''@|<math.h>|g' \
-e 's/@''GNULIB_ACOSF''@/0/g' \
-e 's/@''GNULIB_ACOSL''@/0/g' \
-e 's/@''GNULIB_ASINF''@/0/g' \
-e 's/@''GNULIB_ASINL''@/0/g' \
-e 's/@''GNULIB_ATANF''@/0/g' \
-e 's/@''GNULIB_ATANL''@/0/g' \
-e 's/@''GNULIB_ATAN2F''@/0/g' \
-e 's/@''GNULIB_CBRT''@/0/g' \
-e 's/@''GNULIB_CBRTF''@/0/g' \
-e 's/@''GNULIB_CBRTL''@/0/g' \
-e 's/@''GNULIB_CEIL''@/0/g' \
-e 's/@''GNULIB_CEILF''@/0/g' \
-e 's/@''GNULIB_CEILL''@/0/g' \
-e 's/@''GNULIB_COPYSIGN''@/0/g' \
-e 's/@''GNULIB_COPYSIGNF''@/0/g' \
-e 's/@''GNULIB_COPYSIGNL''@/0/g' \
-e 's/@''GNULIB_COSF''@/0/g' \
-e 's/@''GNULIB_COSL''@/0/g' \
-e 's/@''GNULIB_COSHF''@/0/g' \
-e 's/@''GNULIB_EXPF''@/0/g' \
-e 's/@''GNULIB_EXPL''@/0/g' \
-e 's/@''GNULIB_EXP2''@/0/g' \
-e 's/@''GNULIB_EXP2F''@/0/g' \
-e 's/@''GNULIB_EXP2L''@/0/g' \
-e 's/@''GNULIB_EXPM1''@/0/g' \
-e 's/@''GNULIB_EXPM1F''@/0/g' \
-e 's/@''GNULIB_EXPM1L''@/0/g' \
-e 's/@''GNULIB_FABSF''@/0/g' \
-e 's/@''GNULIB_FABSL''@/0/g' \
-e 's/@''GNULIB_FLOOR''@/0/g' \
-e 's/@''GNULIB_FLOORF''@/1/g' \
-e 's/@''GNULIB_FLOORL''@/0/g' \
-e 's/@''GNULIB_FMA''@/0/g' \
-e 's/@''GNULIB_FMAF''@/0/g' \
-e 's/@''GNULIB_FMAL''@/0/g' \
-e 's/@''GNULIB_FMOD''@/0/g' \
-e 's/@''GNULIB_FMODF''@/0/g' \
-e 's/@''GNULIB_FMODL''@/0/g' \
-e 's/@''GNULIB_FREXPF''@/0/g' \
-e 's/@''GNULIB_FREXP''@/0/g' \
-e 's/@''GNULIB_FREXPL''@/0/g' \
-e 's/@''GNULIB_HYPOT''@/0/g' \
-e 's/@''GNULIB_HYPOTF''@/0/g' \
-e 's/@''GNULIB_HYPOTL''@/0/g' \
< ./math.in.h | \
sed -e 's/@''GNULIB_ILOGB''@/0/g' \
-e 's/@''GNULIB_ILOGBF''@/0/g' \
-e 's/@''GNULIB_ILOGBL''@/0/g' \
-e 's/@''GNULIB_ISFINITE''@/0/g' \
-e 's/@''GNULIB_ISINF''@/0/g' \
-e 's/@''GNULIB_ISNAN''@/0/g' \
-e 's/@''GNULIB_ISNANF''@/0/g' \
-e 's/@''GNULIB_ISNAND''@/0/g' \
-e 's/@''GNULIB_ISNANL''@/0/g' \
-e 's/@''GNULIB_LDEXPF''@/0/g' \
-e 's/@''GNULIB_LDEXPL''@/0/g' \
-e 's/@''GNULIB_LOG''@/0/g' \
-e 's/@''GNULIB_LOGF''@/0/g' \
-e 's/@''GNULIB_LOGL''@/0/g' \
-e 's/@''GNULIB_LOG10''@/0/g' \
-e 's/@''GNULIB_LOG10F''@/0/g' \
-e 's/@''GNULIB_LOG10L''@/0/g' \
-e 's/@''GNULIB_LOG1P''@/0/g' \
-e 's/@''GNULIB_LOG1PF''@/0/g' \
-e 's/@''GNULIB_LOG1PL''@/0/g' \
-e 's/@''GNULIB_LOG2''@/0/g' \
-e 's/@''GNULIB_LOG2F''@/0/g' \
-e 's/@''GNULIB_LOG2L''@/0/g' \
-e 's/@''GNULIB_LOGB''@/0/g' \
-e 's/@''GNULIB_LOGBF''@/0/g' \
-e 's/@''GNULIB_LOGBL''@/0/g' \
-e 's/@''GNULIB_MODF''@/0/g' \
-e 's/@''GNULIB_MODFF''@/0/g' \
-e 's/@''GNULIB_MODFL''@/0/g' \
-e 's/@''GNULIB_POWF''@/0/g' \
-e 's/@''GNULIB_REMAINDER''@/0/g' \
-e 's/@''GNULIB_REMAINDERF''@/0/g' \
-e 's/@''GNULIB_REMAINDERL''@/0/g' \
-e 's/@''GNULIB_RINT''@/0/g' \
-e 's/@''GNULIB_RINTF''@/0/g' \
-e 's/@''GNULIB_RINTL''@/0/g' \
-e 's/@''GNULIB_ROUND''@/0/g' \
-e 's/@''GNULIB_ROUNDF''@/0/g' \
-e 's/@''GNULIB_ROUNDL''@/0/g' \
-e 's/@''GNULIB_SIGNBIT''@/0/g' \
-e 's/@''GNULIB_SINF''@/0/g' \
-e 's/@''GNULIB_SINL''@/0/g' \
-e 's/@''GNULIB_SINHF''@/0/g' \
-e 's/@''GNULIB_SQRTF''@/0/g' \
-e 's/@''GNULIB_SQRTL''@/0/g' \
-e 's/@''GNULIB_TANF''@/0/g' \
-e 's/@''GNULIB_TANL''@/0/g' \
-e 's/@''GNULIB_TANHF''@/0/g' \
-e 's/@''GNULIB_TRUNC''@/0/g' \
-e 's/@''GNULIB_TRUNCF''@/0/g' \
-e 's/@''GNULIB_TRUNCL''@/0/g' \
sed -e 's|@''HAVE_ACOSF''@|1|g' \
-e 's|@''HAVE_ACOSL''@|1|g' \
-e 's|@''HAVE_ASINF''@|1|g' \
-e 's|@''HAVE_ASINL''@|1|g' \
-e 's|@''HAVE_ATANF''@|1|g' \
-e 's|@''HAVE_ATANL''@|1|g' \
-e 's|@''HAVE_ATAN2F''@|1|g' \
-e 's|@''HAVE_CBRT''@|1|g' \
-e 's|@''HAVE_CBRTF''@|1|g' \
-e 's|@''HAVE_CBRTL''@|1|g' \
-e 's|@''HAVE_COPYSIGN''@|1|g' \
-e 's|@''HAVE_COPYSIGNL''@|1|g' \
-e 's|@''HAVE_COSF''@|1|g' \
-e 's|@''HAVE_COSL''@|1|g' \
-e 's|@''HAVE_COSHF''@|1|g' \
-e 's|@''HAVE_EXPF''@|1|g' \
-e 's|@''HAVE_EXPL''@|1|g' \
-e 's|@''HAVE_EXPM1''@|1|g' \
-e 's|@''HAVE_EXPM1F''@|1|g' \
-e 's|@''HAVE_FABSF''@|1|g' \
-e 's|@''HAVE_FABSL''@|1|g' \
-e 's|@''HAVE_FMA''@|1|g' \
-e 's|@''HAVE_FMAF''@|1|g' \
-e 's|@''HAVE_FMAL''@|1|g' \
-e 's|@''HAVE_FMODF''@|1|g' \
-e 's|@''HAVE_FMODL''@|1|g' \
-e 's|@''HAVE_FREXPF''@|1|g' \
-e 's|@''HAVE_HYPOTF''@|1|g' \
-e 's|@''HAVE_HYPOTL''@|1|g' \
-e 's|@''HAVE_ILOGB''@|1|g' \
-e 's|@''HAVE_ILOGBF''@|1|g' \
-e 's|@''HAVE_ILOGBL''@|1|g' \
-e 's|@''HAVE_ISNANF''@|1|g' \
-e 's|@''HAVE_ISNAND''@|1|g' \
-e 's|@''HAVE_ISNANL''@|1|g' \
-e 's|@''HAVE_LDEXPF''@|1|g' \
-e 's|@''HAVE_LOGF''@|1|g' \
-e 's|@''HAVE_LOGL''@|1|g' \
-e 's|@''HAVE_LOG10F''@|1|g' \
-e 's|@''HAVE_LOG10L''@|1|g' \
-e 's|@''HAVE_LOG1P''@|1|g' \
-e 's|@''HAVE_LOG1PF''@|1|g' \
-e 's|@''HAVE_LOG1PL''@|1|g' \
-e 's|@''HAVE_LOGBF''@|1|g' \
-e 's|@''HAVE_LOGBL''@|1|g' \
-e 's|@''HAVE_MODFF''@|1|g' \
-e 's|@''HAVE_MODFL''@|1|g' \
-e 's|@''HAVE_POWF''@|1|g' \
-e 's|@''HAVE_REMAINDER''@|1|g' \
-e 's|@''HAVE_REMAINDERF''@|1|g' \
-e 's|@''HAVE_RINT''@|1|g' \
-e 's|@''HAVE_RINTL''@|1|g' \
-e 's|@''HAVE_SINF''@|1|g' \
-e 's|@''HAVE_SINL''@|1|g' \
-e 's|@''HAVE_SINHF''@|1|g' \
-e 's|@''HAVE_SQRTF''@|1|g' \
-e 's|@''HAVE_SQRTL''@|1|g' \
-e 's|@''HAVE_TANF''@|1|g' \
-e 's|@''HAVE_TANL''@|1|g' \
-e 's|@''HAVE_TANHF''@|1|g' \
-e 's|@''HAVE_DECL_ACOSL''@|1|g' \
-e 's|@''HAVE_DECL_ASINL''@|1|g' \
-e 's|@''HAVE_DECL_ATANL''@|1|g' \
-e 's|@''HAVE_DECL_CBRTF''@|1|g' \
-e 's|@''HAVE_DECL_CBRTL''@|1|g' \
-e 's|@''HAVE_DECL_CEILF''@|1|g' \
-e 's|@''HAVE_DECL_CEILL''@|1|g' \
-e 's|@''HAVE_DECL_COPYSIGNF''@|1|g' \
-e 's|@''HAVE_DECL_COSL''@|1|g' \
-e 's|@''HAVE_DECL_EXPL''@|1|g' \
-e 's|@''HAVE_DECL_EXP2''@|1|g' \
-e 's|@''HAVE_DECL_EXP2F''@|1|g' \
-e 's|@''HAVE_DECL_EXP2L''@|1|g' \
-e 's|@''HAVE_DECL_EXPM1L''@|1|g' \
-e 's|@''HAVE_DECL_FLOORF''@|1|g' \
-e 's|@''HAVE_DECL_FLOORL''@|1|g' \
-e 's|@''HAVE_DECL_FREXPL''@|1|g' \
-e 's|@''HAVE_DECL_LDEXPL''@|1|g' \
-e 's|@''HAVE_DECL_LOGL''@|1|g' \
-e 's|@''HAVE_DECL_LOG10L''@|1|g' \
-e 's|@''HAVE_DECL_LOG2''@|1|g' \
-e 's|@''HAVE_DECL_LOG2F''@|1|g' \
-e 's|@''HAVE_DECL_LOG2L''@|1|g' \
-e 's|@''HAVE_DECL_LOGB''@|1|g' \
-e 's|@''HAVE_DECL_REMAINDER''@|1|g' \
-e 's|@''HAVE_DECL_REMAINDERL''@|1|g' \
-e 's|@''HAVE_DECL_RINTF''@|1|g' \
-e 's|@''HAVE_DECL_ROUND''@|1|g' \
-e 's|@''HAVE_DECL_ROUNDF''@|1|g' \
-e 's|@''HAVE_DECL_ROUNDL''@|1|g' \
-e 's|@''HAVE_DECL_SINL''@|1|g' \
-e 's|@''HAVE_DECL_SQRTL''@|1|g' \
-e 's|@''HAVE_DECL_TANL''@|1|g' \
-e 's|@''HAVE_DECL_TRUNC''@|1|g' \
-e 's|@''HAVE_DECL_TRUNCF''@|1|g' \
-e 's|@''HAVE_DECL_TRUNCL''@|1|g' \
sed -e 's|@''REPLACE_CBRTF''@|0|g' \
-e 's|@''REPLACE_CBRTL''@|0|g' \
-e 's|@''REPLACE_CEIL''@|0|g' \
-e 's|@''REPLACE_CEILF''@|0|g' \
-e 's|@''REPLACE_CEILL''@|0|g' \
-e 's|@''REPLACE_EXPM1''@|0|g' \
-e 's|@''REPLACE_EXPM1F''@|0|g' \
-e 's|@''REPLACE_EXP2''@|0|g' \
-e 's|@''REPLACE_EXP2L''@|0|g' \
-e 's|@''REPLACE_FABSL''@|0|g' \
-e 's|@''REPLACE_FLOOR''@|0|g' \
-e 's|@''REPLACE_FLOORF''@|0|g' \
-e 's|@''REPLACE_FLOORL''@|0|g' \
-e 's|@''REPLACE_FMA''@|0|g' \
-e 's|@''REPLACE_FMAF''@|0|g' \
-e 's|@''REPLACE_FMAL''@|0|g' \
-e 's|@''REPLACE_FMOD''@|0|g' \
-e 's|@''REPLACE_FMODF''@|0|g' \
-e 's|@''REPLACE_FMODL''@|0|g' \
-e 's|@''REPLACE_FREXPF''@|0|g' \
-e 's|@''REPLACE_FREXP''@|0|g' \
-e 's|@''REPLACE_FREXPL''@|0|g' \
-e 's|@''REPLACE_HUGE_VAL''@|0|g' \
-e 's|@''REPLACE_HYPOT''@|0|g' \
-e 's|@''REPLACE_HYPOTF''@|0|g' \
-e 's|@''REPLACE_HYPOTL''@|0|g' \
-e 's|@''REPLACE_ILOGB''@|0|g' \
-e 's|@''REPLACE_ILOGBF''@|0|g' \
-e 's|@''REPLACE_ISFINITE''@|0|g' \
-e 's|@''REPLACE_ISINF''@|0|g' \
-e 's|@''REPLACE_ISNAN''@|0|g' \
-e 's|@''REPLACE_ITOLD''@|0|g' \
-e 's|@''REPLACE_LDEXPL''@|0|g' \
-e 's|@''REPLACE_LOG''@|0|g' \
-e 's|@''REPLACE_LOGF''@|0|g' \
-e 's|@''REPLACE_LOGL''@|0|g' \
-e 's|@''REPLACE_LOG10''@|0|g' \
-e 's|@''REPLACE_LOG10F''@|0|g' \
-e 's|@''REPLACE_LOG10L''@|0|g' \
-e 's|@''REPLACE_LOG1P''@|0|g' \
-e 's|@''REPLACE_LOG1PF''@|0|g' \
-e 's|@''REPLACE_LOG1PL''@|0|g' \
-e 's|@''REPLACE_LOG2''@|0|g' \
-e 's|@''REPLACE_LOG2F''@|0|g' \
-e 's|@''REPLACE_LOG2L''@|0|g' \
-e 's|@''REPLACE_LOGB''@|0|g' \
-e 's|@''REPLACE_LOGBF''@|0|g' \
-e 's|@''REPLACE_LOGBL''@|0|g' \
-e 's|@''REPLACE_MODF''@|0|g' \
-e 's|@''REPLACE_MODFF''@|0|g' \
-e 's|@''REPLACE_MODFL''@|0|g' \
-e 's|@''REPLACE_NAN''@|0|g' \
-e 's|@''REPLACE_REMAINDER''@|0|g' \
-e 's|@''REPLACE_REMAINDERF''@|0|g' \
-e 's|@''REPLACE_REMAINDERL''@|0|g' \
-e 's|@''REPLACE_ROUND''@|0|g' \
-e 's|@''REPLACE_ROUNDF''@|0|g' \
-e 's|@''REPLACE_ROUNDL''@|0|g' \
-e 's|@''REPLACE_SIGNBIT''@|0|g' \
-e 's|@''REPLACE_SIGNBIT_USING_GCC''@|0|g' \
-e 's|@''REPLACE_SQRTL''@|0|g' \
-e 's|@''REPLACE_TRUNC''@|0|g' \
-e 's|@''REPLACE_TRUNCF''@|0|g' \
-e 's|@''REPLACE_TRUNCL''@|0|g' \
-e '/definition of _GL_WARN_ON_USE/r warn-on-use.h'; \
} > math.h-t && \
mv math.h-t math.h
rm -f netdb.h-t netdb.h && \
-e 's|@''NEXT_NETDB_H''@|<netdb.h>|g' \
-e 's|@''HAVE_NETDB_H''@|1|g' \
-e 's/@''GNULIB_GETADDRINFO''@/1/g' \
-e 's|@''HAVE_STRUCT_ADDRINFO''@|1|g' \
-e 's|@''HAVE_DECL_FREEADDRINFO''@|1|g' \
-e 's|@''HAVE_DECL_GAI_STRERROR''@|1|g' \
-e 's|@''HAVE_DECL_GETADDRINFO''@|1|g' \
-e 's|@''HAVE_DECL_GETNAMEINFO''@|1|g' \
-e 's|@''REPLACE_GAI_STRERROR''@|0|g' \
< ./netdb.in.h; \
} > netdb.h-t && \
mv netdb.h-t netdb.h
rm -f stdio.h-t stdio.h && \
-e 's|@''NEXT_STDIO_H''@|<stdio.h>|g' \
-e 's/@''GNULIB_DPRINTF''@/0/g' \
-e 's/@''GNULIB_FCLOSE''@/0/g' \
-e 's/@''GNULIB_FDOPEN''@/0/g' \
-e 's/@''GNULIB_FFLUSH''@/0/g' \
-e 's/@''GNULIB_FGETC''@/1/g' \
-e 's/@''GNULIB_FGETS''@/1/g' \
-e 's/@''GNULIB_FOPEN''@/0/g' \
-e 's/@''GNULIB_FPRINTF''@/1/g' \
-e 's/@''GNULIB_FPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_FPURGE''@/0/g' \
-e 's/@''GNULIB_FPUTC''@/1/g' \
-e 's/@''GNULIB_FPUTS''@/1/g' \
-e 's/@''GNULIB_FREAD''@/1/g' \
-e 's/@''GNULIB_FREOPEN''@/0/g' \
-e 's/@''GNULIB_FSCANF''@/1/g' \
-e 's/@''GNULIB_FSEEK''@/0/g' \
-e 's/@''GNULIB_FSEEKO''@/0/g' \
-e 's/@''GNULIB_FTELL''@/0/g' \
-e 's/@''GNULIB_FTELLO''@/0/g' \
-e 's/@''GNULIB_FWRITE''@/1/g' \
-e 's/@''GNULIB_GETC''@/1/g' \
-e 's/@''GNULIB_GETCHAR''@/1/g' \
-e 's/@''GNULIB_GETDELIM''@/0/g' \
-e 's/@''GNULIB_GETLINE''@/0/g' \
-e 's/@''GNULIB_OBSTACK_PRINTF''@/0/g' \
-e 's/@''GNULIB_OBSTACK_PRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_PCLOSE''@/0/g' \
-e 's/@''GNULIB_PERROR''@/0/g' \
-e 's/@''GNULIB_POPEN''@/0/g' \
-e 's/@''GNULIB_PRINTF''@/1/g' \
-e 's/@''GNULIB_PRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_PUTC''@/1/g' \
-e 's/@''GNULIB_PUTCHAR''@/1/g' \
-e 's/@''GNULIB_PUTS''@/1/g' \
-e 's/@''GNULIB_REMOVE''@/0/g' \
-e 's/@''GNULIB_RENAME''@/0/g' \
-e 's/@''GNULIB_RENAMEAT''@/0/g' \
-e 's/@''GNULIB_SCANF''@/1/g' \
-e 's/@''GNULIB_SNPRINTF''@/1/g' \
-e 's/@''GNULIB_SPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_STDIO_H_NONBLOCKING''@/0/g' \
-e 's/@''GNULIB_STDIO_H_SIGPIPE''@/0/g' \
-e 's/@''GNULIB_TMPFILE''@/0/g' \
-e 's/@''GNULIB_VASPRINTF''@/1/g' \
-e 's/@''GNULIB_VDPRINTF''@/0/g' \
-e 's/@''GNULIB_VFPRINTF''@/1/g' \
-e 's/@''GNULIB_VFPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_VFSCANF''@/0/g' \
-e 's/@''GNULIB_VSCANF''@/0/g' \
-e 's/@''GNULIB_VPRINTF''@/1/g' \
-e 's/@''GNULIB_VPRINTF_POSIX''@/0/g' \
-e 's/@''GNULIB_VSNPRINTF''@/1/g' \
-e 's/@''GNULIB_VSPRINTF_POSIX''@/0/g' \
< ./stdio.in.h | \
sed -e 's|@''HAVE_DECL_FPURGE''@|1|g' \
-e 's|@''HAVE_DECL_FSEEKO''@|1|g' \
-e 's|@''HAVE_DECL_FTELLO''@|1|g' \
-e 's|@''HAVE_DECL_GETDELIM''@|1|g' \
-e 's|@''HAVE_DECL_GETLINE''@|1|g' \
-e 's|@''HAVE_DECL_OBSTACK_PRINTF''@|1|g' \
-e 's|@''HAVE_DECL_SNPRINTF''@|1|g' \
-e 's|@''HAVE_DECL_VSNPRINTF''@|1|g' \
-e 's|@''HAVE_DPRINTF''@|1|g' \
-e 's|@''HAVE_FSEEKO''@|1|g' \
-e 's|@''HAVE_FTELLO''@|1|g' \
-e 's|@''HAVE_PCLOSE''@|1|g' \
-e 's|@''HAVE_POPEN''@|1|g' \
-e 's|@''HAVE_RENAMEAT''@|1|g' \
-e 's|@''HAVE_VASPRINTF''@|1|g' \
-e 's|@''HAVE_VDPRINTF''@|1|g' \
-e 's|@''REPLACE_DPRINTF''@|0|g' \
-e 's|@''REPLACE_FCLOSE''@|0|g' \
-e 's|@''REPLACE_FDOPEN''@|0|g' \
-e 's|@''REPLACE_FFLUSH''@|0|g' \
-e 's|@''REPLACE_FOPEN''@|0|g' \
-e 's|@''REPLACE_FPRINTF''@|0|g' \
-e 's|@''REPLACE_FPURGE''@|0|g' \
-e 's|@''REPLACE_FREOPEN''@|0|g' \
-e 's|@''REPLACE_FSEEK''@|0|g' \
-e 's|@''REPLACE_FSEEKO''@|0|g' \
-e 's|@''REPLACE_FTELL''@|0|g' \
-e 's|@''REPLACE_FTELLO''@|0|g' \
-e 's|@''REPLACE_GETDELIM''@|0|g' \
-e 's|@''REPLACE_GETLINE''@|0|g' \
-e 's|@''REPLACE_OBSTACK_PRINTF''@|0|g' \
-e 's|@''REPLACE_PERROR''@|0|g' \
-e 's|@''REPLACE_POPEN''@|0|g' \
-e 's|@''REPLACE_PRINTF''@|0|g' \
-e 's|@''REPLACE_REMOVE''@|0|g' \
-e 's|@''REPLACE_RENAME''@|0|g' \
-e 's|@''REPLACE_RENAMEAT''@|0|g' \
-e 's|@''REPLACE_SNPRINTF''@|0|g' \
-e 's|@''REPLACE_SPRINTF''@|0|g' \
-e 's|@''REPLACE_STDIO_READ_FUNCS''@|0|g' \
-e 's|@''REPLACE_STDIO_WRITE_FUNCS''@|0|g' \
-e 's|@''REPLACE_TMPFILE''@|0|g' \
-e 's|@''REPLACE_VASPRINTF''@|0|g' \
-e 's|@''REPLACE_VDPRINTF''@|0|g' \
-e 's|@''REPLACE_VFPRINTF''@|0|g' \
-e 's|@''REPLACE_VPRINTF''@|0|g' \
-e 's|@''REPLACE_VSNPRINTF''@|0|g' \
-e 's|@''REPLACE_VSPRINTF''@|0|g' \
-e 's|@''ASM_SYMBOL_PREFIX''@||g' \
} > stdio.h-t && \
mv stdio.h-t stdio.h
pcouas
Re: could not installed nagios client on RHEL7
Post by pcouas »
THIRD2
rm -f stdlib.h-t stdlib.h && \
-e 's|@''NEXT_STDLIB_H''@|<stdlib.h>|g' \
-e 's/@''GNULIB__EXIT''@/0/g' \
-e 's/@''GNULIB_ATOLL''@/0/g' \
-e 's/@''GNULIB_CALLOC_POSIX''@/0/g' \
-e 's/@''GNULIB_CANONICALIZE_FILE_NAME''@/0/g' \
-e 's/@''GNULIB_GETLOADAVG''@/1/g' \
-e 's/@''GNULIB_GETSUBOPT''@/0/g' \
-e 's/@''GNULIB_GRANTPT''@/0/g' \
-e 's/@''GNULIB_MALLOC_POSIX''@/1/g' \
-e 's/@''GNULIB_MBTOWC''@/1/g' \
-e 's/@''GNULIB_MKDTEMP''@/0/g' \
-e 's/@''GNULIB_MKOSTEMP''@/0/g' \
-e 's/@''GNULIB_MKOSTEMPS''@/0/g' \
-e 's/@''GNULIB_MKSTEMP''@/0/g' \
-e 's/@''GNULIB_MKSTEMPS''@/0/g' \
-e 's/@''GNULIB_POSIX_OPENPT''@/0/g' \
-e 's/@''GNULIB_PTSNAME''@/0/g' \
-e 's/@''GNULIB_PTSNAME_R''@/0/g' \
-e 's/@''GNULIB_PUTENV''@/0/g' \
-e 's/@''GNULIB_RANDOM''@/0/g' \
-e 's/@''GNULIB_RANDOM_R''@/0/g' \
-e 's/@''GNULIB_REALLOC_POSIX''@/0/g' \
-e 's/@''GNULIB_REALPATH''@/0/g' \
-e 's/@''GNULIB_RPMATCH''@/0/g' \
-e 's/@''GNULIB_SECURE_GETENV''@/0/g' \
-e 's/@''GNULIB_SETENV''@/1/g' \
-e 's/@''GNULIB_STRTOD''@/0/g' \
-e 's/@''GNULIB_STRTOLL''@/0/g' \
-e 's/@''GNULIB_STRTOULL''@/0/g' \
-e 's/@''GNULIB_SYSTEM_POSIX''@/0/g' \
-e 's/@''GNULIB_UNLOCKPT''@/0/g' \
-e 's/@''GNULIB_UNSETENV''@/1/g' \
-e 's/@''GNULIB_WCTOMB''@/0/g' \
< ./stdlib.in.h | \
sed -e 's|@''HAVE__EXIT''@|1|g' \
-e 's|@''HAVE_ATOLL''@|1|g' \
-e 's|@''HAVE_CANONICALIZE_FILE_NAME''@|1|g' \
-e 's|@''HAVE_DECL_GETLOADAVG''@|1|g' \
-e 's|@''HAVE_GETSUBOPT''@|1|g' \
-e 's|@''HAVE_GRANTPT''@|1|g' \
-e 's|@''HAVE_MKDTEMP''@|1|g' \
-e 's|@''HAVE_MKOSTEMP''@|1|g' \
-e 's|@''HAVE_MKOSTEMPS''@|1|g' \
-e 's|@''HAVE_MKSTEMP''@|1|g' \
-e 's|@''HAVE_MKSTEMPS''@|1|g' \
-e 's|@''HAVE_POSIX_OPENPT''@|1|g' \
-e 's|@''HAVE_PTSNAME''@|1|g' \
-e 's|@''HAVE_PTSNAME_R''@|1|g' \
-e 's|@''HAVE_RANDOM''@|1|g' \
-e 's|@''HAVE_RANDOM_H''@|1|g' \
-e 's|@''HAVE_RANDOM_R''@|1|g' \
-e 's|@''HAVE_REALPATH''@|1|g' \
-e 's|@''HAVE_RPMATCH''@|1|g' \
-e 's|@''HAVE_SECURE_GETENV''@|1|g' \
-e 's|@''HAVE_DECL_SETENV''@|1|g' \
-e 's|@''HAVE_STRTOD''@|1|g' \
-e 's|@''HAVE_STRTOLL''@|1|g' \
-e 's|@''HAVE_STRTOULL''@|1|g' \
-e 's|@''HAVE_STRUCT_RANDOM_DATA''@|1|g' \
-e 's|@''HAVE_SYS_LOADAVG_H''@|0|g' \
-e 's|@''HAVE_UNLOCKPT''@|1|g' \
-e 's|@''HAVE_DECL_UNSETENV''@|1|g' \
-e 's|@''REPLACE_CALLOC''@|0|g' \
-e 's|@''REPLACE_CANONICALIZE_FILE_NAME''@|0|g' \
-e 's|@''REPLACE_MALLOC''@|0|g' \
-e 's|@''REPLACE_MBTOWC''@|0|g' \
-e 's|@''REPLACE_MKSTEMP''@|0|g' \
-e 's|@''REPLACE_PTSNAME''@|0|g' \
-e 's|@''REPLACE_PTSNAME_R''@|0|g' \
-e 's|@''REPLACE_PUTENV''@|0|g' \
-e 's|@''REPLACE_RANDOM_R''@|0|g' \
-e 's|@''REPLACE_REALLOC''@|0|g' \
-e 's|@''REPLACE_REALPATH''@|0|g' \
-e 's|@''REPLACE_SETENV''@|0|g' \
-e 's|@''REPLACE_STRTOD''@|0|g' \
-e 's|@''REPLACE_UNSETENV''@|0|g' \
-e 's|@''REPLACE_WCTOMB''@|0|g' \
-e '/definition of _Noreturn/r ../build-aux/snippet/_Noreturn.h' \
} > stdlib.h-t && \
mv stdlib.h-t stdlib.h
rm -f string.h-t string.h && \
-e 's|@''NEXT_STRING_H''@|<string.h>|g' \
-e 's/@''GNULIB_FFSL''@/0/g' \
-e 's/@''GNULIB_FFSLL''@/0/g' \
-e 's/@''GNULIB_MBSLEN''@/0/g' \
-e 's/@''GNULIB_MBSNLEN''@/0/g' \
-e 's/@''GNULIB_MBSCHR''@/0/g' \
-e 's/@''GNULIB_MBSRCHR''@/0/g' \
-e 's/@''GNULIB_MBSSTR''@/0/g' \
-e 's/@''GNULIB_MBSCASECMP''@/0/g' \
-e 's/@''GNULIB_MBSNCASECMP''@/0/g' \
-e 's/@''GNULIB_MBSPCASECMP''@/0/g' \
-e 's/@''GNULIB_MBSCASESTR''@/0/g' \
-e 's/@''GNULIB_MBSCSPN''@/0/g' \
-e 's/@''GNULIB_MBSPBRK''@/0/g' \
-e 's/@''GNULIB_MBSSPN''@/0/g' \
-e 's/@''GNULIB_MBSSEP''@/0/g' \
-e 's/@''GNULIB_MBSTOK_R''@/0/g' \
-e 's/@''GNULIB_MEMCHR''@/1/g' \
-e 's/@''GNULIB_MEMMEM''@/0/g' \
-e 's/@''GNULIB_MEMPCPY''@/0/g' \
-e 's/@''GNULIB_MEMRCHR''@/0/g' \
-e 's/@''GNULIB_RAWMEMCHR''@/0/g' \
-e 's/@''GNULIB_STPCPY''@/0/g' \
-e 's/@''GNULIB_STPNCPY''@/0/g' \
-e 's/@''GNULIB_STRCHRNUL''@/0/g' \
-e 's/@''GNULIB_STRDUP''@/0/g' \
-e 's/@''GNULIB_STRNCAT''@/0/g' \
-e 's/@''GNULIB_STRNDUP''@/1/g' \
-e 's/@''GNULIB_STRNLEN''@/1/g' \
-e 's/@''GNULIB_STRPBRK''@/0/g' \
-e 's/@''GNULIB_STRSEP''@/1/g' \
-e 's/@''GNULIB_STRSTR''@/1/g' \
-e 's/@''GNULIB_STRCASESTR''@/1/g' \
-e 's/@''GNULIB_STRTOK_R''@/0/g' \
-e 's/@''GNULIB_STRERROR''@/1/g' \
-e 's/@''GNULIB_STRERROR_R''@/0/g' \
-e 's/@''GNULIB_STRSIGNAL''@/0/g' \
-e 's/@''GNULIB_STRVERSCMP''@/0/g' \
< ./string.in.h | \
sed -e 's|@''HAVE_FFSL''@|1|g' \
-e 's|@''HAVE_FFSLL''@|1|g' \
-e 's|@''HAVE_MBSLEN''@|0|g' \
-e 's|@''HAVE_MEMCHR''@|1|g' \
-e 's|@''HAVE_DECL_MEMMEM''@|1|g' \
-e 's|@''HAVE_MEMPCPY''@|1|g' \
-e 's|@''HAVE_DECL_MEMRCHR''@|1|g' \
-e 's|@''HAVE_RAWMEMCHR''@|1|g' \
-e 's|@''HAVE_STPCPY''@|1|g' \
-e 's|@''HAVE_STPNCPY''@|1|g' \
-e 's|@''HAVE_STRCHRNUL''@|1|g' \
-e 's|@''HAVE_DECL_STRDUP''@|1|g' \
-e 's|@''HAVE_DECL_STRNDUP''@|1|g' \
-e 's|@''HAVE_DECL_STRNLEN''@|1|g' \
-e 's|@''HAVE_STRPBRK''@|1|g' \
-e 's|@''HAVE_STRSEP''@|1|g' \
-e 's|@''HAVE_STRCASESTR''@|1|g' \
-e 's|@''HAVE_DECL_STRTOK_R''@|1|g' \
-e 's|@''HAVE_DECL_STRERROR_R''@|1|g' \
-e 's|@''HAVE_DECL_STRSIGNAL''@|1|g' \
-e 's|@''HAVE_STRVERSCMP''@|1|g' \
-e 's|@''REPLACE_STPNCPY''@|0|g' \
-e 's|@''REPLACE_MEMCHR''@|0|g' \
-e 's|@''REPLACE_MEMMEM''@|0|g' \
-e 's|@''REPLACE_STRCASESTR''@|1|g' \
-e 's|@''REPLACE_STRCHRNUL''@|0|g' \
-e 's|@''REPLACE_STRDUP''@|0|g' \
-e 's|@''REPLACE_STRSTR''@|0|g' \
-e 's|@''REPLACE_STRERROR''@|0|g' \
-e 's|@''REPLACE_STRERROR_R''@|0|g' \
-e 's|@''REPLACE_STRNCAT''@|0|g' \
-e 's|@''REPLACE_STRNDUP''@|0|g' \
-e 's|@''REPLACE_STRNLEN''@|0|g' \
-e 's|@''REPLACE_STRSIGNAL''@|0|g' \
-e 's|@''REPLACE_STRTOK_R''@|0|g' \
-e 's|@''UNDEFINE_STRTOK_R''@|0|g' \
< ./string.in.h; \
} > string.h-t && \
mv string.h-t string.h
rm -f strings.h-t strings.h && \
-e 's|@''HAVE_STRINGS_H''@|1|g' \
-e 's|@''NEXT_STRINGS_H''@|<strings.h>|g' \
-e 's|@''GNULIB_FFS''@|0|g' \
-e 's|@''HAVE_FFS''@|1|g' \
-e 's|@''HAVE_STRCASECMP''@|1|g' \
-e 's|@''HAVE_DECL_STRNCASECMP''@|1|g' \
< ./strings.in.h; \
} > strings.h-t && \
mv strings.h-t strings.h
/bin/mkdir -p sys
rm -f sys/socket.h-t sys/socket.h && \
-e 's|@''NEXT_SYS_SOCKET_H''@|<sys/socket.h>|g' \
-e 's|@''HAVE_SYS_SOCKET_H''@|1|g' \
-e 's/@''GNULIB_CLOSE''@/0/g' \
-e 's/@''GNULIB_SOCKET''@/0/g' \
-e 's/@''GNULIB_CONNECT''@/0/g' \
-e 's/@''GNULIB_ACCEPT''@/0/g' \
-e 's/@''GNULIB_BIND''@/0/g' \
-e 's/@''GNULIB_GETPEERNAME''@/0/g' \
-e 's/@''GNULIB_GETSOCKNAME''@/0/g' \
-e 's/@''GNULIB_GETSOCKOPT''@/0/g' \
-e 's/@''GNULIB_LISTEN''@/0/g' \
-e 's/@''GNULIB_RECV''@/0/g' \
-e 's/@''GNULIB_SEND''@/0/g' \
-e 's/@''GNULIB_RECVFROM''@/0/g' \
-e 's/@''GNULIB_SENDTO''@/0/g' \
-e 's/@''GNULIB_SETSOCKOPT''@/0/g' \
-e 's/@''GNULIB_SHUTDOWN''@/0/g' \
-e 's/@''GNULIB_ACCEPT4''@/0/g' \
-e 's|@''HAVE_WINSOCK2_H''@|0|g' \
-e 's|@''HAVE_WS2TCPIP_H''@|0|g' \
-e 's|@''HAVE_STRUCT_SOCKADDR_STORAGE''@|1|g' \
-e 's|@''HAVE_STRUCT_SOCKADDR_STORAGE_SS_FAMILY''@|1|g' \
-e 's|@''HAVE_SA_FAMILY_T''@|1|g' \
-e 's|@''HAVE_ACCEPT4''@|1|g' \
< ./sys_socket.in.h; \
} > sys/socket.h-t && \
mv -f sys/socket.h-t sys/socket.h
/bin/mkdir -p sys
rm -f sys/types.h-t sys/types.h && \
-e 's|@''NEXT_SYS_TYPES_H''@|<sys/types.h>|g' \
-e 's|@''WINDOWS_64_BIT_OFF_T''@|0|g' \
< ./sys_types.in.h; \
} > sys/types.h-t && \
mv sys/types.h-t sys/types.h
/bin/mkdir -p sys
rm -f sys/uio.h-t sys/uio.h && \
-e 's|@''NEXT_SYS_UIO_H''@|<sys/uio.h>|g' \
-e 's|@''HAVE_SYS_UIO_H''@|1|g' \
< ./sys_uio.in.h; \
} > sys/uio.h-t && \
mv -f sys/uio.h-t sys/uio.h
rm -f time.h-t time.h && \
-e 's|@''NEXT_TIME_H''@|<time.h>|g' \
-e 's/@''GNULIB_MKTIME''@/1/g' \
-e 's/@''GNULIB_NANOSLEEP''@/0/g' \
-e 's/@''GNULIB_STRPTIME''@/0/g' \
-e 's/@''GNULIB_TIMEGM''@/1/g' \
-e 's/@''GNULIB_TIME_R''@/1/g' \
-e 's|@''HAVE_DECL_LOCALTIME_R''@|1|g' \
-e 's|@''HAVE_NANOSLEEP''@|1|g' \
-e 's|@''HAVE_STRPTIME''@|1|g' \
-e 's|@''HAVE_TIMEGM''@|1|g' \
-e 's|@''REPLACE_LOCALTIME_R''@|0|g' \
-e 's|@''REPLACE_MKTIME''@|1|g' \
-e 's|@''REPLACE_NANOSLEEP''@|GNULIB_PORTCHECK|g' \
-e 's|@''REPLACE_TIMEGM''@|0|g' \
-e 's|@''PTHREAD_H_DEFINES_STRUCT_TIMESPEC''@|0|g' \
-e 's|@''SYS_TIME_H_DEFINES_STRUCT_TIMESPEC''@|0|g' \
-e 's|@''TIME_H_DEFINES_STRUCT_TIMESPEC''@|1|g' \
< ./time.in.h; \
} > time.h-t && \
mv time.h-t time.h
rm -f unistd.h-t unistd.h && \
-e 's|@''HAVE_UNISTD_H''@|1|g' \
-e 's|@''NEXT_UNISTD_H''@|<unistd.h>|g' \
-e 's/@''GNULIB_CHDIR''@/0/g' \
-e 's/@''GNULIB_CHOWN''@/0/g' \
-e 's/@''GNULIB_DUP''@/0/g' \
-e 's/@''GNULIB_DUP2''@/0/g' \
-e 's/@''GNULIB_DUP3''@/0/g' \
-e 's/@''GNULIB_ENVIRON''@/1/g' \
-e 's/@''GNULIB_EUIDACCESS''@/0/g' \
-e 's/@''GNULIB_FACCESSAT''@/0/g' \
-e 's/@''GNULIB_FCHDIR''@/0/g' \
-e 's/@''GNULIB_FCHOWNAT''@/0/g' \
-e 's/@''GNULIB_FDATASYNC''@/0/g' \
-e 's/@''GNULIB_FSYNC''@/0/g' \
-e 's/@''GNULIB_FTRUNCATE''@/0/g' \
-e 's/@''GNULIB_GETCWD''@/0/g' \
-e 's/@''GNULIB_GETDOMAINNAME''@/0/g' \
-e 's/@''GNULIB_GETDTABLESIZE''@/0/g' \
-e 's/@''GNULIB_GETGROUPS''@/0/g' \
-e 's/@''GNULIB_GETHOSTNAME''@/1/g' \
-e 's/@''GNULIB_GETLOGIN''@/0/g' \
-e 's/@''GNULIB_GETLOGIN_R''@/0/g' \
-e 's/@''GNULIB_GETPAGESIZE''@/0/g' \
-e 's/@''GNULIB_GETUSERSHELL''@/0/g' \
-e 's/@''GNULIB_GROUP_MEMBER''@/0/g' \
-e 's/@''GNULIB_ISATTY''@/0/g' \
-e 's/@''GNULIB_LCHOWN''@/0/g' \
-e 's/@''GNULIB_LINK''@/0/g' \
-e 's/@''GNULIB_LINKAT''@/0/g' \
-e 's/@''GNULIB_LSEEK''@/0/g' \
-e 's/@''GNULIB_PIPE''@/0/g' \
-e 's/@''GNULIB_PIPE2''@/0/g' \
-e 's/@''GNULIB_PREAD''@/0/g' \
-e 's/@''GNULIB_PWRITE''@/0/g' \
-e 's/@''GNULIB_READ''@/1/g' \
-e 's/@''GNULIB_READLINK''@/0/g' \
-e 's/@''GNULIB_READLINKAT''@/0/g' \
-e 's/@''GNULIB_RMDIR''@/0/g' \
-e 's/@''GNULIB_SETHOSTNAME''@/0/g' \
-e 's/@''GNULIB_SLEEP''@/0/g' \
-e 's/@''GNULIB_SYMLINK''@/0/g' \
-e 's/@''GNULIB_SYMLINKAT''@/0/g' \
-e 's/@''GNULIB_TTYNAME_R''@/0/g' \
-e 's/@''GNULIB_UNISTD_H_GETOPT''@/0/g' \
-e 's/@''GNULIB_UNISTD_H_NONBLOCKING''@/0/g' \
-e 's/@''GNULIB_UNISTD_H_SIGPIPE''@/0/g' \
-e 's/@''GNULIB_UNLINK''@/0/g' \
-e 's/@''GNULIB_UNLINKAT''@/0/g' \
-e 's/@''GNULIB_USLEEP''@/0/g' \
-e 's/@''GNULIB_WRITE''@/0/g' \
< ./unistd.in.h | \
sed -e 's|@''HAVE_CHOWN''@|1|g' \
-e 's|@''HAVE_DUP2''@|1|g' \
-e 's|@''HAVE_DUP3''@|1|g' \
-e 's|@''HAVE_EUIDACCESS''@|1|g' \
-e 's|@''HAVE_FACCESSAT''@|1|g' \
-e 's|@''HAVE_FCHDIR''@|1|g' \
-e 's|@''HAVE_FCHOWNAT''@|1|g' \
-e 's|@''HAVE_FDATASYNC''@|1|g' \
-e 's|@''HAVE_FSYNC''@|1|g' \
-e 's|@''HAVE_FTRUNCATE''@|1|g' \
-e 's|@''HAVE_GETDTABLESIZE''@|1|g' \
-e 's|@''HAVE_GETGROUPS''@|1|g' \
-e 's|@''HAVE_GETHOSTNAME''@|1|g' \
-e 's|@''HAVE_GETLOGIN''@|1|g' \
-e 's|@''HAVE_GETPAGESIZE''@|1|g' \
-e 's|@''HAVE_GROUP_MEMBER''@|1|g' \
-e 's|@''HAVE_LCHOWN''@|1|g' \
-e 's|@''HAVE_LINK''@|1|g' \
-e 's|@''HAVE_LINKAT''@|1|g' \
-e 's|@''HAVE_PIPE''@|1|g' \
-e 's|@''HAVE_PIPE2''@|1|g' \
-e 's|@''HAVE_PREAD''@|1|g' \
-e 's|@''HAVE_PWRITE''@|1|g' \
-e 's|@''HAVE_READLINK''@|1|g' \
-e 's|@''HAVE_READLINKAT''@|1|g' \
-e 's|@''HAVE_SETHOSTNAME''@|1|g' \
-e 's|@''HAVE_SLEEP''@|1|g' \
-e 's|@''HAVE_SYMLINK''@|1|g' \
-e 's|@''HAVE_SYMLINKAT''@|1|g' \
-e 's|@''HAVE_UNLINKAT''@|1|g' \
-e 's|@''HAVE_USLEEP''@|1|g' \
-e 's|@''HAVE_DECL_ENVIRON''@|1|g' \
-e 's|@''HAVE_DECL_FCHDIR''@|1|g' \
-e 's|@''HAVE_DECL_FDATASYNC''@|1|g' \
-e 's|@''HAVE_DECL_GETDOMAINNAME''@|1|g' \
-e 's|@''HAVE_DECL_GETLOGIN_R''@|1|g' \
-e 's|@''HAVE_DECL_GETPAGESIZE''@|1|g' \
-e 's|@''HAVE_DECL_GETUSERSHELL''@|1|g' \
-e 's|@''HAVE_DECL_SETHOSTNAME''@|1|g' \
-e 's|@''HAVE_DECL_TTYNAME_R''@|1|g' \
-e 's|@''HAVE_OS_H''@|0|g' \
-e 's|@''HAVE_SYS_PARAM_H''@|0|g' \
sed -e 's|@''REPLACE_CHOWN''@|0|g' \
-e 's|@''REPLACE_CLOSE''@|0|g' \
-e 's|@''REPLACE_DUP''@|0|g' \
-e 's|@''REPLACE_DUP2''@|0|g' \
-e 's|@''REPLACE_FCHOWNAT''@|0|g' \
-e 's|@''REPLACE_FTRUNCATE''@|0|g' \
-e 's|@''REPLACE_GETCWD''@|0|g' \
-e 's|@''REPLACE_GETDOMAINNAME''@|0|g' \
-e 's|@''REPLACE_GETLOGIN_R''@|0|g' \
-e 's|@''REPLACE_GETGROUPS''@|0|g' \
-e 's|@''REPLACE_GETPAGESIZE''@|0|g' \
-e 's|@''REPLACE_ISATTY''@|0|g' \
-e 's|@''REPLACE_LCHOWN''@|0|g' \
-e 's|@''REPLACE_LINK''@|0|g' \
-e 's|@''REPLACE_LINKAT''@|0|g' \
-e 's|@''REPLACE_LSEEK''@|0|g' \
-e 's|@''REPLACE_PREAD''@|0|g' \
-e 's|@''REPLACE_PWRITE''@|0|g' \
-e 's|@''REPLACE_READ''@|0|g' \
-e 's|@''REPLACE_READLINK''@|0|g' \
-e 's|@''REPLACE_RMDIR''@|0|g' \
-e 's|@''REPLACE_SLEEP''@|0|g' \
-e 's|@''REPLACE_SYMLINK''@|0|g' \
-e 's|@''REPLACE_TTYNAME_R''@|0|g' \
-e 's|@''REPLACE_UNLINK''@|0|g' \
-e 's|@''REPLACE_UNLINKAT''@|0|g' \
-e 's|@''REPLACE_USLEEP''@|0|g' \
-e 's|@''REPLACE_WRITE''@|0|g' \
-e 's|@''UNISTD_H_HAVE_WINSOCK2_H''@|0|g' \
-e 's|@''UNISTD_H_HAVE_WINSOCK2_H_AND_USE_SOCKETS''@|0|g' \
} > unistd.h-t && \
mv unistd.h-t unistd.h
rm -f wchar.h-t wchar.h && \
-e 's|@''NEXT_WCHAR_H''@|<wchar.h>|g' \
-e 's|@''HAVE_WCHAR_H''@|1|g' \
-e 's/@''GNULIB_BTOWC''@/1/g' \
-e 's/@''GNULIB_WCTOB''@/0/g' \
-e 's/@''GNULIB_MBSINIT''@/1/g' \
-e 's/@''GNULIB_MBRTOWC''@/1/g' \
-e 's/@''GNULIB_MBRLEN''@/0/g' \
-e 's/@''GNULIB_MBSRTOWCS''@/0/g' \
-e 's/@''GNULIB_MBSNRTOWCS''@/0/g' \
-e 's/@''GNULIB_WCRTOMB''@/1/g' \
-e 's/@''GNULIB_WCSRTOMBS''@/0/g' \
-e 's/@''GNULIB_WCSNRTOMBS''@/0/g' \
-e 's/@''GNULIB_WCWIDTH''@/0/g' \
-e 's/@''GNULIB_WMEMCHR''@/0/g' \
-e 's/@''GNULIB_WMEMCMP''@/0/g' \
-e 's/@''GNULIB_WMEMCPY''@/0/g' \
-e 's/@''GNULIB_WMEMMOVE''@/0/g' \
-e 's/@''GNULIB_WMEMSET''@/0/g' \
-e 's/@''GNULIB_WCSLEN''@/0/g' \
-e 's/@''GNULIB_WCSNLEN''@/0/g' \
-e 's/@''GNULIB_WCSCPY''@/0/g' \
-e 's/@''GNULIB_WCPCPY''@/0/g' \
-e 's/@''GNULIB_WCSNCPY''@/0/g' \
-e 's/@''GNULIB_WCPNCPY''@/0/g' \
-e 's/@''GNULIB_WCSCAT''@/0/g' \
-e 's/@''GNULIB_WCSNCAT''@/0/g' \
-e 's/@''GNULIB_WCSCMP''@/0/g' \
-e 's/@''GNULIB_WCSNCMP''@/0/g' \
-e 's/@''GNULIB_WCSCASECMP''@/0/g' \
-e 's/@''GNULIB_WCSNCASECMP''@/0/g' \
-e 's/@''GNULIB_WCSCOLL''@/0/g' \
-e 's/@''GNULIB_WCSXFRM''@/0/g' \
-e 's/@''GNULIB_WCSDUP''@/0/g' \
-e 's/@''GNULIB_WCSCHR''@/0/g' \
-e 's/@''GNULIB_WCSRCHR''@/0/g' \
-e 's/@''GNULIB_WCSCSPN''@/0/g' \
-e 's/@''GNULIB_WCSSPN''@/0/g' \
-e 's/@''GNULIB_WCSPBRK''@/0/g' \
-e 's/@''GNULIB_WCSSTR''@/0/g' \
-e 's/@''GNULIB_WCSTOK''@/0/g' \
-e 's/@''GNULIB_WCSWIDTH''@/0/g' \
< ./wchar.in.h | \
sed -e 's|@''HAVE_WINT_T''@|1|g' \
-e 's|@''HAVE_BTOWC''@|1|g' \
-e 's|@''HAVE_MBSINIT''@|1|g' \
-e 's|@''HAVE_MBRTOWC''@|1|g' \
-e 's|@''HAVE_MBRLEN''@|1|g' \
-e 's|@''HAVE_MBSRTOWCS''@|1|g' \
-e 's|@''HAVE_MBSNRTOWCS''@|1|g' \
-e 's|@''HAVE_WCRTOMB''@|1|g' \
-e 's|@''HAVE_WCSRTOMBS''@|1|g' \
-e 's|@''HAVE_WCSNRTOMBS''@|1|g' \
-e 's|@''HAVE_WMEMCHR''@|1|g' \
-e 's|@''HAVE_WMEMCMP''@|1|g' \
-e 's|@''HAVE_WMEMCPY''@|1|g' \
-e 's|@''HAVE_WMEMMOVE''@|1|g' \
-e 's|@''HAVE_WMEMSET''@|1|g' \
-e 's|@''HAVE_WCSLEN''@|1|g' \
-e 's|@''HAVE_WCSNLEN''@|1|g' \
-e 's|@''HAVE_WCSCPY''@|1|g' \
-e 's|@''HAVE_WCPCPY''@|1|g' \
-e 's|@''HAVE_WCSNCPY''@|1|g' \
-e 's|@''HAVE_WCPNCPY''@|1|g' \
-e 's|@''HAVE_WCSCAT''@|1|g' \
-e 's|@''HAVE_WCSNCAT''@|1|g' \
-e 's|@''HAVE_WCSCMP''@|1|g' \
-e 's|@''HAVE_WCSNCMP''@|1|g' \
-e 's|@''HAVE_WCSCASECMP''@|1|g' \
-e 's|@''HAVE_WCSNCASECMP''@|1|g' \
-e 's|@''HAVE_WCSCOLL''@|1|g' \
-e 's|@''HAVE_WCSXFRM''@|1|g' \
-e 's|@''HAVE_WCSDUP''@|1|g' \
-e 's|@''HAVE_WCSCHR''@|1|g' \
-e 's|@''HAVE_WCSRCHR''@|1|g' \
-e 's|@''HAVE_WCSCSPN''@|1|g' \
-e 's|@''HAVE_WCSSPN''@|1|g' \
-e 's|@''HAVE_WCSPBRK''@|1|g' \
-e 's|@''HAVE_WCSSTR''@|1|g' \
-e 's|@''HAVE_WCSTOK''@|1|g' \
-e 's|@''HAVE_WCSWIDTH''@|1|g' \
-e 's|@''HAVE_DECL_WCTOB''@|1|g' \
-e 's|@''HAVE_DECL_WCWIDTH''@|1|g' \
sed -e 's|@''REPLACE_MBSTATE_T''@|0|g' \
-e 's|@''REPLACE_BTOWC''@|0|g' \
-e 's|@''REPLACE_WCTOB''@|0|g' \
-e 's|@''REPLACE_MBSINIT''@|0|g' \
-e 's|@''REPLACE_MBRTOWC''@|0|g' \
-e 's|@''REPLACE_MBRLEN''@|0|g' \
-e 's|@''REPLACE_MBSRTOWCS''@|0|g' \
-e 's|@''REPLACE_MBSNRTOWCS''@|0|g' \
-e 's|@''REPLACE_WCRTOMB''@|0|g' \
-e 's|@''REPLACE_WCSRTOMBS''@|0|g' \
-e 's|@''REPLACE_WCSNRTOMBS''@|0|g' \
-e 's|@''REPLACE_WCWIDTH''@|0|g' \
-e 's|@''REPLACE_WCSWIDTH''@|0|g' \
} > wchar.h-t && \
mv wchar.h-t wchar.h
pcouas
Post by pcouas »
THIRD3
rm -f wctype.h-t wctype.h && \
-e 's/@''HAVE_WCTYPE_H''@/1/g' \
-e 's|@''NEXT_WCTYPE_H''@|<wctype.h>|g' \
-e 's/@''GNULIB_ISWBLANK''@/0/g' \
-e 's/@''GNULIB_WCTYPE''@/0/g' \
-e 's/@''GNULIB_ISWCTYPE''@/0/g' \
-e 's/@''GNULIB_WCTRANS''@/0/g' \
-e 's/@''GNULIB_TOWCTRANS''@/0/g' \
-e 's/@''HAVE_ISWBLANK''@/1/g' \
-e 's/@''HAVE_ISWCNTRL''@/1/g' \
-e 's/@''HAVE_WCTYPE_T''@/1/g' \
-e 's/@''HAVE_WCTRANS_T''@/1/g' \
-e 's/@''HAVE_WINT_T''@/1/g' \
-e 's/@''REPLACE_ISWBLANK''@/0/g' \
-e 's/@''REPLACE_ISWCNTRL''@/0/g' \
-e 's/@''REPLACE_TOWLOWER''@/0/g' \
< ./wctype.in.h; \
} > wctype.h-t && \
mv wctype.h-t wctype.h
make all-recursive
make[3]: Entering directory `/tmp/nagios-plugins-release-2.1.3/gl'
make[4]: Entering directory `/tmp/nagios-plugins-release-2.1.3/gl'
depbase=`echo base64.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT base64.o -MD -MP -MF $depbase.Tpo -c -o base64.o base64.c &&\
mv -f $depbase.Tpo $depbase.Po
depbase=`echo sha1.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT sha1.o -MD -MP -MF $depbase.Tpo -c -o sha1.o sha1.c &&\
depbase=`echo dirname.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT dirname.o -MD -MP -MF $depbase.Tpo -c -o dirname.o dirname.c &&\
depbase=`echo basename.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT basename.o -MD -MP -MF $depbase.Tpo -c -o basename.o basename.c &&\
depbase=`echo dirname-lgpl.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT dirname-lgpl.o -MD -MP -MF $depbase.Tpo -c -o dirname-lgpl.o dirname-lgpl.c &&\
depbase=`echo basename-lgpl.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT basename-lgpl.o -MD -MP -MF $depbase.Tpo -c -o basename-lgpl.o basename-lgpl.c &&\
depbase=`echo exitfail.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT exitfail.o -MD -MP -MF $depbase.Tpo -c -o exitfail.o exitfail.c &&\
depbase=`echo fd-hook.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT fd-hook.o -MD -MP -MF $depbase.Tpo -c -o fd-hook.o fd-hook.c &&\
depbase=`echo idpriv-droptemp.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT idpriv-droptemp.o -MD -MP -MF $depbase.Tpo -c -o idpriv-droptemp.o idpriv-droptemp.c &&\
depbase=`echo localcharset.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT localcharset.o -MD -MP -MF $depbase.Tpo -c -o localcharset.o localcharset.c &&\
depbase=`echo glthread/lock.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT glthread/lock.o -MD -MP -MF $depbase.Tpo -c -o glthread/lock.o glthread/lock.c &&\
depbase=`echo malloca.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT malloca.o -MD -MP -MF $depbase.Tpo -c -o malloca.o malloca.c &&\
depbase=`echo math.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT math.o -MD -MP -MF $depbase.Tpo -c -o math.o math.c &&\
depbase=`echo safe-read.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT safe-read.o -MD -MP -MF $depbase.Tpo -c -o safe-read.o safe-read.c &&\
depbase=`echo sys_socket.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT sys_socket.o -MD -MP -MF $depbase.Tpo -c -o sys_socket.o sys_socket.c &&\
depbase=`echo glthread/threadlib.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT glthread/threadlib.o -MD -MP -MF $depbase.Tpo -c -o glthread/threadlib.o glthread/threadlib.c &&\
depbase=`echo unistd.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT unistd.o -MD -MP -MF $depbase.Tpo -c -o unistd.o unistd.c &&\
depbase=`echo wctype-h.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT wctype-h.o -MD -MP -MF $depbase.Tpo -c -o wctype-h.o wctype-h.c &&\
depbase=`echo xmalloc.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT xmalloc.o -MD -MP -MF $depbase.Tpo -c -o xmalloc.o xmalloc.c &&\
depbase=`echo xalloc-die.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT xalloc-die.o -MD -MP -MF $depbase.Tpo -c -o xalloc-die.o xalloc-die.c &&\
depbase=`echo xstrndup.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT xstrndup.o -MD -MP -MF $depbase.Tpo -c -o xstrndup.o xstrndup.c &&\
depbase=`echo fsusage.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT fsusage.o -MD -MP -MF $depbase.Tpo -c -o fsusage.o fsusage.c &&\
depbase=`echo mktime.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT mktime.o -MD -MP -MF $depbase.Tpo -c -o mktime.o mktime.c &&\
depbase=`echo mountlist.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT mountlist.o -MD -MP -MF $depbase.Tpo -c -o mountlist.o mountlist.c &&\
depbase=`echo printf-args.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT printf-args.o -MD -MP -MF $depbase.Tpo -c -o printf-args.o printf-args.c &&\
depbase=`echo printf-parse.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT printf-parse.o -MD -MP -MF $depbase.Tpo -c -o printf-parse.o printf-parse.c &&\
depbase=`echo strcasestr.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT strcasestr.o -MD -MP -MF $depbase.Tpo -c -o strcasestr.o strcasestr.c &&\
depbase=`echo vasnprintf.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
gcc -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT vasnprintf.o -MD -MP -MF $depbase.Tpo -c -o vasnprintf.o vasnprintf.c &&\
rm -f libgnu.a
ar cru libgnu.a base64.o sha1.o dirname.o basename.o dirname-lgpl.o basename-lgpl.o stripslash.o exitfail.o fd-hook.o full-read.o idpriv-droptemp.o localcharset.o glthread/lock.o malloca.o math.o safe-read.o sockets.o sys_socket.o glthread/threadlib.o unistd.o wctype-h.o xmalloc.o xalloc-die.o xsize.o xstrndup.o asnprintf.o fsusage.o mktime.o mountlist.o printf-args.o printf-parse.o strcasestr.o vasnprintf.o
ranlib libgnu.a
make[4]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/gl'
make[3]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/gl'
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/gl'
Making all in tap
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/tap'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/tap'
Making all in lib
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/lib'
Making all in .
make[3]: Entering directory `/tmp/nagios-plugins-release-2.1.3/lib'
gcc -DHAVE_CONFIG_H -I. -I.. -DNP_STATE_DIR_PREFIX=\"/usr/local/nagios/var\" -I. -I../gl -I../intl -I../plugins -g -O2 -MT utils_base.o -MD -MP -MF .deps/utils_base.Tpo -c -o utils_base.o utils_base.c
mv -f .deps/utils_base.Tpo .deps/utils_base.Po
gcc -DHAVE_CONFIG_H -I. -I.. -DNP_STATE_DIR_PREFIX=\"/usr/local/nagios/var\" -I. -I../gl -I../intl -I../plugins -g -O2 -MT utils_disk.o -MD -MP -MF .deps/utils_disk.Tpo -c -o utils_disk.o utils_disk.c
mv -f .deps/utils_disk.Tpo .deps/utils_disk.Po
gcc -DHAVE_CONFIG_H -I. -I.. -DNP_STATE_DIR_PREFIX=\"/usr/local/nagios/var\" -I. -I../gl -I../intl -I../plugins -g -O2 -MT utils_tcp.o -MD -MP -MF .deps/utils_tcp.Tpo -c -o utils_tcp.o utils_tcp.c
mv -f .deps/utils_tcp.Tpo .deps/utils_tcp.Po
gcc -DHAVE_CONFIG_H -I. -I.. -DNP_STATE_DIR_PREFIX=\"/usr/local/nagios/var\" -I. -I../gl -I../intl -I../plugins -g -O2 -MT utils_cmd.o -MD -MP -MF .deps/utils_cmd.Tpo -c -o utils_cmd.o utils_cmd.c
mv -f .deps/utils_cmd.Tpo .deps/utils_cmd.Po
gcc -DHAVE_CONFIG_H -I. -I.. -DNP_STATE_DIR_PREFIX=\"/usr/local/nagios/var\" -I. -I../gl -I../intl -I../plugins -g -O2 -MT parse_ini.o -MD -MP -MF .deps/parse_ini.Tpo -c -o parse_ini.o parse_ini.c
mv -f .deps/parse_ini.Tpo .deps/parse_ini.Po
gcc -DHAVE_CONFIG_H -I. -I.. -DNP_STATE_DIR_PREFIX=\"/usr/local/nagios/var\" -I. -I../gl -I../intl -I../plugins -g -O2 -MT extra_opts.o -MD -MP -MF .deps/extra_opts.Tpo -c -o extra_opts.o extra_opts.c
mv -f .deps/extra_opts.Tpo .deps/extra_opts.Po
rm -f libnagiosplug.a
ar cru libnagiosplug.a utils_base.o utils_disk.o utils_tcp.o utils_cmd.o parse_ini.o extra_opts.o
ranlib libnagiosplug.a
make[3]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/lib'
Making all in tests
make[3]: Entering directory `/tmp/nagios-plugins-release-2.1.3/lib/tests'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/lib/tests'
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/lib'
Making all in plugins
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins'
2.1.3.git
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT utils.o -MD -MP -MF .deps/utils.Tpo -c -o utils.o utils.c
mv -f .deps/utils.Tpo .deps/utils.Po
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT netutils.o -MD -MP -MF .deps/netutils.Tpo -c -o netutils.o netutils.c
mv -f .deps/netutils.Tpo .deps/netutils.Po
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT sslutils.o -MD -MP -MF .deps/sslutils.Tpo -c -o sslutils.o sslutils.c
mv -f .deps/sslutils.Tpo .deps/sslutils.Po
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT runcmd.o -MD -MP -MF .deps/runcmd.Tpo -c -o runcmd.o runcmd.c
mv -f .deps/runcmd.Tpo .deps/runcmd.Po
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT popen.o -MD -MP -MF .deps/popen.Tpo -c -o popen.o popen.c
mv -f .deps/popen.Tpo .deps/popen.Po
rm -f libnpcommon.a
ar cru libnpcommon.a utils.o netutils.o sslutils.o runcmd.o popen.o runcmd.o
ranlib libnpcommon.a
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_apt.o -MD -MP -MF .deps/check_apt.Tpo -c -o check_apt.o check_apt.c
mv -f .deps/check_apt.Tpo .deps/check_apt.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_apt check_apt.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_apt check_apt.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_cluster.o -MD -MP -MF .deps/check_cluster.Tpo -c -o check_cluster.o check_cluster.c
mv -f .deps/check_cluster.Tpo .deps/check_cluster.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_cluster check_cluster.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_cluster check_cluster.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_disk.o -MD -MP -MF .deps/check_disk.Tpo -c -o check_disk.o check_disk.c
mv -f .deps/check_disk.Tpo .deps/check_disk.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_disk check_disk.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_disk check_disk.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_dummy.o -MD -MP -MF .deps/check_dummy.Tpo -c -o check_dummy.o check_dummy.c
mv -f .deps/check_dummy.Tpo .deps/check_dummy.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_dummy check_dummy.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_dummy check_dummy.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_http.o -MD -MP -MF .deps/check_http.Tpo -c -o check_http.o check_http.c
mv -f .deps/check_http.Tpo .deps/check_http.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_http check_http.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lssl -lcrypto -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_http check_http.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lssl -lcrypto -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_load.o -MD -MP -MF .deps/check_load.Tpo -c -o check_load.o check_load.c
mv -f .deps/check_load.Tpo .deps/check_load.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_load check_load.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_load check_load.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_mrtg.o -MD -MP -MF .deps/check_mrtg.Tpo -c -o check_mrtg.o check_mrtg.c
mv -f .deps/check_mrtg.Tpo .deps/check_mrtg.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_mrtg check_mrtg.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_mrtg check_mrtg.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_mrtgtraf.o -MD -MP -MF .deps/check_mrtgtraf.Tpo -c -o check_mrtgtraf.o check_mrtgtraf.c
mv -f .deps/check_mrtgtraf.Tpo .deps/check_mrtgtraf.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_mrtgtraf check_mrtgtraf.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_mrtgtraf check_mrtgtraf.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ntp.o -MD -MP -MF .deps/check_ntp.Tpo -c -o check_ntp.o check_ntp.c
mv -f .deps/check_ntp.Tpo .deps/check_ntp.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ntp check_ntp.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lm -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ntp check_ntp.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lm -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ntp_peer.o -MD -MP -MF .deps/check_ntp_peer.Tpo -c -o check_ntp_peer.o check_ntp_peer.c
mv -f .deps/check_ntp_peer.Tpo .deps/check_ntp_peer.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ntp_peer check_ntp_peer.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lm -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ntp_peer check_ntp_peer.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lm -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_nwstat.o -MD -MP -MF .deps/check_nwstat.Tpo -c -o check_nwstat.o check_nwstat.c
mv -f .deps/check_nwstat.Tpo .deps/check_nwstat.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_nwstat check_nwstat.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_nwstat check_nwstat.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_overcr.o -MD -MP -MF .deps/check_overcr.Tpo -c -o check_overcr.o check_overcr.c
mv -f .deps/check_overcr.Tpo .deps/check_overcr.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_overcr check_overcr.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_overcr check_overcr.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ping.o -MD -MP -MF .deps/check_ping.Tpo -c -o check_ping.o check_ping.c
mv -f .deps/check_ping.Tpo .deps/check_ping.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ping check_ping.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ping check_ping.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_real.o -MD -MP -MF .deps/check_real.Tpo -c -o check_real.o check_real.c
mv -f .deps/check_real.Tpo .deps/check_real.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_real check_real.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_real check_real.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_smtp.o -MD -MP -MF .deps/check_smtp.Tpo -c -o check_smtp.o check_smtp.c
mv -f .deps/check_smtp.Tpo .deps/check_smtp.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_smtp check_smtp.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lssl -lcrypto -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_smtp check_smtp.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lssl -lcrypto -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ssh.o -MD -MP -MF .deps/check_ssh.Tpo -c -o check_ssh.o check_ssh.c
mv -f .deps/check_ssh.Tpo .deps/check_ssh.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ssh check_ssh.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ssh check_ssh.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_tcp.o -MD -MP -MF .deps/check_tcp.Tpo -c -o check_tcp.o check_tcp.c
mv -f .deps/check_tcp.Tpo .deps/check_tcp.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_tcp check_tcp.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lssl -lcrypto -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_tcp check_tcp.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lssl -lcrypto -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_time.o -MD -MP -MF .deps/check_time.Tpo -c -o check_time.o check_time.c
mv -f .deps/check_time.Tpo .deps/check_time.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_time check_time.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_time check_time.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ntp_time.o -MD -MP -MF .deps/check_ntp_time.Tpo -c -o check_ntp_time.o check_ntp_time.c
mv -f .deps/check_ntp_time.Tpo .deps/check_ntp_time.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ntp_time check_ntp_time.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lm -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ntp_time check_ntp_time.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lm -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ups.o -MD -MP -MF .deps/check_ups.Tpo -c -o check_ups.o check_ups.c
mv -f .deps/check_ups.Tpo .deps/check_ups.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ups check_ups.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ups check_ups.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_users.o -MD -MP -MF .deps/check_users.Tpo -c -o check_users.o check_users.c
mv -f .deps/check_users.Tpo .deps/check_users.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_users check_users.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_users check_users.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT negate.o -MD -MP -MF .deps/negate.Tpo -c -o negate.o negate.c
mv -f .deps/negate.Tpo .deps/negate.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o negate negate.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o negate negate.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT urlize.o -MD -MP -MF .deps/urlize.Tpo -c -o urlize.o urlize.c
mv -f .deps/urlize.Tpo .deps/urlize.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o urlize urlize.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o urlize urlize.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_ide_smart.o -MD -MP -MF .deps/check_ide_smart.Tpo -c -o check_ide_smart.o check_ide_smart.c
mv -f .deps/check_ide_smart.Tpo .deps/check_ide_smart.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_ide_smart check_ide_smart.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_ide_smart check_ide_smart.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_uptime.o -MD -MP -MF .deps/check_uptime.Tpo -c -o check_uptime.o check_uptime.c
mv -f .deps/check_uptime.Tpo .deps/check_uptime.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_uptime check_uptime.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lrt -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_uptime check_uptime.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lrt -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_procs.o -MD -MP -MF .deps/check_procs.Tpo -c -o check_procs.o check_procs.c
mv -f .deps/check_procs.Tpo .deps/check_procs.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_procs check_procs.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_procs check_procs.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_nagios.o -MD -MP -MF .deps/check_nagios.Tpo -c -o check_nagios.o check_nagios.c
mv -f .deps/check_nagios.Tpo .deps/check_nagios.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_nagios check_nagios.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_nagios check_nagios.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_by_ssh.o -MD -MP -MF .deps/check_by_ssh.Tpo -c -o check_by_ssh.o check_by_ssh.c
mv -f .deps/check_by_ssh.Tpo .deps/check_by_ssh.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_by_ssh check_by_ssh.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_by_ssh check_by_ssh.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_swap.o -MD -MP -MF .deps/check_swap.Tpo -c -o check_swap.o check_swap.c
mv -f .deps/check_swap.Tpo .deps/check_swap.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_swap check_swap.o -lm libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_swap check_swap.o -L. -lm libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_nt.o -MD -MP -MF .deps/check_nt.Tpo -c -o check_nt.o check_nt.c
mv -f .deps/check_nt.Tpo .deps/check_nt.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_nt check_nt.o libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_nt check_nt.o -L. libnpcommon.a ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins'
Making all in plugins-scripts
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins-scripts'
2.1.3.git
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins-scripts'
Making all in plugins-root
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins-root'
2.1.3.git
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I../plugins -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_dhcp.o -MD -MP -MF .deps/check_dhcp.Tpo -c -o check_dhcp.o check_dhcp.c
mv -f .deps/check_dhcp.Tpo .deps/check_dhcp.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_dhcp check_dhcp.o ../plugins/netutils.o ../plugins/utils.o ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_dhcp check_dhcp.o ../plugins/netutils.o ../plugins/utils.o -L. ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
gcc -DLOCALEDIR=\"/usr/local/nagios/share/locale\" -DHAVE_CONFIG_H -I. -I.. -I.. -I../lib -I../gl -I../intl -I../plugins -I/usr/include -DNP_VERSION='"2.1.3.git"' -g -O2 -MT check_icmp.o -MD -MP -MF .deps/check_icmp.Tpo -c -o check_icmp.o check_icmp.c
mv -f .deps/check_icmp.Tpo .deps/check_icmp.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -DNP_VERSION='"2.1.3.git"' -g -O2 -L. -o check_icmp check_icmp.o ../plugins/netutils.o ../plugins/utils.o ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lnsl -lresolv -lpthread -ldl
libtool: link: gcc -DNP_VERSION=\"2.1.3.git\" -g -O2 -o check_icmp check_icmp.o ../plugins/netutils.o ../plugins/utils.o -L. ../lib/libnagiosplug.a ../gl/libgnu.a -lnsl -lresolv -lpthread -ldl
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins-root'
Making all in po
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/po'
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/po'
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3'
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3'
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3'
[ec2-user@ciapacaprod nagios-plugins-release-2.1.3]$
[ec2-user@ciapacaprod nagios-plugins-release-2.1.3]$ sudo make install
Making install in gl
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/gl'
make install-recursive
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/gl'
if test yes = no; then \
case 'linux-gnu' in \
darwin[56]*) \
need_charset_alias=true ;; \
darwin* | cygwin* | mingw* | pw32* | cegcc*) \
need_charset_alias=false ;; \
esac ; \
else \
need_charset_alias=false ; \
fi ; \
if $need_charset_alias; then \
/bin/sh ../build-aux/mkinstalldirs /usr/local/nagios/lib ; \
fi ; \
if test -f /usr/local/nagios/lib/charset.alias; then \
sed -f ref-add.sed /usr/local/nagios/lib/charset.alias > /usr/local/nagios/lib/charset.tmp ; \
/bin/install -c -m 644 /usr/local/nagios/lib/charset.tmp /usr/local/nagios/lib/charset.alias ; \
rm -f /usr/local/nagios/lib/charset.tmp ; \
else \
sed -f ref-add.sed charset.alias > /usr/local/nagios/lib/charset.tmp ; \
fi ; \
fi
make[4]: Nothing to be done for `install-data-am'.
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/gl'
Making install in tap
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/tap'
make[2]: Nothing to be done for `install-exec-am'.
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/tap'
Making install in lib
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/lib'
Making install in .
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
Making install in tests
make[2]: Entering directory `/tmp/nagios-plugins-release-2.1.3/lib/tests'
make[2]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/lib/tests'
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/lib'
Making install in plugins
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins'
2.1.3.git
2.1.3.git
/bin/mkdir -p '/usr/local/nagios/libexec'
/bin/sh ../libtool --mode=install /bin/install -c check_apt check_cluster check_disk check_dummy check_http check_load check_mrtg check_mrtgtraf check_ntp check_ntp_peer check_nwstat check_overcr check_ping check_real check_smtp check_ssh check_tcp check_time check_ntp_time check_ups check_users negate urlize check_ide_smart check_uptime check_procs check_nagios check_by_ssh check_swap check_nt '/usr/local/nagios/libexec'
libtool: install: /bin/install -c check_apt /usr/local/nagios/libexec/check_apt
libtool: install: /bin/install -c check_cluster /usr/local/nagios/libexec/check_cluster
libtool: install: /bin/install -c check_disk /usr/local/nagios/libexec/check_disk
libtool: install: /bin/install -c check_dummy /usr/local/nagios/libexec/check_dummy
libtool: install: /bin/install -c check_http /usr/local/nagios/libexec/check_http
libtool: install: /bin/install -c check_load /usr/local/nagios/libexec/check_load
libtool: install: /bin/install -c check_mrtg /usr/local/nagios/libexec/check_mrtg
libtool: install: /bin/install -c check_mrtgtraf /usr/local/nagios/libexec/check_mrtgtraf
libtool: install: /bin/install -c check_ntp /usr/local/nagios/libexec/check_ntp
libtool: install: /bin/install -c check_ntp_peer /usr/local/nagios/libexec/check_ntp_peer
libtool: install: /bin/install -c check_nwstat /usr/local/nagios/libexec/check_nwstat
libtool: install: /bin/install -c check_overcr /usr/local/nagios/libexec/check_overcr
libtool: install: /bin/install -c check_ping /usr/local/nagios/libexec/check_ping
libtool: install: /bin/install -c check_real /usr/local/nagios/libexec/check_real
libtool: install: /bin/install -c check_smtp /usr/local/nagios/libexec/check_smtp
libtool: install: /bin/install -c check_ssh /usr/local/nagios/libexec/check_ssh
libtool: install: /bin/install -c check_tcp /usr/local/nagios/libexec/check_tcp
libtool: install: /bin/install -c check_time /usr/local/nagios/libexec/check_time
libtool: install: /bin/install -c check_ntp_time /usr/local/nagios/libexec/check_ntp_time
libtool: install: /bin/install -c check_ups /usr/local/nagios/libexec/check_ups
libtool: install: /bin/install -c check_users /usr/local/nagios/libexec/check_users
libtool: install: /bin/install -c negate /usr/local/nagios/libexec/negate
libtool: install: /bin/install -c urlize /usr/local/nagios/libexec/urlize
libtool: install: /bin/install -c check_ide_smart /usr/local/nagios/libexec/check_ide_smart
libtool: install: /bin/install -c check_uptime /usr/local/nagios/libexec/check_uptime
libtool: install: /bin/install -c check_procs /usr/local/nagios/libexec/check_procs
libtool: install: /bin/install -c check_nagios /usr/local/nagios/libexec/check_nagios
libtool: install: /bin/install -c check_by_ssh /usr/local/nagios/libexec/check_by_ssh
libtool: install: /bin/install -c check_swap /usr/local/nagios/libexec/check_swap
libtool: install: /bin/install -c check_nt /usr/local/nagios/libexec/check_nt
make install-exec-hook
make[3]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins'
2.1.3.git
cd /usr/local/nagios/libexec && \
for i in check_ftp check_imap check_nntp check_pop check_udp check_clamd check_simap check_spop check_jabber check_nntps check_ssmtp ; do rm -f $i; ln -s check_tcp $i ; done ;\
if [ -x check_ldap ] ; then rm -f check_ldaps ; ln -s check_ldap check_ldaps ; fi
make[3]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins'
make[2]: Nothing to be done for `install-data-am'.
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins'
Making install in plugins-scripts
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins-scripts'
2.1.3.git
2.1.3.git
/bin/install -c check_breeze check_disk_smb check_flexlm check_ircd check_log check_oracle check_rpc check_sensors check_wave check_ifstatus check_ifoperstatus check_mailq check_file_age utils.sh utils.pm '/usr/local/nagios/libexec'
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins-scripts'
Making install in plugins-root
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/plugins-root'
2.1.3.git
2.1.3.git
/bin/install -c check_dhcp /usr/local/nagios/libexec/check_dhcp
chown root /usr/local/nagios/libexec/check_dhcp
chmod ug=rx,u+s /usr/local/nagios/libexec/check_dhcp
/bin/install -c check_icmp /usr/local/nagios/libexec/check_icmp
chown root /usr/local/nagios/libexec/check_icmp
chmod ug=rx,u+s /usr/local/nagios/libexec/check_icmp
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/plugins-root'
Making install in po
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3/po'
/bin/mkdir -p /usr/local/nagios/share
installing fr.gmo as /usr/local/nagios/share/locale/fr/LC_MESSAGES/nagios-plugins.mo
installing de.gmo as /usr/local/nagios/share/locale/de/LC_MESSAGES/nagios-plugins.mo
if test "nagios-plugins" = "gettext-tools"; then \
/bin/mkdir -p /usr/local/nagios/share/gettext/po; \
for file in Makefile.in.in remove-potcdate.sin Makevars.template; do \
/bin/install -c -m 644 ./$file \
/usr/local/nagios/share/gettext/po/$file; \
done; \
for file in Makevars; do \
rm -f /usr/local/nagios/share/gettext/po/$file; \
done; \
else \
fi
make[1]: Leaving directory `/tmp/nagios-plugins-release-2.1.3/po'
make[1]: Entering directory `/tmp/nagios-plugins-release-2.1.3'
[ec2-user@cprod nagios-plugins-release-2.1.3]$
pcouas
Post by pcouas »
LAST FOURTH command
[ec2-user@cprod nagios-plugins-release-2.1.3]$ sudo make install
darwin[56]*) \
esac ; \
else \
fi ; \
fi ; \
else \
fi ; \
fi
Making install in .
2.1.3.git
2.1.3.git
2.1.3.git
2.1.3.git
2.1.3.git
2.1.3.git
2.1.3.git
done; \
done; \
else \
fi
pcouas
Post by pcouas »
Hi
I see this in last command logs ?
checking for dustat.h... no
checking sys/fs/s5param.h presence... no
checking for sys/fs/s5param.h... no
checking sys/filsys.h usability... no
checking for statfs that truncates block counts... no
checking for sys/loadavg.h... no
