Manage Users page SQL error
ssax
Dreams In Code
Re: Manage Users page SQL error
Post by ssax »
Sounds good, thank you, we will keep an eye out.
TBT
Post by TBT »
Followed your recommendation, successfully ran on remote DB, but issues remains.
SQL Error [nagiosxi] : ERROR: column "login_attempts" does not exist
LINE 1: SELECT user_id FROM xi_users WHERE (login_attempts >= 3) AN...
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
ssax
Dreams In Code
Post by ssax »
What is the output from this command:
- Please change user/pass and xxx.xxx.xxx.xxx
echo "desc xi_users;" | mysql -unagiosxi -pnagios -h xxx.xxx.xxx.xxx nagiosxi
Thank you
TBT
Post by TBT »
ssax wrote:What is the output from this command:
Thank you
ERROR 1146 (42S02) at line 1: Table 'nagiosqldev.xi_users' doesn't exist
Can you post the following files from your Nagios XI server so we can view the settings?
/usr/local/nagiosxi/html/config.inc.php
/etc/php.ini
TBT
Post by TBT »
tgriep wrote:Can you post the following files from your Nagios XI server so we can view the settings?
/etc/php.ini
Not keen on posting login credentials. Can you be more specific on what you're looking for an I will verify?
The output from this command from a previous post failed so I wanted to verify the settings for your MYSQL server.
echo "desc xi_users;" | mysql -u nagiosxi -pnagios -h xxx.xxx.xxx.xxx nagiosxi
You can PM me the files or open a ticket by sending an email to [email protected] and we can continue there.
Thanks for the files, run this command from the XI server as root and post the output.
echo "\d+ xi_users;" | psql nagiosxi nagiosxi
TBT
Post by TBT »
Table "public.xi_users"
Column | Type | Modifiers | Storage | Description
user_id | integer | not null default nextval('xi_users_user_id_seq'::regclass) | plain |
username | character varying(64) | not null | extended |
password | character varying(64) | not null | extended |
name | character varying(64) | | extended |
email | character varying(128) | not null | extended |
backend_ticket | character varying(128) | | extended |
enabled | smallint | not null default (1)::smallint | plain |
Indexes:
"xi_users_pkey" PRIMARY KEY, btree (user_id)
"xi_users_username_key" UNIQUE, btree (username)
Has OIDs: no
If the system was recently upgraded, it looks like it did not finish because the new tables in the postgress database are missing causing the SQL error.
Depending on how the upgrade was run, the upgrade.log file could be in one of these 2 folders.
/tmp/nagiosxi/upgrade.log
/usr/local/nagiosxi/tmp/upgrade.log
Can you post them?
What version of XI is this server running?
