check_mssql doesn't work that way unfortunately. That would require altering the check_mssql plugin to add it's query results to the output message. It would likely involve changing the following block:
This is beyond the scope of the support we can provide, @mcapra showed you the part that will need to be modified. If you have a developer on your team, I would contact them.
