Please find below the screenshots attached:
Issue while monitoring Remote Linux Server
Re: Issue while monitoring Remote Linux Server
I believe the issue is here -
Since you have no repositories it does not know how to install. What is the full output of zypper lr
Warning: No repositories defined. Operating only with the installed resolvables. Nothing can be installed.
Below is the output of zypper lr :
Two options.
Create a repo file with this in it:
Or do this:
https://raymii.org/s/tutorials/VMWare_v ... tware.html
[server_monitoring]
name=Server Monitoring Software (openSUSE_13.2)
type=rpm-md
baseurl=http://download.opensuse.org/repositories/server:/monitoring/openSUSE_13.2/
gpgcheck=1
gpgkey=http://download.opensuse.org/repositories/server:/monitoring/openSUSE_13.2//repodata/repomd.xml.key
enabled=1https://raymii.org/s/tutorials/VMWare_v ... tware.html
I don't insult, I diagnose.
Thanks @ruffsense - this is correct.
@HAL - let us know if you have any further questions. You may want to contact your SuSE administrator as well to see if they can help.
