assign define hosts to specific users
baber
Re: assign define hosts to specific users
Post by baber »
dwhitfield wrote:For clarity, the anchor tag should have taken you directly to the contact section of the document.
Here is a contact example:
define contact{
	contact_name	contact_name
	minimum_value	0
	host_notifications_enabled	[0/1]
	service_notifications_enabled	[0/1]
	host_notification_period	timeperiod_name
	service_notification_period	timeperiod_name
	host_notification_options	[d,u,r,f,s,n]
	service_notification_options	[w,u,c,r,f,s,n]
	host_notification_commands	command_name
	service_notification_commands	command_name
Please let us know if you need additional examples.
Can you show the output of ls -la /usr/local/nagios/etc?
drwxrwxr-x. 8 nagios nagios  4096 Dec 12 23:22 .
drwxr-xr-x. 9 nagios nagios  4096 May 26  2016 ..
drwxr-xr-x. 2 root   root    4096 Aug  2 22:41 backup
-rw-rw-r--. 1 nagios nagios 12374 Dec 12 22:16 cgi.cfg
-rw-rw-r--. 1 nagios nagios 12267 May 26  2016 cgi.cfg~
drwxr-xr-x. 2 root   root    4096 Dec  8 17:38 Esxi
-rw-r--r--. 1 root   root      64 Dec 12 22:01 htpasswd.users
drwxr-xr-x. 2 root   root    4096 Dec  8 23:02 linux
drwxr-xr-x. 2 root   root    4096 Dec  5 17:46 MSA
-rw-r--r--. 1 root   root   51525 Dec 12 21:52 nagios.cfg
-rw-rw-r--. 1 nagios nagios 44831 May 26  2016 nagios.cfg~
-rw-r--r--. 1 nagios nagios  8860 Sep 22 16:47 nrpe.cfg
drwxrwxr-x. 2 nagios nagios  4096 Dec  5 20:04 objects
-rw-rw----. 1 nagios nagios  1343 Aug 10 01:40 resource.cfg
-rw-rw----. 1 nagios nagios  1312 May 26  2016 resource.cfg~
drwxr-xr-x. 2 root   root    4096 Dec 12 23:22 windows
Also, can you post your nagios.cfg and contacts.cfg?
i have attached contact.cfg file
contacts.cfg
(2.65 KiB) Downloaded 611 times
Post by dwhitfield »
Your contacts.cfg is in another directory, but I can't tell where it should be because you didn't upload your nagios.cfg. If you'd prefer to PM it, that will work. Just make sure you update this thread after you PM it.
UPDATE: nagios.cfg received and shared with techs
ssax
Dreams In Code
Post by ssax »
Multi-tenancy is the key, please read this document:
See here as well:
https://assets.nagios.com/downloads/nag ... Rights.pdf
Note:
If you apply a contact/contactgroup to the host they will automatically be able to view all services attached to that host, this is by design, if you do not want a user to see all services you will only be able to add the contact/contactgroups on the services and NOT on the host.
Let us know if you have any questions.
Thank you
baber
Post by baber »
dwhitfield wrote:Your contacts.cfg is in another directory, but I can't tell where it should be because you didn't upload your nagios.cfg. If you'd prefer to PM it, that will work. Just make sure you update this thread after you PM it.
i have sent PM and attach nagios.cfg
What's the output of ls -la /usr/local/nagios/etc/objects? Looks like your contacts.cfg should be in there.
Also, did you read through the documentation @ssax sent?
baber
Post by baber »
dwhitfield wrote:What's the output of ls -la /usr/local/nagios/etc/objects? Looks like your contacts.cfg should be in there.
i know my contact.cfg file is that
drwxrwxr-x. 2 nagios nagios  4096 Dec  5 20:04 .
drwxrwxr-x. 8 nagios nagios  4096 Dec 12 23:22 ..
-rw-rw-r--. 1 nagios nagios 10862 Dec  5 22:03 commands.cfg
-rw-rw-r--. 1 nagios nagios  7688 May 26  2016 commands.cfg~
-rw-rw-r--. 1 nagios nagios  2711 Dec 13 00:11 contacts.cfg
-rw-rw-r--. 1 nagios nagios  2138 May 26  2016 contacts.cfg~
-rw-r--r--. 1 root   root     972 Dec 12 23:22 hostgroup.cfg
-rw-rw-r--. 1 nagios nagios  5375 May 26  2016 localhost.cfg
-rw-rw-r--. 1 nagios nagios  5375 May 26  2016 localhost.cfg~
-rw-rw-r--. 1 nagios nagios  3096 May 26  2016 printer.cfg
-rw-rw-r--. 1 nagios nagios  3096 May 26  2016 printer.cfg~
-rw-rw-r--. 1 nagios nagios  3265 May 26  2016 switch.cfg
-rw-rw-r--. 1 nagios nagios  3265 May 26  2016 switch.cfg~
-rw-rw-r--. 1 nagios nagios 20903 Dec 13 00:05 templates.cfg
-rw-rw-r--. 1 nagios nagios 10621 May 26  2016 templates.cfg~
-rw-rw-r--. 1 nagios nagios  3180 May 26  2016 timeperiods.cfg
-rw-rw-r--. 1 nagios nagios  3180 May 26  2016 timeperiods.cfg~
-rw-rw-r--. 1 nagios nagios  3991 May 26  2016 windows.cfg
-rw-rw-r--. 1 nagios nagios  3991 May 26  2016 windows.cfg~
but i don't know what do i have to add in contact.cfg file and what do i have to add in other files for that babak can see specific host or service
please write an example
and i want babak just see this host
	use		windows-server			; Inherit default values from a template
	host_name	DB-Asisstant				; The name we're giving to this host
	alias		server DB-Asisstant			; A longer name associated with the host
	address		10.10.10.10			; IP address of the host
	use					local-service
	service_description			Memory Usage
	check_command				check_nt!MEMUSE!-w 90 -c 95
	use					local-service
	service_description			SqlServer
	check_command				check_nt!SERVICESTATE!-d SHOWALL -l MSSQLSERVER
	use					local-service
	service_description			Cpu Usage
	check_command				check_nrpe!alias_cpu
	use					local-service
	service_description			Disk Space
	check_command				check_nrpe!alias_volumes
	use					local-service
	service_description			Time
	check_command				check_nrpe!check_windows_time
ssax
Dreams In Code
Post by ssax »
baber, even though the links I posted were for XI they are still very relevant to Nagios Core, did you read through them (at least the multi-tenancy one)?
baber
Post by baber »
ssax wrote:baber, even though the links I posted were for XI they are still very relevant to Nagios Core, did you read through them (at least the multi-tenancy one)?
Yes i read that but previously said confused i have been paste all configs on previous post now please help me
define contact{
	minimum_value	0
Your answer can be found above, and also in the documentation @ssax linked. What specifically are you having issues with?
baber wrote:Yes i read that but previously said confused
Have you seen the documentation on how a host is defined?
https://assets.nagios.com/downloads/nag ... .html#host
You will need to add the contact name to the contacts field in your host definition if you want the contact to be able to see that host.
