If you don't see what you need at https://assets.nagios.com/downloads/nag ... olist.html then you should file a feature request at https://github.com/NagiosEnterprises/na ... issues/new
If you think this is better suited for a plugin, the plugin development guidelines are at http://nagios-plugins.org/doc/guidelines.html
I hate to be the bearer of bad news, but there are a number of security vulnerabilities that have been fixed since 4.0.7. I would highly advise upgrading to 4.2.4. Also, RHEL 5 goes EOL in March, so if you haven't already, it's time to migrate off of that.
Event Handling using monitoring status as condition.
- Former Nagios Staff
doubleclick
Re: Event Handling using monitoring status as condition.
Understood.
Thank you @dwhitfield and everyone else for your time and for providing valuable support for free.
Best wishes for 2017.
@doubleclick, do you want to lock this thread up? If you do decide to develop a plugin, we have a separate part of the forum for that: https://support.nagios.com/forum/viewforum.php?f=35
doubleclick
Yes, please feel free to lock it up (unless this is something i can do from here?).
Thank you again for the help.
