New Contacts - Notification
mguthrie
Re: New Contacts - Notification
Post by mguthrie »
If you're going to manually set up contacts in Nagios XI, take a look at the following doc for how the definitions should be set up.
http://assets.nagios.com/downloads/nagi ... ndcontacts
Amir
Post by Amir »
Hi there:
Thanks for your help so far guys
should I just create a Nagios user and I hope this will work ?
Regards
Amir
Notifications should work fine for a Nagios user.
Amir
Post by Amir »
Hi there:
Thanks for your help; it seems it is working for Nagios User
Regards
AMir
newmeadow
Post by newmeadow »
I had the same issue. I did not want to create a user for everyone but I had to to get it working. I just wanted to add to notifications but only way was to add as user.
costha
Post by costha »
Hello, did anyone solve this issue?
I'm finding a way how to send notification for NON nagios user, because I have to sending it to lot of people and I don't want to creating user for everyone.... I had copy contact from nagios user contatct, but notification going only to contact with nagios user, not for ONLY contact. BUT when i check Notification log (Home>Incident management> notifications) it shows notification went to that contact. Where is difference? Why nagios sent notification for nagios users and NO for only contacts?
Thank you very much
Costha
