UNKNOWN SNMP::get_request(SubsystemName): Received noSuchName(2) error-status at error-index 1 Code: Select all
UNKNOWNCode: Select all
command_name check_fujitsu_server
command_line $USER1$/check_fujitsu_server.pl -H $HOSTADDRESS$ -A $ARG1$ $ARG2$ $ARG3$
} Code: Select all
./check_fujitsu_server.pl -H Infra1 -A 10.0.5.15 -C public --chkenv-fanCode: Select all
command_line $USER1$/check_fujitsu_server.pl -H $HOSTADDRESS$ -A $ARG1$ $ARG2$ $ARG3$Code: Select all
command_line $USER1$/check_fujitsu_server.pl -H $HOSTADDRESS$ -t 59 -A $ARG1$ $ARG2$ $ARG3$Code: Select all
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra3 -A 10.0.5.17 -C public --chkenv-fan -v 1
UNKNOWN SNMP::get_request(ServerID): Received noSuchName(2) error-status at error-index 1
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra3 -A 10.0.5.17 -C public --chkenv-fan -v 2
UNKNOWN SNMP::get_request(ServerID): Received noSuchName(2) error-status at error-index 1Code: Select all
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra2 -A 10.0.5.16 -C public --chkenv-temp
OK TemperatureSensors(ok)
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra2 -A 10.0.5.16 -C public --chkenv-temp -v 1
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra2 -A 10.0.5.16 -C public --chkenv-temp -v 2
ID=YLNS015489 Systemname=INFRA2 Description="Primergy iRMC S4 #1 Wed Aug 5 12:38:56 CEST 2015" Location="Unknown" Contact="root@localhost" SpecifiedAddress=Infra2 AdminAddress=10.0.5.16
* Temperature Sensors:
./check_fujitsu_server.pl -H Infra3 -A 10.0.5.17 -t 120 -C public --chkenv-fan
./check_fujitsu_server.pl -H Infra2 -A 10.0.5.16 -t 120 -C public --chkenv-tempCode: Select all
[root@telematics ~]# cd /usr/local/nagios/libexec/
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra3 -A 10.0.5.17 -t 120 -C public --chkenv-fan
[root@telematics libexec]# ./check_fujitsu_server.pl -H Infra2 -A 10.0.5.16 -t 120 -C public --chkenv-temp
| Ambient=21C;37;42 Systemboard=44C;75;80 VR_CPU1=41C;120;125 VR_MEM_AB=29C;120;125 VR_MEM_CD=39C;120;125 VR_CPU2=31C;120;125 VR_MEM_EF=34C;120;125 VR_MEM_GH=26C;120;125 CPU1=39C;82;83 MEM_A=27C;78;82 PSU1_Inlet=35C;57;61 PSU2_Inlet=36C;57;61 PSU1=61C;102;107 PSU2=61C;102;107
OK TemperatureSensors(ok)Code: Select all
OK Cooling(ok)
