You don't have permission to access /nagios/ on this server.
sachinambardekar
Re: You don't have permission to access /nagios/ on this ser
I am the one who has installed and configured http and I am new to this. So if you can one more time explain me what exactly I need to do that would be of great help.
Thank you,
Sachin A
Thank you,
Sachin A
See my original post as it answers your question -
rkennedy wrote:I believe the issue is here -You'll want to consult whomever setup apache, or take a look at this article to see if it helps - http://stackoverflow.com/questions/5301 ... -directiveCode: Select all
Directory index forbidden by Options directive
[/code]
- Former Nagios Staff
For clarity on what @rkennedy said, the problem is we don't know the other software you have set up.
If it were me, I'd set up a VM and run Nagios by itself and avoid a complicated Apache config, but every organization has different policies about these things.
sachinambardekar
Let me create another VM and try to install nagios on fresh installation. I will update this post if I ran into any issue.
Thank you,
Sachin A
Thank you,
Sachin A
Sounds good - the best guides for installing can be found here - https://support.nagios.com/kb/category.php?id=58
Let us know if you run into any issues. I suspect it'll work without a problem though.
sachinambardekar
Support,
As per your suggestion followed step - by - step instructions from https://support.nagios.com/kb/article.p ... ategory=58 and installed the nagios as well as nagios-plugin, however, while validating the plugin I am getting below error. Uploaded error screenshot as well as cgi.cfg file from /usr/local/nagios/etc
It appears as though you do not have permission to view information for any of the hosts you requested...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file.
Please advise.
Thank you,
Sachin A
Please advise.
Thank you,
Sachin A
cgi.cfg- (12.45 KiB) Downloaded 509 times
Nagios Command error.docx- (159.37 KiB) Downloaded 350 times
Do you have hosts / services configured on the system? What is the full output of this? /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
sachinambardekar
[root@hdputils ~]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.2.2
Last Modified: 10-24-2016
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 8 services.
Checked 1 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 1 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
[root@hdputils ~]# ps -ef|grep nagios
nagios 1814 1 0 10:48 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 1818 1814 0 10:48 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1819 1814 0 10:48 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1820 1814 0 10:48 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 1821 1814 0 10:48 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 2006 1814 0 10:48 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root 2033 2013 0 10:48 pts/0 00:00:00 grep nagios
[root@hdputils ~]# ps -ef|grep httpd
root 1694 1 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1715 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1716 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1717 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1718 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1719 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1720 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1721 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
apache 1722 1694 0 10:48 ? 00:00:00 /usr/sbin/httpd
root 2035 2013 0 10:48 pts/0 00:00:00 grep httpd
Please advise.
Thank you,
Sachin A
Nagios Core 4.2.2
License: GPL
Checking objects...
Checked 8 services.
Checked 1 hosts.
Checked 1 contacts.
Checked 1 hosts
Total Warnings: 0
Total Errors: 0
Please advise.
Thank you,
Sachin A
It looks like you do indeed have a host group so it should be working, could you post the entire /usr/local/nagios/var/objects.cache file for us to review? We'll need to make sure 'nagiosadmin' is indeed a contact on the localhost host group, and that it's a contact of it too.
sachinambardekar
Uploaded the requested file. Please advise.
Thank you,
Sachin A
Thank you,
Sachin A
