Check_exi command setup
ssax
Dreams In Code
Re: Check_exi command setup
Post by ssax »
Does your username or password have special characters in it? If so, you might try surrounding them with single quotes:
--username 'xxxx' --password 'xxxx'
I found a link that says the following perl module (IO::Compress::Zlib::Extra) needs to be updated.
Login to the server as root and run the following command to do that.
cpan IO::Compress::Zlib::Extra
scheema31
Post by scheema31 »
tgriep - I ran the perl module update which completed, ran the command again and this time i don't get an error but command does not return anything either, just waiting for input... ive attached screenshot
ssax - thanks for the suggestion but my username nor password contain special characters, however i tried it with single quotes but that did not help.
thanks!
It looks like if you do not specify a Virtual Machine, or a Datastore, etc., the plugin will walk through all of the hosts and guests in your VMWare network so it could take a long time to run.
Try using specific guests, datastores in the command and that should make it run faster.
scheema31
Post by scheema31 »
Excellet!
it worked when running on my server :)
[root@someserver ~]# /usr/local/nagios/libexec/check_esx3.pl --hostIP 10.10.xx.xx --dataType Datastore --datacenter /vmfs/volumes/somedatastore_01 --username user --password pass --warning 80 --critical 90
MYDATASTORE_01 : 84 % Used MYDATASTORE_02 : 83 % Used
now how should my command line looks for it to run on web? i dont think what i have is correct:
		command_name check_esx_datastore
		command_line $USER1$/check_esx3.pl -H $HOSTADDRESS$ -u $ESXUSER$ -p $ESXPASSWORD$ -l datastore -s usage -w $ARG1$ -c $ARG2$ }
	use 			        Generic-services
	host_name 		SV-VMHOST-02
	service_description 	Datastore MYDATASTORE
	check_command 	check_esx_datastore!80!90  }
You could create your command like the example below. You may have to tweak it to get it to work.
command_line $USER1$/check_esx3.pl --hostIP $HOSTADDRESS$ --dataType Datastore --datacenter /vmfs/volumes/somedatastore_01 --username $ESXUSER$ --password $ESXPASSWORD$ --warning $ARG1$ --critical $ARG2$
scheema31
Post by scheema31 »
thanks that made some progress, i can make checks but returns a warning state with an error (attached picture)
looks like another plugin install/update?
thanks!
Yes, looks like another perl module needs to be installed.
Run this as root to install that
yum install perl-Crypt-SSLeay -y
Most sites you download plugins from, should have instructions on installing and creating commands, take a look at them for more details.
scheema31
Post by scheema31 »
Perfect that did the trick, my checks are now successful on server and through browser.
Thanks for all your help Tgriep!
That is good to hear. I'll close and lock this post as solved. If you have any other issues / questions, feel free to open a new post.
