tnx for your helprkennedy wrote:I filed a feature request for the ability to have read-only users be able to see the object definition. The ID is #10762.
The one concern I have about this though, is that a read-only user will be able to see credentials that could be contained in the check_command - which may not be something a read-only user should have access to.
Trying to find the best way to pull information
Re: Trying to find the best way to pull information
Did you have additional questions regarding this issue, or can we close this thread since a feature request was submit?
you can close it
