NRDS download or wget not working
garethwithers
Re: NRDS download or wget not working
I have tried to do this with no joy.
Did it on a clean build with a new install of XI, everything else seems to be working as well.
Gareth
Gareth
- Former Nagios Staff
On the new one, what's the output of ls -laR /usr/local/nrdp >/tmp/ls.txt?
Does everything look the same between the two servers?
garethwithers
Hi dwhitfield
There certainly looks more files there than before
Heres the file as requested:
Can we get a fresh set of your apache logs? The ones we currently have are a bit old and don't reflect the new changes:
/var/log/httpd/error_log
/var/log/httpd/ssl_error_log
/var/log/httpd/access_log
/var/log/httpd/ssl_access_logFormer Nagios employee
garethwithers
As requested please find the attached
Appreciate all the help
This definitely stands out:
That probably shouldn't be returning a 404. I was able to replicate this on my Nagios XI machine.
Just to verify I understand exactly what's going on, can you share the outputs of the following commands:
And afterwards, run this command and see if it fixes the problem:
172.29.130.22 - - [06/Mar/2017:14:20:31 +0000] "GET /nrdp/?cmd=nrdsgetclient&token=<token>&configname=<config_name>HTTP/1.1" 404 - "http://vapngoa101/nagiosxi/includes/components/nrdsconfigmanager/nrdsconfigmanager.php" "Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.76 Safari/537.36"Just to verify I understand exactly what's going on, can you share the outputs of the following commands:
ls -d -1 /usr/local/nrdp/** | xargs ls -al
cat config.inc.php | grep tmp
sed -i "2i\$cfg['tmp_dir'] = '/tmp';" /usr/local/nrdp/server/config.inc.phpFormer Nagios employee
garethwithers
Afternoon
That has worked and i have included the file for you to look at:
Thanks a lot for the help, if you could let me know the issue that would be great! just so i can know the cause if it was something we did wrong.
Regards
Gareth
Regards
Gareth
The issue is a known bug with NRDP that will be fixed in a future version. Sorry for the confusion it may have caused!
Did you have additional questions regarding this issue, or can we close this thread and mark it as resolved?
garethwithers
Hi mcapra
No problem at all thanks a lot for the help and assistance.
Yes you can close the ticket off.
Gareth
Gareth
