nagiosgraph is not ours. Sometimes it takes third-party apps a while to catch up with our new code.
If you have logs of how much time you are spending, you could probably make a good case to management to get an XI license. You might as well download the 60-day demo from https://www.nagios.com/products/nagios-xi/ and see if you like it better. Migrating isn't the easiest thing in the world (mostly because people do all sorts of crazy things with Core), but it's certainly doable: https://assets.nagios.com/downloads/nag ... ios_XI.pdf
Missing /nagios/cgi-bin/statusmap.cgi was not foun
- Former Nagios Staff
neworderfac33
Re: Missing /nagios/cgi-bin/statusmap.cgi was not foun
Good morning - I've come in today and the red mist has lifted a little!
I finally got rid of the error message!
- it was, as I suspected, all about dependencies - you need gd-devel.
When I tried to install gd-devel using the .rpm that I'd previously downloaded, it flagged up a number of dependecies, so then I did:
Then, I installed the gd-devel rpm:
THEN, I compiled:
Whilst this didn't create statusmap.cgi in /usr/local/nagios/sbin/statusmap.cgi, it DID create it in the /cgi folder of my nagios source folder, in this case, /home/downloads/nagios-4.2.4/cgi
So then, I copied THAT file with:
verfied my configuration and restarted Nagios.
When I try to view the status map... I get one!
I hope this helps someone else out there and apologies for the tantrum!
Pete
yum install fontconfig-devel
yum install freetype-devel
yum install libX11-devel
yum install libXpm-devel
yum install libjpeg-devel
yum install libpng-devel
rpm -ivh gd-devel-2.0.35-26.el7.x86_64.rpm
./configure
make all
cp /home/downloads/nagios-4.2.4/cgi/statusmap.cgi /usr/local/nagios/sbin/statusmap.cgi
Pete
Last edited by neworderfac33 on Thu Jan 26, 2017 10:39 am, edited 2 times in total.
Thanks so much for posting that. Do you want to go ahead and lock this thread up?
neworderfac33
Yep - the thread can be locked.
