nagios service would not start
btemple
Re: nagios service would not start
Post by btemple »
So we found about 18 items host / services in the nagios.log that had warnings. 2 hosts did not have a contact or notifications interval etc. In the past we would get a config error and not be able to apply the config. We also found 5 that had duplicate service names
We fixed all the errors then applied the config and the nagios service stayed stable. We have since run a manual backup and are keeping an eye on the logs.
Is it possible that the pre-check should have failed but allowed us to apply the config anyway, and then later the bad config caused the service to stop and not be able to restart ?
btemple
Post by btemple »
we tried to delete a host WHLCTX2 and that stopped the nagios service and it would not start again
btemple
Post by btemple »
So I restored and everything is good. I went back to delete the host WHLCTX2 but this time remembered to check for dependent relationships.
I then removed those relationships and deleted the host. Nagios is now still running.
It appears that the "cannot delete because of dependent relationships" banner / warning may not be functioning .....
btemple
Post by btemple »
So after a few more changes it failed again
Can you show us a screenshot of the exact error you're seeing at this point?
btemple
Post by btemple »
Ok we have decided to migrate to a new host. Our current platform is about 3 years old and was re-purposed at that time.
Can you provide guidance in a clean migration that doesn't include our current database. Meaning all checks and hosts ? We would like to keep all bandwidth .rrd files to if possible.
Please let me know what you guys think. I do not trust our current mysql to migrate without keeping the corruption.
Also what do you think about theses specs /
4 cpu 16 gb of ram 160 gb disk (vmware)
Wxnagios01 = 600 hosts 4704 checks
avandemore
Post by avandemore »
Honestly, the easiest thing to do is a full backup / restore:
The find the large tables:
mysql -uroot -pnagiosxi -e 'SELECT table_schema as `Database`, table_name AS `Table`, round(((data_length + index_length) / 1024 / 1024), 2) `Size in MB` FROM information_schema.TABLES ORDER BY (data_length + index_length) DESC;'
And truncate the large tables.
https://assets.nagios.com/downloads/nag ... tabase.pdf
Previous Nagios employee
btemple
Post by btemple »
So this is our plan
Go from centos 6.8 to Red Hat 7
can this be used a straight back / restore type migration ?
avandemore
Yes as long as the XI versions match. You can upgrade the new install later if need be.
