ad tls auth
WVUhealth
Re: ad tls auth
Post by WVUhealth »
no still did not work
Re: ad tls auth
Post by mcapra »
This might be an OpenSSL version issue. Can you share the output of:
php -r 'phpinfo();'
openssl version
WVUhealth
Re: ad tls auth
Post by WVUhealth »
phpinfo()
PHP Version => 5.4.16
System => Linux ########### 3.10.0-514.6.1.el7.x86_64 #1 SMP Sat Dec 10 11:15:38 EST 2016 x86_64
Build Date => Aug  5 2016 07:50:33
Server API => Command Line Interface
Virtual Directory Support => disabled
Configuration File (php.ini) Path => /etc
Loaded Configuration File => /etc/php.ini
Scan this dir for additional .ini files => /etc/php.d
Additional .ini files parsed => /etc/php.d/curl.ini,
/etc/php.d/fileinfo.ini,
/etc/php.d/json.ini,
/etc/php.d/ldap.ini,
/etc/php.d/phar.ini,
/etc/php.d/sourceguardian.ini,
/etc/php.d/zip.ini
PHP API => 20100412
PHP Extension => 20100525
Zend Extension => 220100525
Zend Extension Build => API220100525,NTS
PHP Extension Build => API20100525,NTS
Debug Build => no
Thread Safety => disabled
Zend Signal Handling => disabled
Zend Memory Manager => enabled
Zend Multibyte Support => disabled
IPv6 Support => enabled
DTrace Support => disabled
Registered PHP Streams => https, ftps, compress.zlib, compress.bzip2, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports => tcp, udp, unix, udg, ssl, sslv3, sslv2, tls
Registered Stream Filters => zlib.*, bzip2.*, convert.iconv.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk
This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.4.0, Copyright (c) 1998-2013 Zend Technologies
 _______________________________________________________________________
Configuration
bz2
BZip2 Support => Enabled
Stream Wrapper support => compress.bzip2://
Stream Filter support => bzip2.decompress, bzip2.compress
BZip2 Version => 1.0.6, 6-Sept-2010
calendar
Calendar support => enabled
Core
Directive => Local Value => Master Value
allow_url_fopen => On => On
allow_url_include => Off => Off
always_populate_raw_post_data => Off => Off
arg_separator.input => & => &
arg_separator.output => & => &
asp_tags => Off => Off
auto_append_file => no value => no value
auto_globals_jit => On => On
auto_prepend_file => no value => no value
browscap => no value => no value
default_charset => no value => no value
default_mimetype => text/html => text/html
disable_classes => no value => no value
disable_functions => no value => no value
display_errors => Off => Off
display_startup_errors => Off => Off
doc_root => no value => no value
docref_ext => no value => no value
docref_root => no value => no value
enable_dl => Off => Off
enable_post_data_reading => On => On
error_append_string => no value => no value
error_log => no value => no value
error_prepend_string => no value => no value
error_reporting => 22527 => 22527
exit_on_timeout => Off => Off
expose_php => On => On
extension_dir => /usr/lib64/php/modules => /usr/lib64/php/modules
file_uploads => On => On
highlight.comment => <font style="color: #FF8000">#FF8000</font> => <font style="color: #FF8000">#FF8000</font>
highlight.default => <font style="color: #0000BB">#0000BB</font> => <font style="color: #0000BB">#0000BB</font>
highlight.html => <font style="color: #000000">#000000</font> => <font style="color: #000000">#000000</font>
highlight.keyword => <font style="color: #007700">#007700</font> => <font style="color: #007700">#007700</font>
highlight.string => <font style="color: #DD0000">#DD0000</font> => <font style="color: #DD0000">#DD0000</font>
html_errors => Off => Off
ignore_repeated_errors => Off => Off
ignore_repeated_source => Off => Off
ignore_user_abort => Off => Off
implicit_flush => On => On
include_path => .:/usr/share/pear:/usr/share/php => .:/usr/share/pear:/usr/share/php
log_errors => On => On
log_errors_max_len => 1024 => 1024
mail.add_x_header => On => On
mail.force_extra_parameters => no value => no value
mail.log => no value => no value
max_execution_time => 0 => 0
max_file_uploads => 20 => 20
max_input_nesting_level => 64 => 64
max_input_time => -1 => -1
max_input_vars => 1000 => 1000
memory_limit => 128M => 128M
open_basedir => no value => no value
output_buffering => 0 => 0
output_handler => no value => no value
post_max_size => 8M => 8M
precision => 14 => 14
realpath_cache_size => 16K => 16K
realpath_cache_ttl => 120 => 120
register_argc_argv => On => On
report_memleaks => On => On
report_zend_debug => Off => Off
request_order => GP => GP
sendmail_from => no value => no value
sendmail_path => /usr/sbin/sendmail -t -i => /usr/sbin/sendmail -t -i
serialize_precision => 17 => 17
short_open_tag => Off => Off
SMTP => localhost => localhost
smtp_port => 25 => 25
sql.safe_mode => Off => Off
track_errors => Off => Off
unserialize_callback_func => no value => no value
upload_max_filesize => 2M => 2M
upload_tmp_dir => no value => no value
user_dir => no value => no value
user_ini.cache_ttl => 300 => 300
user_ini.filename => .user.ini => .user.ini
variables_order => GPCS => GPCS
xmlrpc_error_number => 0 => 0
xmlrpc_errors => Off => Off
zend.detect_unicode => On => On
zend.enable_gc => On => On
zend.multibyte => Off => Off
zend.script_encoding => no value => no value
ctype
ctype functions => enabled
curl
cURL support => enabled
cURL Information => 7.29.0
Age => 3
Features
AsynchDNS => Yes
Debug => No
GSS-Negotiate => Yes
IDN => Yes
IPv6 => Yes
Largefile => Yes
NTLM => Yes
SPNEGO => No
SSL => Yes
SSPI => No
krb4 => No
libz => Yes
CharConv => No
Protocols => dict, file, ftp, ftps, gopher, http, https, imap, imaps, ldap, ldaps, pop3, pop3s, rtsp, scp, sftp, smtp, smtps, telnet, tftp
Host => x86_64-redhat-linux-gnu
SSL Version => NSS/3.21 Basic ECC
ZLib Version => 1.2.7
libSSH Version => libssh2/1.4.3
date
date/time support => enabled
"Olson" Timezone Database Version => 0.system
Timezone Database => internal
Default timezone => US/Eastern
date.default_latitude => 31.7667 => 31.7667
date.default_longitude => 35.2333 => 35.2333
date.sunrise_zenith => 90.583333 => 90.583333
date.sunset_zenith => 90.583333 => 90.583333
date.timezone => US/Eastern => US/Eastern
ereg
Regex Library => Bundled library enabled
exif
EXIF Support => enabled
EXIF Version => 1.4 $Id$
Supported EXIF Version => 0220
Supported filetypes => JPEG,TIFF
exif.decode_jis_intel => JIS => JIS
exif.decode_jis_motorola => JIS => JIS
exif.decode_unicode_intel => UCS-2LE => UCS-2LE
exif.decode_unicode_motorola => UCS-2BE => UCS-2BE
exif.encode_jis => no value => no value
exif.encode_unicode => ISO-8859-15 => ISO-8859-15
fileinfo
fileinfo support => enabled
version => 1.0.5
filter
Input Validation and Filtering => enabled
Revision => $Id: 2aa8dd57d9c0c655cd45e6e5872bb95fa5ad76cf $
filter.default => unsafe_raw => unsafe_raw
filter.default_flags => no value => no value
ftp
FTP support => enabled
gettext
GetText Support => enabled
gmp
gmp support => enabled
GMP version => 6.0.0
hash
hash support => enabled
Hashing Engines => md2 md4 md5 sha1 sha224 sha256 sha384 sha512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost adler32 crc32 crc32b fnv132 fnv164 joaat haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
iconv
iconv support => enabled
iconv implementation => glibc
iconv library version => 2.17
iconv.input_encoding => ISO-8859-1 => ISO-8859-1
iconv.internal_encoding => ISO-8859-1 => ISO-8859-1
iconv.output_encoding => ISO-8859-1 => ISO-8859-1
json
json support => enabled
json version => 1.2.1
ldap
LDAP Support => enabled
RCS Version => $Id$
Total Links => 0/unlimited
API Version => 3001
Vendor Name => OpenLDAP
Vendor Version => 20440
SASL Support => Enabled
ldap.max_links => Unlimited => Unlimited
libxml
libXML support => active
libXML Compiled Version => 2.9.1
libXML Loaded Version => 20901
libXML streams => enabled
mhash
MHASH support => Enabled
MHASH API Version => Emulated Support
openssl
OpenSSL support => enabled
OpenSSL Library Version => OpenSSL 1.0.1e-fips 11 Feb 2013
OpenSSL Header Version => OpenSSL 1.0.1e-fips 11 Feb 2013
pcntl
pcntl support => enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support => enabled
PCRE Library Version => 8.32 2012-11-30
pcre.backtrack_limit => 1000000 => 1000000
pcre.recursion_limit => 100000 => 100000
Phar
Phar: PHP Archive support => enabled
Phar EXT version => 2.0.1
Phar API version => 1.1.1
SVN revision => $Id: c5042cc34acebcc0926625b57dff03deebbe6472 $
Phar-based phar archives => enabled
Tar-based phar archives => enabled
ZIP-based phar archives => enabled
gzip compression => enabled
bzip2 compression => enabled
Native OpenSSL support => enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_list => no value => no value
phar.readonly => On => On
phar.require_hash => On => On
readline
Readline Support => enabled
Readline library => EditLine wrapper
cli.pager => no value => no value
cli.prompt => \b \>  => \b \>
Reflection
Reflection => enabled
Version => $Id: 6c4d8062369898a397e4b128348042f5c01b4427 $
session
Session Support => enabled
Registered save handlers => files user
Registered serializer handlers => php php_binary
session.auto_start => Off => Off
session.cache_expire => 180 => 180
session.cache_limiter => nocache => nocache
session.cookie_domain => no value => no value
session.cookie_httponly => Off => Off
session.cookie_lifetime => 0 => 0
session.cookie_path => / => /
session.cookie_secure => Off => Off
session.entropy_file => /dev/urandom => /dev/urandom
session.entropy_length => 32 => 32
session.gc_divisor => 1000 => 1000
session.gc_maxlifetime => 1440 => 1440
session.gc_probability => 1 => 1
session.hash_bits_per_character => 5 => 5
session.hash_function => 0 => 0
session.name => PHPSESSID => PHPSESSID
session.referer_check => no value => no value
session.save_handler => files => files
session.save_path => no value => no value
session.serialize_handler => php => php
session.upload_progress.cleanup => On => On
session.upload_progress.enabled => On => On
session.upload_progress.freq => 1% => 1%
session.upload_progress.min_freq => 1 => 1
session.upload_progress.name => PHP_SESSION_UPLOAD_PROGRESS => PHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefix => upload_progress_ => upload_progress_
session.use_cookies => On => On
session.use_only_cookies => On => On
session.use_trans_sid => 0 => 0
shmop
shmop support => enabled
SimpleXML
Simplexml support => enabled
Revision => $Id: 692516840b2d7d6e7aedb0bedded1f53b764a99f $
Schema support => enabled
sockets
Sockets Support => enabled
SourceGuardian
SourceGuardian Loader Support => enabled
SourceGuardian Loader Version => 10.1.5
SourceGuardian Loader Build Number => 0x00000016
phpSHIELD Support => enabled
sourceguardian.restrict_unencoded => 0 => 0
SPL
SPL support => enabled
Interfaces => Countable, OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes => AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
standard
Dynamic Library Support => enabled
Path to sendmail => /usr/sbin/sendmail -t -i
assert.active => 1 => 1
assert.bail => 0 => 0
assert.callback => no value => no value
assert.quiet_eval => 0 => 0
assert.warning => 1 => 1
auto_detect_line_endings => 0 => 0
default_socket_timeout => 60 => 60
url_rewriter.tags => a=href,area=href,frame=src,input=src,form=fakeentry => a=href,area=href,frame=src,input=src,form=fakeentry
user_agent => no value => no value
tokenizer
Tokenizer Support => enabled
xml
XML Support => active
XML Namespace Support => active
libxml2 Version => 2.9.1
zip
Zip => enabled
Extension Version => $Id: 0c033d4e4613d577409950ed7bf8da4b68286d15 $
Zip version => 1.11.0
Compiled against libzip version => 0.10.1
zlib
ZLib Support => enabled
Stream Wrapper => compress.zlib://
Stream Filter => zlib.inflate, zlib.deflate
Compiled Version => 1.2.7
Linked Version => 1.2.7
zlib.output_compression => Off => Off
zlib.output_compression_level => -1 => -1
zlib.output_handler => no value => no value
Additional Modules
Module Name
Environment
Variable => Value
XDG_SESSION_ID => 2807
HOSTNAME => XXXXXXXXXX
TERM => xterm-256color
SHELL => /bin/bash
HISTSIZE => 1000
SSH_CLIENT => 10.3.9.27 56056 22
SSH_TTY => /dev/pts/1
USER => root
LS_COLORS => rs=0:di=38;5;27:ln=38;5;51:mh=44;38;5;15:pi=40;38;5;11:so=38;5;13:do=38;5;5:bd=48;5;232;38;5;11:cd=48;5;232;38;5;3:or=48;5;232;38;5;9:mi=05;48;5;232;38;5;15:su=48;5;196;38;5;15:sg=48;5;11;38;5;16:ca=48;5;196;38;5;226:tw=48;5;10;38;5;16:ow=48;5;10;38;5;21:st=48;5;21;38;5;15:ex=38;5;34:*.tar=38;5;9:*.tgz=38;5;9:*.arc=38;5;9:*.arj=38;5;9:*.taz=38;5;9:*.lha=38;5;9:*.lz4=38;5;9:*.lzh=38;5;9:*.lzma=38;5;9:*.tlz=38;5;9:*.txz=38;5;9:*.tzo=38;5;9:*.t7z=38;5;9:*.zip=38;5;9:*.z=38;5;9:*.Z=38;5;9:*.dz=38;5;9:*.gz=38;5;9:*.lrz=38;5;9:*.lz=38;5;9:*.lzo=38;5;9:*.xz=38;5;9:*.bz2=38;5;9:*.bz=38;5;9:*.tbz=38;5;9:*.tbz2=38;5;9:*.tz=38;5;9:*.deb=38;5;9:*.rpm=38;5;9:*.jar=38;5;9:*.war=38;5;9:*.ear=38;5;9:*.sar=38;5;9:*.rar=38;5;9:*.alz=38;5;9:*.ace=38;5;9:*.zoo=38;5;9:*.cpio=38;5;9:*.7z=38;5;9:*.rz=38;5;9:*.cab=38;5;9:*.jpg=38;5;13:*.jpeg=38;5;13:*.gif=38;5;13:*.bmp=38;5;13:*.pbm=38;5;13:*.pgm=38;5;13:*.ppm=38;5;13:*.tga=38;5;13:*.xbm=38;5;13:*.xpm=38;5;13:*.tif=38;5;13:*.tiff=38;5;13:*.png=38;5;13:*.svg=38;5;13:*.svgz=38;5;13:*.mng=38;5;13:*.pcx=38;5;13:*.mov=38;5;13:*.mpg=38;5;13:*.mpeg=38;5;13:*.m2v=38;5;13:*.mkv=38;5;13:*.webm=38;5;13:*.ogm=38;5;13:*.mp4=38;5;13:*.m4v=38;5;13:*.mp4v=38;5;13:*.vob=38;5;13:*.qt=38;5;13:*.nuv=38;5;13:*.wmv=38;5;13:*.asf=38;5;13:*.rm=38;5;13:*.rmvb=38;5;13:*.flc=38;5;13:*.avi=38;5;13:*.fli=38;5;13:*.flv=38;5;13:*.gl=38;5;13:*.dl=38;5;13:*.xcf=38;5;13:*.xwd=38;5;13:*.yuv=38;5;13:*.cgm=38;5;13:*.emf=38;5;13:*.axv=38;5;13:*.anx=38;5;13:*.ogv=38;5;13:*.ogx=38;5;13:*.aac=38;5;45:*.au=38;5;45:*.flac=38;5;45:*.mid=38;5;45:*.midi=38;5;45:*.mka=38;5;45:*.mp3=38;5;45:*.mpc=38;5;45:*.ogg=38;5;45:*.ra=38;5;45:*.wav=38;5;45:*.axa=38;5;45:*.oga=38;5;45:*.spx=38;5;45:*.xspf=38;5;45:
MAIL => /var/spool/mail/root
PATH => /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
PWD => /usr/local/nagioslogserver
XMODIFIERS => @im=ibus
LANG => en_US.UTF-8
HISTCONTROL => ignoredups
SHLVL => 1
HOME => /root
LOGNAME => root
SSH_CONNECTION => 10.3.9.27 56056 157.182.94.109 22
LESSOPEN => ||/usr/bin/lesspipe.sh %s
XDG_RUNTIME_DIR => /run/user/0
_ => /usr/bin/php
OLDPWD => /usr/local/nagioslogserver/var
PHP Variables
Variable => Value
_SERVER["XDG_SESSION_ID"] => 2807
_SERVER["HOSTNAME"] => ##############
_SERVER["TERM"] => xterm-256color
_SERVER["SHELL"] => /bin/bash
_SERVER["HISTSIZE"] => 1000
_SERVER["SSH_CLIENT"] => 10.3.9.27 56056 22
_SERVER["SSH_TTY"] => /dev/pts/1
_SERVER["USER"] => root
_SERVER["LS_COLORS"] => rs=0:di=38;5;27:ln=38;5;51:mh=44;38;5;15:pi=40;38;5;11:so=38;5;13:do=38;5;5:bd=48;5;232;38;5;11:cd=48;5;232;38;5;3:or=48;5;232;38;5;9:mi=05;48;5;232;38;5;15:su=48;5;196;38;5;15:sg=48;5;11;38;5;16:ca=48;5;196;38;5;226:tw=48;5;10;38;5;16:ow=48;5;10;38;5;21:st=48;5;21;38;5;15:ex=38;5;34:*.tar=38;5;9:*.tgz=38;5;9:*.arc=38;5;9:*.arj=38;5;9:*.taz=38;5;9:*.lha=38;5;9:*.lz4=38;5;9:*.lzh=38;5;9:*.lzma=38;5;9:*.tlz=38;5;9:*.txz=38;5;9:*.tzo=38;5;9:*.t7z=38;5;9:*.zip=38;5;9:*.z=38;5;9:*.Z=38;5;9:*.dz=38;5;9:*.gz=38;5;9:*.lrz=38;5;9:*.lz=38;5;9:*.lzo=38;5;9:*.xz=38;5;9:*.bz2=38;5;9:*.bz=38;5;9:*.tbz=38;5;9:*.tbz2=38;5;9:*.tz=38;5;9:*.deb=38;5;9:*.rpm=38;5;9:*.jar=38;5;9:*.war=38;5;9:*.ear=38;5;9:*.sar=38;5;9:*.rar=38;5;9:*.alz=38;5;9:*.ace=38;5;9:*.zoo=38;5;9:*.cpio=38;5;9:*.7z=38;5;9:*.rz=38;5;9:*.cab=38;5;9:*.jpg=38;5;13:*.jpeg=38;5;13:*.gif=38;5;13:*.bmp=38;5;13:*.pbm=38;5;13:*.pgm=38;5;13:*.ppm=38;5;13:*.tga=38;5;13:*.xbm=38;5;13:*.xpm=38;5;13:*.tif=38;5;13:*.tiff=38;5;13:*.png=38;5;13:*.svg=38;5;13:*.svgz=38;5;13:*.mng=38;5;13:*.pcx=38;5;13:*.mov=38;5;13:*.mpg=38;5;13:*.mpeg=38;5;13:*.m2v=38;5;13:*.mkv=38;5;13:*.webm=38;5;13:*.ogm=38;5;13:*.mp4=38;5;13:*.m4v=38;5;13:*.mp4v=38;5;13:*.vob=38;5;13:*.qt=38;5;13:*.nuv=38;5;13:*.wmv=38;5;13:*.asf=38;5;13:*.rm=38;5;13:*.rmvb=38;5;13:*.flc=38;5;13:*.avi=38;5;13:*.fli=38;5;13:*.flv=38;5;13:*.gl=38;5;13:*.dl=38;5;13:*.xcf=38;5;13:*.xwd=38;5;13:*.yuv=38;5;13:*.cgm=38;5;13:*.emf=38;5;13:*.axv=38;5;13:*.anx=38;5;13:*.ogv=38;5;13:*.ogx=38;5;13:*.aac=38;5;45:*.au=38;5;45:*.flac=38;5;45:*.mid=38;5;45:*.midi=38;5;45:*.mka=38;5;45:*.mp3=38;5;45:*.mpc=38;5;45:*.ogg=38;5;45:*.ra=38;5;45:*.wav=38;5;45:*.axa=38;5;45:*.oga=38;5;45:*.spx=38;5;45:*.xspf=38;5;45:
_SERVER["MAIL"] => /var/spool/mail/root
_SERVER["PATH"] => /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
_SERVER["PWD"] => /usr/local/nagioslogserver
_SERVER["XMODIFIERS"] => @im=ibus
_SERVER["LANG"] => en_US.UTF-8
_SERVER["HISTCONTROL"] => ignoredups
_SERVER["SHLVL"] => 1
_SERVER["HOME"] => /root
_SERVER["LOGNAME"] => root
_SERVER["SSH_CONNECTION"] => 10.3.9.27 56056 157.182.94.109 22
_SERVER["LESSOPEN"] => ||/usr/bin/lesspipe.sh %s
_SERVER["XDG_RUNTIME_DIR"] => /run/user/0
_SERVER["_"] => /usr/bin/php
_SERVER["OLDPWD"] => /usr/local/nagioslogserver/var
_SERVER["PHP_SELF"] => -
_SERVER["SCRIPT_NAME"] => -
_SERVER["SCRIPT_FILENAME"] =>
_SERVER["PATH_TRANSLATED"] =>
_SERVER["DOCUMENT_ROOT"] =>
_SERVER["REQUEST_TIME_FLOAT"] => 1486556871.1479
_SERVER["REQUEST_TIME"] => 1486556871
_SERVER["argv"] => Array
    [0] => -
_SERVER["argc"] => 1
openssl version -->   OpenSSL 1.0.1e-fips 11 Feb 2013
Reason: please use [code] tags for long/technical outputs
Re: ad tls auth
Post by mcapra »
After making the suggested changes, have you tried (from NLS) removing and re-importing the AD users? I encountered similar issues when changing my AD setup from un-encrypted to leveraging TLS.
WVUhealth
Re: ad tls auth
Post by WVUhealth »
did not work either... i know its a cert issue.. just sure how to deal with it properly within NLS
Re: ad tls auth
Post by mcapra »
It could also be an issue with the version of openldap leveraged. The nice thing is we have a functional machine to test against. From both your Nagios XI and Nagios Log Server machines, can you share the output of:
rpm -qa | grep openldap
WVUhealth
Re: ad tls auth
Post by WVUhealth »
[root@XXX nagioslogserver]# rpm -qa | grep openldap
openldap-2.4.40-13.el7.x86_64
[root@nagiosxi ~]# rpm -qa | grep openldap
openldap-2.4.40-12.el6.x86_64
openldap-devel-2.4.40-12.el6.x86_64
WVUhealth
Re: ad tls auth
Post by WVUhealth »
i just copied certs from nagios xi and it worked...
bryan
Re: ad tls auth
Post by mcapra »
Did you require additional assistance with this issue, or can we close the thread and mark it as resolved?
WVUhealth
Re: ad tls auth
Post by WVUhealth »
Resolved. Added root domain ca cert to system ca trust, updated permissions above, commented out tlsreqcert never, restart apache on entire cluster. Good to go.
