host & service perfdata increasing alarmingly
Re: host & service perfdata increasing alarmingly
I have this in my commands.cfg:
# SAMPLE PERFORMANCE DATA COMMANDS
# These are sample performance data commands that can be used to send performance
# data output to two text files (one for hosts, another for services). If you
# plan on simply writing performance data out to a file, consider using the
# host_perfdata_file and service_perfdata_file options in the main config file.
# 'process-host-perfdata' command definition
command_name process-host-perfdata
command_line /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /usr/local/nagios/var/host-perfdata.out
# 'process-service-perfdata' command definition
command_name process-service-perfdata
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /usr/local/nagios/var/service-perfdata.out
command_name process-service-perfdata-file
command_line /bin/mv /usr/local/pnp4nagios/var/service-perfdata /usr/local/pnp4nagios/var/spool/service-perfdata.$TIMET$
command_name process-host-perfdata-file
command_line /bin/mv /usr/local/pnp4nagios/var/host-perfdata /usr/local/pnp4nagios/var/spool/host-perfdata.$TIMET$
Also, an interesting find that might help:
[root@nagios-eqx-01 local]# grep -R -i 'process-host-perfdata-file' .
./nagios/var/nagios.log:[1486632671] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486632707] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486663091] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486663173] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486663610] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486664528] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486667224] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486668876] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486668923] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
./nagios/var/nagios.log:[1486676061] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
grep: ./nagios/var/rw/nagios.qh: No such device or address
^C
[root@nagios-eqx-01 local]# grep -R -i 'process-service-perfdata-file' .
./nagios/var/nagios.log:[1486632671] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486632707] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486663091] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486663173] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486663610] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486664528] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486667224] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486668876] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486668923] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
./nagios/var/nagios.log:[1486676061] Warning: Service performance file processing command 'process-service-perfdata-file' was not found - service performance data file will not be processed!
^C
Any updates on this?
Please do not bump your thread. We work through a queue, and you only push yourself to the bottom once again.pmithil7 wrote:Any updates on this?
Can you PM over myself and @dwhitfield an entire copy of your /usr/local/nagios/etc directory? The error mentions that something isn't processing properly with your performance data so it'll help to see everything at play../nagios/var/nagios.log:[1486676061] Warning: Host performance file processing command 'process-host-perfdata-file' was not found - host performance data file will not be processed!
^C
I was able to find this thread - https://support.nagios.com/forum/viewto ... =6&t=41487 - it appears this issue may have been going on for a bit here. From what I can tell in your file -
Is executing this -
Mine is a bit different over here -
From there, it would really depend on what's processing the perf data to pick it up. What other addons are you using in conjunction with Nagios? I saw in the previous post mentions of livestatus / pnp4nagios. What versions?
host_perfdata_file_processing_command=process-host-perfdata-file
service_perfdata_file_processing_command=process-service-perfdata-file
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
command_name process-host-perfdata-file-bulk
command_line /bin/mv /usr/local/nagios/var/host-perfdata /usr/local/nagios/var/spool/xidpe/$TIMET$.perfdata.host
Sorry for being a little impatient. I have sent a PM message as requested with the directory contents.
From the logs i feel like changes need to be made in the commands.cfg for the definitions of 'process-service-perfdata-file' and 'process-host-perfdata-file'. Let me know your thoughts on it.
Mithil
Mithil
Can you address the question above?
It's hard to say what needs to be changed since we did not configure all of this. It might be revisiting what @ssax mentioned - https://support.nagios.com/forum/viewto ... 87#p205430rkennedy wrote:I was able to find this thread - https://support.nagios.com/forum/viewto ... =6&t=41487 - it appears this issue may have been going on for a bit here. From what I can tell in your file -
If has to be one of the pnp4nagios config files that are putting the performance data in the wrong folder.
Take a look at the files in the following folder and see if they are correct.
Or reinstall / remove pnp4nagios to fix the issue.
/usr/local/pnp4nagios/etcBe sure to check out our Knowledgebase for helpful articles and solutions!
From the thread that you mentioned, my problem wasn't solved and hence i temporarily stopped processing performance data by putting process_performance_data = 0. This stopped data from accumulating and it after a month it again started accumulating data in those two files inspite of process_performance_data being 0. Hence, this grew up my concern about how data is still being gathered.
I have pnp4nagios of :
PKG_VERSION="0.6.25"
PKG_NAME="pnp4nagios"
Other then that i have nrpe, check_mk and wato as plugins on nagios.
I also checked /usr/local/pnp4nagios/etc and the configuration files seem to be ideal.
Any suggestion? Should i uninstall and re-install pnp4nagios again?
Yes, try uninstalling pnp4nagios and reinstalling to see if that fixes the issue.
If you have any other brokers enabled in the nagios.cfg file, try commenting them out as well to see if that stops the collecting of the performance data.
Thank you for your help. Any document or instructions on how to safely uninstall pnp4nagios without affecting nagios and other plugins? Any specifics that i should look forward to that won't crash the server?
I'm just being cautious here. Thanks
