NRPE: Unable to read output
Re: NRPE: Unable to read output
Can you post your full nrpe.cfg file from that remote system.
Can you login as root to that server, run the following command and post the /tmp/ls.txt file?
lr -lR /apps/nagios >/tmp/ls.txt
Also, take a look at the NRPE troubleshooting guide and on page 17 has tips for the error you are having.
https://assets.nagios.com/downloads/nag ... utions.pdf
rahul.srivastava1
Post by rahul.srivastava1 »
I am attaching the nrpe.cfg and ls.txt files from the remote server.
Also,i have gone through the documents which you suggested. It did not solve our issue.
We are struggling with this one command. Others are working fine.
Regards,
Rahul
ls.txt
(80.32 KiB) Downloaded 213 times
nrpe.cfg
(8.24 KiB) Downloaded 214 times
Can you post these files
check_jmx
jmx.cfg
From this folder
/apps/nagios/libexec/nagios-jmx-plugin-1.2.3
so we can view the settings?
Also, check the syslog files on the remote server for any errors that could help and post them here.
rahul.srivastava1
I am attaching the check_jmx and jmx.cfg files from /apps/nagios/libexec/nagios-jmx-plugin-1.2.3 path.
Syslog only shows the below:
ssb-voor-01 nrpe[18471]: [ID 927837 mail.info] connect from ssbpops01.ssb.sungard.com
here ssb-voor-01 is our remote server and ssbpops01.ssb.sungard.com is ournagios server
Regards,
Rahul
jmx.cfg
(206 Bytes) Downloaded 215 times
rahul.srivastava1
Seems like i am unable to upload check_jmx file. It has FILE extension.
In the ls.txt file, it doesn't show an extension for one of the check_jmx files. In that folder is a check_jmx and a check_jmx.jar file but I shouldn't need to see the check_jmx.jar file.
Try running these command instead and post the output.
cat /apps/nagios/libexec/nagios-jmx-plugin-1.2.3/check_jmx
cat /apps/nagios/libexec/nagios-jmx-plugin-1.2.3/README.txt
rahul.srivastava1
Here are the outputs:
1. cat /apps/nagios/libexec/nagios-jmx-plugin-1.2.3/check_jmx
#!/bin/sh
# Nagios JMX plugin.
JAVA_CMD=`which java`
if [ -z $JAVA_CMD ]
then
  if [ -x $JAVA_HOME/bin/java ]
  then
    JAVA_CMD=$JAVA_HOME/bin/java
  else
    echo JMX CRITICAL - java not found.
    exit 2
  fi
fi
DIR=`dirname $0`
$JAVA_CMD -jar $DIR/check_jmx.jar "$@"
2. cat /apps/nagios/libexec/nagios-jmx-plugin-1.2.3/README.txt
Copyright 2009 Felix Roethenbacher
* Nagios JMX Plugin                                                           *
Version 1.2.3
Copy
  - check_jmx
  - check_jmx.jar
to your Nagios plugin directory.
For a couple of sample command definitions copy
  - jmx.cfg
to your Nagios plugin configuration directory.
For further information see http://snippets.syabru.ch/nagios-jmx-plugin/index.html
Can you login to the remote server, run the following commands and post the output?
su nagios
/apps/nagios/libexec/nagios-jmx-plugin-1.2.3/check_jmx -U service:jmx:rmi:///jndi/rmi://168.162.97.143:7780/jmxrmi -O jboss.system:type=ServerInfo -A TotalMemory -w 3247300864 -c 3251495168
ls -l /usr/sh
which java
env |grep JAVA
I do have a question, does the Nagios server have access directly to the server at IP Address 168.162.97.143?
If so, why not install the plugin on the Nagios server and run it from there.
rahul.srivastava1
su nagiois
[nagios@ssb-voor-01]:~ $ /apps/nagios/libexec/nagios-jmx-plugin-1.2.3/check_jmx -U service:jmx:rmi:///jndi/rmi://168.162.97.143:7780/jmxrmi -O jboss.system:type=ServerInfo -A TotalMemory -w 3247300864 -c 3251495168
JMX OK - TotalMemory = 3147300864 | 'TotalMemory'=3147300864;3247300864;3251495168;;
[nagios@ssb-voor-01]:~ $ ls -l /usr/sh
ls: cannot access /usr/sh: No such file or directory
[nagios@ssb-voor-01]:~ $ which java
/usr/java7u121/jdk1.7.0_121/bin/java
Also, about running the plugin from nagios server, i will see what are the possibilities.
Regards,
Rahul
I setup the same check_jmx plugin on a Solaris 10 system, configures a check command in nrpe and it worked for me when I tested it from my nagios server
./check_nrpe -H 192.168.112.159 -c check_jmx
JMX OK - HeapMemoryUsage.used = 13249136 | 'HeapMemoryUsage used'=13249136;;;;.
The only thing I can thing of is after editing the nrpe.cfg file, you did not restart the NRPE Agent so it did not pickup the changes.
Running the following command reloaded the nrpe agent on my system. You may have to edit the service name to match your environment.
svcadm restart svc:/network/nrpe/tcp:default
