NRPE: Unable to read output
Re: NRPE: Unable to read output
Is there a firewall on the server at IP address 168.162.97.143 blocking the Nagios server?
Can you login to the Nagios server as root, run the following and post the output?
nmap 168.162.97.143 -p 7780
Katya.Ailarov
Post by Katya.Ailarov »
sorry i dont have this command intsall on my server.
please suggest other comand
Thank you vey much!
Are you able to install nmap on the Nagios server? It is very useful for troubleshooting.
Katya.Ailarov
i dont think it is the FW.
because i can telnet
-bash-4.1# telnet 168.162.97.143 5666
Trying 168.162.97.143...
Connected to 168.162.97.143.
Escape character is '^]'.
Post by mcapra »
We would really need to see the nmap output. It could be that telnet requests are not filtered but others are (this is quite common). This would be presented in an nmap output.
Katya.Ailarov
-bash-4.1# nmap 168.162.97.143 -p 7780
Starting Nmap 6.47 ( http://nmap.org ) at 2017-03-16 07:51 EDT
mass_dns: warning: Unable to determine any DNS servers. Reverse DNS is disabled. Try using --system-dns or specify valid servers with --dns-servers
Nmap scan report for 168.162.97.143
Host is up (0.00032s latency).
PORT STATE SERVICE
7780/tcp open unknown
Nmap done: 1 IP address (1 host up) scanned in 0.06 seconds
-bash-4.1#
Post by mcapra »
Just to clarify, which server is this: 10.146.1.37
Your original post doesn't describe this server:
1) Nagios server itself (ssbpops01_10.146.1.100)
2) Solaris remote host (Ssb-voor-01_168.162.97.143)
3) Solaris remote host (ssbpech01_10.146.1.38)
Can you run this command from the CLI of your Nagios Core (ssbpops01_10.146.1.100) machine:
nmap 168.162.97.143 -p 5666
Since the nmap from your Nagios Core machine to 168.162.97.143 shows port 7780 as open, is there any particular reason you're running your JMX checks through NRPE when it appears as though you could be running check_jmx directly from the Nagios Core machine?
If that sounds reasonable, I would think you could run check_jmx from the Nagios Core machine like so:
check_jmx -U service:jmx:rmi:///jndi/rmi://168.162.97.143:7780/jmxrmi -O jboss.system:type=ServerInfo -A TotalMemory -w 3247300864 -c 3251495168
And get results back.
Katya.Ailarov
nmap command from ssbpops01_10.146.1.100 (Nagios machine):
-bash-4.1# nmap 168.162.97.143 -p 5666
Starting Nmap 6.47 ( http://nmap.org ) at 2017-03-19 10:35 EDT
Host is up (0.00034s latency).
PORT STATE SERVICE
5666/tcp open nrpe
-bash-4.1#
check_jmx from Nagios server itself (ssbpops01_10.146.1.100):
-bash-4.1# ./check_jmx -U service:jmx:rmi:///jndi/rmi://168.162.97.143:7780/jmxrmi -O jboss.system:type=ServerInfo -A TotalMemory -w 3247300864 -c 3251495168
JMX CRITICAL - Error opening RMI connection: Connection refused to host: 168.162.97.143; nested exception is:
java.net.ConnectException: Connection timed out (Connection timed out)
-bash-4.1# hostname
ssbpops01.ssb.sungard.com
The nmap against 168.x.x.x mentions that TCP is open, is UDP open as well or is it being blocked since it's a WAN address?
Please post the related configurations you're using on the client java application side so we can see how your JMX is setup.
Post by dwhitfield »
rkennedy wrote:The nmap against 168.x.x.x mentions that TCP is open, is UDP open as well or is it being blocked since it's a WAN address?
For clarity on this piece, run nmap -sU -p 5666 168.162.97.143.
Also, yes JMX configs would be great.
