ls -al /usr/local/nagios/libexec/
ps aux | grep xinetd
ps aux | grep nrpe
cat /usr/local/nagios/etc/nrpe.cfg
ps aux | grep nrpe
allowed_hosts=127.0.0.1 10.2.8.79Code: Select all
su nagios
/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
ls -al /usr/lib/nagios/plugins/
/usr/lib/nagios/plugins/check_nrpe -H 127.0.0.1
/usr/lib/nagios/plugins/check_nrpe -H 127.0.0.1 -c check_loadCode: Select all
/usr/local/nagios/libexec/check_load -w 15,10,5 -c 30,25,20
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1 -n
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1 -n -c check_loadCode: Select all
tail -n 200 /var/log/messages | grep nrpeCode: Select all
[root@tgcs018 /]# cd /usr/local/nagios/libexec
[root@tgcs018 libexec]# check_load -w 15,10,5 -c 30,25,20
-bash: check_load: command not found
[root@tgcs018 libexec]# ls
check_apt check_jabber check_services
check_asterisk.pl check_load check_simap
check_asterisk_sip_peers.sh check_log check_sip
check_breeze check_mailq check_smtp
check_by_ssh check_mrtg check_spop
check_clamd check_mrtgtraf check_ssh
check_cluster check_nagios check_ssmtp
check_cpu_stats.sh check_netstat.pl check_swap
check_dhcp check_nntp check_tcp
check_dig check_nntps check_time
check_disk check_nrpe check_udp
check_disk_smb check_nt check_ups
check_dns check_ntp check_uptime
check_dummy check_ntp_peer check_users
check_file_age check_ntp_time check_wave
check_flexlm check_nwstat check_yum
check_ftp check_open_files.pl custom_check_mem
check_http check_oracle custom_check_procs
check_icmp check_overcr nagisk.pl
check_ide_smart check_ping negate
check_ifoperstatus check_pop send_nsca
check_ifstatus check_procs urlize
check_imap check_real utils.pm
check_init_service check_rpc utils.sh
check_ircd check_sensors
[root@tgcs018 libexec]# ./check_load -w 15,10,5 -c 30,25,20
OK - load average: 0.05, 0.03, 0.05|load1=0.050;15.000;30.000;0; load5=0.030;10.000;25.000;0; load15=0.050;5.000;20.000;0;
[root@tgcs018 libexec]# ./check_nrpe -H 127.0.0.1 -n
CHECK_NRPE: Error receiving data from daemon.
[root@tgcs018 libexec]# ./check_nrpe -H 127.0.0.1 -n -c check_load
[root@tgcs018 libexec]# tail -n 200 /var/log/messages | grep nrpe
Mar 13 19:01:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=8273 duration=0(sec)
Mar 13 19:02:25 tgcs018 xinetd[883]: START: nrpe pid=8446 from=::ffff:10.2.8.79
Mar 13 19:02:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=8446 duration=0(sec)
Mar 13 19:03:25 tgcs018 xinetd[883]: START: nrpe pid=8619 from=::ffff:10.2.8.79
Mar 13 19:03:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=8619 duration=0(sec)
Mar 13 19:04:25 tgcs018 xinetd[883]: START: nrpe pid=8790 from=::ffff:10.2.8.79
Mar 13 19:04:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=8790 duration=0(sec)
Mar 13 19:05:25 tgcs018 xinetd[883]: START: nrpe pid=8961 from=::ffff:10.2.8.79
Mar 13 19:05:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=8961 duration=0(sec)
Mar 13 19:06:25 tgcs018 xinetd[883]: START: nrpe pid=9132 from=::ffff:10.2.8.79
Mar 13 19:06:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=9132 duration=0(sec)
Mar 13 19:07:25 tgcs018 xinetd[883]: START: nrpe pid=9303 from=::ffff:10.2.8.79
Mar 13 19:07:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=9303 duration=0(sec)
Mar 13 19:08:25 tgcs018 xinetd[883]: START: nrpe pid=9474 from=::ffff:10.2.8.79
Mar 13 19:08:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=9474 duration=0(sec)
Mar 13 19:09:25 tgcs018 xinetd[883]: START: nrpe pid=9657 from=::ffff:10.2.8.79
Mar 13 19:09:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=9657 duration=0(sec)
Mar 13 19:10:25 tgcs018 xinetd[883]: START: nrpe pid=9834 from=::ffff:10.2.8.79
Mar 13 19:10:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=9834 duration=1(sec)
Mar 13 19:11:25 tgcs018 xinetd[883]: START: nrpe pid=10005 from=::ffff:10.2.8.79
Mar 13 19:11:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=10005 duration=1(sec)
Mar 13 19:12:26 tgcs018 xinetd[883]: START: nrpe pid=10176 from=::ffff:10.2.8.79
Mar 13 19:12:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=10176 duration=0(sec)
Mar 13 19:13:26 tgcs018 xinetd[883]: START: nrpe pid=10347 from=::ffff:10.2.8.79
Mar 13 19:13:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=10347 duration=0(sec)
Mar 13 19:14:26 tgcs018 xinetd[883]: START: nrpe pid=10518 from=::ffff:10.2.8.79
Mar 13 19:14:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=10518 duration=0(sec)
Mar 13 19:15:25 tgcs018 xinetd[883]: START: nrpe pid=10689 from=::ffff:10.2.8.79
Mar 13 19:15:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=10689 duration=0(sec)
Mar 13 19:16:25 tgcs018 xinetd[883]: START: nrpe pid=10860 from=::ffff:10.2.8.79
Mar 13 19:16:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=10860 duration=0(sec)
Mar 13 19:17:25 tgcs018 xinetd[883]: START: nrpe pid=11031 from=::ffff:10.2.8.79
Mar 13 19:17:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=11031 duration=0(sec)
Mar 13 19:18:25 tgcs018 xinetd[883]: START: nrpe pid=11202 from=::ffff:10.2.8.79
Mar 13 19:18:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=11202 duration=0(sec)
Mar 13 19:19:25 tgcs018 xinetd[883]: START: nrpe pid=11373 from=::ffff:10.2.8.79
Mar 13 19:19:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=11373 duration=0(sec)
Mar 13 19:20:25 tgcs018 xinetd[883]: START: nrpe pid=11549 from=::ffff:10.2.8.79
Mar 13 19:20:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=11549 duration=0(sec)
Mar 13 19:21:25 tgcs018 xinetd[883]: START: nrpe pid=11720 from=::ffff:10.2.8.79
Mar 13 19:21:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=11720 duration=0(sec)
Mar 13 19:22:25 tgcs018 xinetd[883]: START: nrpe pid=11891 from=::ffff:10.2.8.79
Mar 13 19:22:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=11891 duration=0(sec)
Mar 13 19:23:25 tgcs018 xinetd[883]: START: nrpe pid=12068 from=::ffff:10.2.8.79
Mar 13 19:23:25 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=12068 duration=0(sec)
Mar 13 19:24:25 tgcs018 xinetd[883]: START: nrpe pid=12240 from=::ffff:10.2.8.79
Mar 13 19:24:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=12240 duration=1(sec)
Mar 13 19:25:26 tgcs018 xinetd[883]: START: nrpe pid=12411 from=::ffff:10.2.8.79
Mar 13 19:25:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=12411 duration=0(sec)
Mar 13 19:26:26 tgcs018 xinetd[883]: START: nrpe pid=12582 from=::ffff:10.2.8.79
Mar 13 19:26:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=12582 duration=0(sec)
Mar 13 19:27:26 tgcs018 xinetd[883]: START: nrpe pid=12753 from=::ffff:10.2.8.79
Mar 13 19:27:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=12753 duration=0(sec)
Mar 13 19:28:26 tgcs018 xinetd[883]: START: nrpe pid=12924 from=::ffff:10.2.8.79
Mar 13 19:28:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=12924 duration=0(sec)
Mar 13 19:29:26 tgcs018 xinetd[883]: START: nrpe pid=13112 from=::ffff:10.2.8.79
Mar 13 19:29:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=13112 duration=0(sec)
Mar 13 19:30:26 tgcs018 xinetd[883]: START: nrpe pid=13291 from=::ffff:10.2.8.79
Mar 13 19:30:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=13291 duration=0(sec)
Mar 13 19:31:26 tgcs018 xinetd[883]: START: nrpe pid=13465 from=::ffff:10.2.8.79
Mar 13 19:31:26 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=13465 duration=0(sec)
Mar 13 19:31:27 tgcs018 xinetd[883]: START: nrpe pid=13509 from=::ffff:127.0.0.1
Mar 13 19:31:27 tgcs018 xinetd[13509]: FAIL: nrpe address from=::ffff:127.0.0.1
Mar 13 19:31:27 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=13509 duration=0(sec)
Mar 13 19:31:44 tgcs018 xinetd[883]: START: nrpe pid=13541 from=::ffff:127.0.0.1
Mar 13 19:31:44 tgcs018 xinetd[13541]: FAIL: nrpe address from=::ffff:127.0.0.1
Mar 13 19:31:44 tgcs018 xinetd[883]: EXIT: nrpe status=0 pid=13541 duration=0(sec)
[root@tgcs018 libexec]#Code: Select all
/etc/xinetd.d/nrpeCode: Select all
# only_from = 127.0.0.1Code: Select all
service xinetd restartCode: Select all
/usr/local/nagios/bin/nrpeCode: Select all
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -c check_loadCode: Select all
/usr/local/nagios/etc/nrpe.cfgCode: Select all
debug=0Code: Select all
debug=1Code: Select all
/etc/rsyslogd.confCode: Select all
*.info;mail.none;authpriv.none;cron.none /var/log/messagesCode: Select all
*.info;mail.none;authpriv.none;cron.none;daemon.debug /var/log/messagesCode: Select all
service rsyslog restartCode: Select all
/usr/local/nagios/libexec/check_nrpe -H YOURREMOTEHOSTCode: Select all
tail -n 100 /var/log/messages
