You may be hitting a bug, you can try running these commands and see if it resolves the issue for you:
- NOTE: Make sure you take an XI backups/VM snapshot just in case
- Running the below command will remove ALL data from Home > Event Log or Reports > Event Log (they are the same report).
Thanks - ran the truncate command and it completed OK. However, not sure it did anything ?
I went to Home -> Event Log afterwards, and it shows that I have 100,000+ records in the last 24hrs?
Hosts/Services = 1052/10252
Then we are getting events forwarded from two other Nagios Servers - Hosts/Services = 189/2017 & 237/2739
I disabled the Global Service event handler yesterday to reduce the number of events being written to the Event Log. Today it still shows 100,000+ entries for the last 24hrs.
I suppose doing the math that's almost 200,00 events an hour (assuming that they run every 5mins).
The event_handler.log file only has a single entry that the LOCK file was created.
BTW pidstat -C postgres -d 5 12 command doesn't work either... no values get returned.
Also I'm guessing that the truncate command did work as the xi-meta table is somewhat smaller today when I ran the query you sent and the other two tables don't appear in the listing now.
Let's move this into a ticket, please email [email protected] with a descriptive subject and detailed body and please include a link back to this thread so that we can get a remote session setup.
