Import host and service escalations and BPI configs
avandemore
Re: Import host and service escalations and BPI configs
Yeah, that's basically the same process I did. I can't explain why I get different results than you, but I did it twice to make sure.
Previous Nagios employee
Ok, I'll start over. What order did you follow?
avandemore
I've PM'd you the config files and process I used to create them.
Please note, the file is best viewed with:
less -r cfgprep.txtPrevious Nagios employee
I have the PM but I can't find anything attached to it.
avandemore
I've sent it again, this time with it attached.
After looking over, the process looks the same as what I've tried. But, my other issue is during the actual import configs to core config manager, what order did you use?
avandemore
I didn't take it that far. Your original error indicates a failure importing the service DB_REPLICATION because host DB_REPLICATION is missing? Did you import the service first? When I import the host first, it works for me assuming your contact/contact groups are done first.
Okay, I'll follow default order and get back if there are issues. Thanks!
avandemore
Sounds good, let us know if you have more issues.
Write configs and Verify Files both came back successfully. So that's better than last time. I'm now applying configuration which seems to take a long time. I'll let you know.
