Dear Team,
I have successfully installed the NagiosXI server and Nagios NRPE client.
Thank you very much for your support. Appreciating your help.
I have added the DEV servers and QA servers.
I want to get the metrics of the below for any of DEV server.
1. CPU
2. UPTIME
3. DISK
4. MEMORY
Please guide me the navigation path for the above ?
Also , How can i group the DEV servers names and GROUP QA server names ?
How to get the emails Notifications configuration ?
Nag
linux-nrpe-agent uninstall / remove
- Former Nagios Staff
Re: linux-nrpe-agent uninstall / remove
1. check_nrpe!check_load!-a '-w 15,10,5 -c 30,20,10'
2. Do you really want the uptime or just whether it's up or down? The reports will give you an uptime based on the results.
3. check_disk: http://nagios-plugins.org/doc/man/check_disk.html
4. check_nrpe!check_mem!-a '-w 20 -c 10'
As for your questions about grouping and notification, please open another thread.
Hi ,
1. for CPU, there is only dropdown menu for the check_command
How can we execute your suggested below command ? please guide as it is having two commands together. ?
In the dropdown box, we can SELECT only one command... so how to execute above 2 commnads?
I also tried the above command in : /usr/local/nagios/libexec
/usr/local/nagios/libexec/check_nrpe!check_load!-a '-w 15,10,5 -c 30,20,10'
-bash: !check_load!-a: event not found
Thank you,
Thank you,
I'm going to lock this thread since we are working through the checks in another thread.
