Automate daily mass delete hosts
nagwindmon
Re: Automate daily mass delete hosts
will try to run my script with advised changes... in meantime what would you recommend for deleting hosts by utilizing XI scripts as I do now or REST API?
if REST API is preferred way do you mind to provide a sample how would I run it by cron?
Thanks!
Thanks!
nagwindmon
a quick update: using XI scripts is pretty much direct deletes into database so may not be a best practice so made an attempt to utilize REST API delete and got the following error:
[nagios@esu4v385 nagios]$ curl -k -XDELETE "http://esu4v385/nagiosxi/api/v1/config/ ... CVT3511956"
"error": "Host cannot be deleted using this method. Must be deleted through the CCM."
but the host looks like does not have any services or any other dependencies:
Please advise!
Please advise!
Since that Host object has relationships with both the DRT_CVT and MCY-708-CST Hostgroups, you will first need to eliminate those dependencies before you can delete the Host object.
Since the API doesn't currently allow you to cherry-pick specific hosts out of hostgroups, you would essentially need to GET those hostgroups, modify them to not include CVT3511956, then delete and re-create them.
nagwindmon
where do you see item labeled as 'Dependent relationship' in the output?
In my example there is not a 'Dependent relationship' that should prohibit deletion...
That aside, @lmiltchev tested this and even if there is a host->hostgroup and hostgroup->host dependency for a given host it shouldn't affect API deletion. I didn't have any problems deleting a host in that configuration.
You could try adding force=1 to your API request and see if that makes a difference. Your assessment is correct as far as I can tell that there shouldn't be any relationships preventing this host from being deleted.
Thanks @mcapra!
nagwindmon, what is the Nagios XI version that you are currently using? It is possible that this is a bug with API, that was fixed in the later versions.
My test host was added to 3 hostgroups:
but I was able to delete it just fine via the REST API.
[root@main-nagios-xi ~]# curl -XDELETE "http://x.x.x.x/nagiosxi/api/v1/config/host?apikey=LTltbjobR0X3V5ViDIitYaI8hjsjoFBaOcWYukamF7oAsD8lhJRvSPWq8I3PjTf7&pretty=1&host_name=test&applyconfig=1"
"success": "Removed test from the system. Config applied, Nagios Core was restarted."
}You do not have the required permissions to view the files attached to this post.
nagwindmon
Nagios XI 5.2.0
There were MANY, MANY bug fixes, and added features since 5.2.0. I would strongly recommend upgrading to the latest. You particular issue was probably fixed in 5.2.8. I see this in the changelog:
Looking at the task, I see this:
https://assets.nagios.com/downloads/nag ... NGES-5.TXT- Fixed API not deleting some hosts correctly [TPS#8500] -BH
Description: Using rest Api cannot delete a host that is a member of a hostgroup
Steps To Reproduce:
1) Add a host and put it in a hostgroup
2) Try to delete the host using this cmd
curl -XDELETE "https://nagios/nagiosxi/api/v1/config/h ... lyconfig=1 "
3) results in -
nagwindmon
got it, thanks lmiltchev! as always very much appreciate your inputs on this forum
Did you have any other questions or are we okay closing this?
