Waiting for configuration verification took about 40 minutes
nagio60
Re: Waiting for configuration verification took about 40 min
Post by nagio60 »
Yes this is a new install with few nodes added for monitor test.
also please check the attached profile.zip that was PM'ed.
Thank you.
Can you run the following tail command as root on the Nagios server.
tail -f /var/log/httpd/*_log
Then in the XI GUI, Apply the Config and post the output of the tail command so we cam view the errors if there are any.
