Backup & Maintenance not working automatically
Re: Backup & Maintenance not working automatically
So I have nagios as a user now but I still get the jsonselect issue when trying to run the jobs automatically.
The errors we're running into are actually separate from the backup_maintenance job. The backups job runs create_backup.sh which references the jsonselect module directly rather than importing it.
Can you run the following as root:
Then again as the nagios user (use sudo if needed), sharing outputs along the way?
curl -s -XPOST 'http://localhost:9200/_export/state' > /tmp/state.json
python -m jsonselect.__main__ .count < /tmp/state.json
python -c "help('modules');" | grep jsonselect
2
DLFCN cPickle jsonselect sgmllib
curl -s -XPOST 'https://localhost:9200/_export/state' > /tmp/state.json
$ python -m jsonselect.__main__ .count < /tmp/state.json
/bin/python: No module named jsonselect
$ python -c "help('modules');" | grep jsonselect
Can you share the outputs of these commands as both root and nagios:
python -V
which pythonFormer Nagios employee
Both are the same
$python -V
Python 2.7.5
$which python
/bin/pythonRe: Backup & Maintenance not working automatically
Pretty baffling so far. How about the full output of this from nagios and root:
It's almost like nagios and root are using 2 different python installations.
python -c "help('modules');"Former Nagios employee
Okay these are actually different, and from what I saw the only thing different is jsonselect.
Nagios
Root:
Nagios
Please wait a moment while I gather a list of all available modules...
BaseHTTPServer backports imputil selinux
Bastion base64 iniparse semanage
CDROM bdb inspect seobject
CGIHTTPServer binascii io sepolgen
ConfigParser binhex itertools sepolicy
Cookie bisect javapackages sets
DLFCN bsddb json setuptools
DocXMLRPCServer bz2 keyword sgmllib
HTMLParser cPickle lib2to3 sha
IN cProfile liblzma shelve
IPy cStringIO linecache shlex
MimeWriter calendar linuxaudiodev shutil
OpenSSL cgi locale signal
Queue cgitb logging site
SimpleHTTPServer chunk lxml slip
SimpleXMLRPCServer cmath lzma smtpd
SocketServer cmd macpath smtplib
StringIO code macurl2path snack
TYPES codecs mailbox sndhdr
UserDict codeop mailcap socket
UserList collections markupbase spwd
UserString colorsys marshal sqlite3
_LWPCookieJar commands math sqlitecachec
_MozillaCookieJar compileall md5 sre
__builtin__ compiler mhlib sre_compile
__future__ configobj mimetools sre_constants
_abcoll contextlib mimetypes sre_parse
_ast cookielib mimify ssl
_audit copy mmap stat
_bisect copy_reg modulefinder statvfs
_bsddb crypt multifile string
_codecs csv multiprocessing stringold
_codecs_cn ctypes mutex stringprep
_codecs_hk curl netrc strop
_codecs_iso2022 curses new struct
_codecs_jp datetime nis subprocess
_codecs_kr dbhash nntplib sunau
_codecs_tw dbm ntpath sunaudio
_collections dbus nturl2path symbol
_crypt decimal numbers symtable
_csv decorator opcode sys
_ctypes difflib operator sysconfig
_curses dircache optparse syslog
_curses_panel dis os tabnanny
_dbus_bindings distutils os2emxpath tarfile
_dbus_glib_bindings dl ossaudiodev telnetlib
_elementtree doctest parser tempfile
_functools dumbdbm pdb termios
_hashlib dummy_thread perf test
_heapq dummy_threading pickle textwrap
_hotshot easy_install pickletools this
_io email pipes thread
_json encodings pkg_resources threading
_locale errno pkgutil time
_lsprof exceptions platform timeit
_markerlib fcntl plistlib timing
_multibytecodec filecmp policycoreutils toaiff
_multiprocessing fileinput popen2 token
_osx_support firewall poplib tokenize
_pyio fnmatch posix trace
_random formatter posixfile traceback
_semanage fpformat posixpath tty
_snack fractions pprint tuned
_socket ftplib profile types
_sqlite3 functools pstats unicodedata
_sqlitecache future_builtins pty unittest
_sre gc pwd urlgrabber
_ssl gdbm py_compile urllib
_strptime genericpath pyclbr urllib2
_struct getopt pycurl urlparse
_symtable getpass pydoc user
_sysconfigdata gettext pydoc_data uu
_threading_local gi pyexpat uuid
_warnings glob pygtkcompat validate
_weakref gpgme pyparsing warnings
_weakrefset grp pyudev wave
abc gzip quopri weakref
acutil hashlib random webbrowser
aifc heapq re whichdb
antigravity hmac readline wsgiref
anydbm hotshot repr xattr
argparse htmlentitydefs resource xdrlib
array htmllib rexec xml
ast httplib rfc822 xmllib
asynchat idlelib rlcompleter xmlrpclib
asyncore ihooks robotparser xxsubtype
atexit imageop rpm yum
audiodev imaplib rpmUtils zipfile
audioop imghdr runpy zipimport
audit imp sched zlib
auparse importlib select
Enter any module name to get more help. Or, type "modules spam" to search
for modules whose descriptions contain the word "spam".
BaseHTTPServer bdb iniparse semanage
Bastion binascii inspect seobject
CDROM binhex io sepolgen
CGIHTTPServer bisect itertools sepolicy
ConfigParser bsddb javapackages sets
Cookie bz2 json setuptools
DocXMLRPCServer cProfile keyword sha
HTMLParser cStringIO lib2to3 shelve
IN calendar liblzma shlex
IPy cgi linecache shutil
MimeWriter cgitb linuxaudiodev signal
OpenSSL chunk locale site
Queue click logging slip
SimpleHTTPServer cmath lxml smtpd
SimpleXMLRPCServer cmd lzma smtplib
SocketServer code macpath snack
StringIO codecs macurl2path sndhdr
TYPES codeop mailbox socket
UserDict collections mailcap spwd
UserList colorsys markupbase sqlite3
UserString commands marshal sqlitecachec
_LWPCookieJar compileall math sre
_MozillaCookieJar compiler md5 sre_compile
__builtin__ configobj mhlib sre_constants
__future__ contextlib mimetools sre_parse
_abcoll cookielib mimetypes ssl
_ast copy mimify stat
_audit copy_reg mmap statvfs
_bisect crypt modulefinder string
_bsddb csv multifile stringold
_codecs ctypes multiprocessing stringprep
_codecs_cn curator mutex strop
_codecs_hk curl netrc struct
_codecs_iso2022 curses new subprocess
_codecs_jp datetime nis sunau
_codecs_kr dbhash nntplib sunaudio
_codecs_tw dbm ntpath symbol
_collections dbus nturl2path symtable
_crypt decimal numbers sys
_csv decorator opcode sysconfig
_ctypes difflib operator syslog
_curses dircache optparse tabnanny
_curses_panel dis os tarfile
_dbus_bindings distutils os2emxpath telnetlib
_dbus_glib_bindings dl ossaudiodev tempfile
_elementtree doctest parser termios
_functools dumbdbm pdb test
_hashlib dummy_thread perf tests
_io elasticsearch pip thread
_json email pipes threading
_locale encodings pkg_resources time
_lsprof errno pkgutil timeit
_markerlib exceptions platform timing
_multibytecodec fcntl plistlib toaiff
_multiprocessing filecmp policycoreutils token
_osx_support fileinput popen2 tokenize
_pyio firewall poplib trace
_random fnmatch posix traceback
_semanage formatter posixfile tty
_snack fpformat posixpath tuned
_socket fractions pprint types
_sqlite3 ftplib profile unicodedata
_sqlitecache functools pstats unittest
_sre future_builtins pty urlgrabber
_ssl gc pwd urllib
_strptime gdbm py_compile urllib2
_struct genericpath pyclbr urllib3
_symtable getopt pycurl urlparse
_sysconfigdata getpass pydoc user
_threading_local gettext pydoc_data uu
_warnings gi pyexpat uuid
_weakref glob pygtkcompat validate
_weakrefset gpgme pyparsing warnings
abc grp pyudev wave
acutil gzip quopri weakref
aifc hashlib random webbrowser
antigravity heapq re whichdb
anydbm hmac readline wsgiref
argparse hotshot repr xattr
array htmlentitydefs resource xdrlib
ast htmllib rexec xml
asynchat httplib rfc822 xmllib
asyncore idlelib rlcompleter xmlrpclib
atexit ihooks robotparser xxsubtype
audiodev imageop rpm yum
audioop imaplib rpmUtils zipfile
audit imghdr runpy zipimport
auparse imp sched zlib
backports importlib select
base64 imputil selinux
Are the perms on that module's files in site-packages allowing the nagios user to read the jsonselect path? That's one way I was able to reproduce this:
If it's not 744, try changing it to 744. Or 755.
ls -al /usr/lib/python2.7/site-packagesFormer Nagios employee
I had to change jsonselect to 755 to get the errors to subside. However, I still don't see anything getting closed or deleted and there are no additional snapshots.
/usr/lib/python2.7/site-packages/jsonselect:
total 64
-rwxr-xr-x. 1 root root 15910 Oct 21 2013 jsonselect.py
-rwxr-xr-x. 1 root root 1253 Oct 21 2013 __main__.py
-rwxr-xr-x. 1 root root 178 Oct 24 2013 __init__.py
-rwxr-xr-x. 1 root root 394 Nov 17 10:22 __init__.pyc
-rwxr-xr-x. 1 root root 1598 Nov 17 10:22 __main__.pyc
-rwxr-xr-x. 1 root root 21578 Nov 17 10:22 jsonselect.pyc
drwxr-xr-x. 2 root root 4096 Nov 17 10:22 .
drwxr-xr-x. 34 root root 4096 Jan 24 12:08 ..
tail -f /usr/local/nagioslogserver/var/jobs.log
PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0
Running command run_alerts with args ' ' for job id: run_all_alerts
SUCCESS
Running command update_check with args ' ' for job id: run_update_check
SUCCESS
Processed 0 node jobs.
Processed 2 global jobs.
tail: /usr/local/nagioslogserver/var/jobs.log: file truncated
Running command create_backup with args ' ' for job id: AVs_k0f-cJMl7DjS3OF1
SUCCESS
SUCCESS
SUCCESS
That particular job (backup_maintenance) only gets run every 24 hours unless you're specifically telling it to run sooner via the GUI.
Based on this:
Based on this:
It doesn't look like the backup_maintenance job has ran yet.TEWLS wrote:Code: Select all
tail -f /usr/local/nagioslogserver/var/jobs.log PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0 Running command run_alerts with args ' ' for job id: run_all_alerts SUCCESS Running command update_check with args ' ' for job id: run_update_check SUCCESS Processed 0 node jobs. Processed 2 global jobs. tail: /usr/local/nagioslogserver/var/jobs.log: file truncated PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0 Running command create_backup with args ' ' for job id: AVs_k0f-cJMl7DjS3OF1 tail: /usr/local/nagioslogserver/var/jobs.log: file truncated PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0 Running command run_alerts with args ' ' for job id: run_all_alerts SUCCESS Running command run_alerts with args ' ' for job id: run_all_alerts SUCCESS Processed 0 node jobs. Processed 2 global jobs. tail: /usr/local/nagioslogserver/var/jobs.log: file truncated PHP Warning: Module 'SourceGuardian' already loaded in Unknown on line 0 Running command run_alerts with args ' ' for job id: run_all_alerts SUCCESS
