Disabling SSL in REALLY old Nagios self compiled setup
ddolecki108
Re: Disabling SSL in REALLY old Nagios self compiled setup
Post by ddolecki108 »
This definitely has something to do with SSL and more particularly not using SSL.
So, there are two types of nagios client machines, one type has wealer ciphers enabled and another, newer type has only stronger ciphers.
the "-n" is failing on both.
With a client with weak ciphers:
[]# /usr/local/nagios/libexec/check_nrpe -n -H weakcipherservername
CHECK_NRPE: Error receiving data from daemon.
[]# /usr/local/nagios/libexec/check_nrpe -H weakcipherservername
NRPE v2.15
With a client with strong ciphers:
[]# /usr/local/nagios/libexec/check_nrpe -n -H strongcipherservername
[]# /usr/local/nagios/libexec/check_nrpe -H strongcipherservername
CHECK_NRPE: Error - Could not complete SSL handshake.
If you want to compile the NRPE Agent without SSL, you would use the following example.
./configure --enable-command-args --disable-ssl
You also may want to look at this KB article for making the older and newer versions of NRPE to work together.
https://support.nagios.com/kb/article.php?id=516
ddolecki108
Thanks for the input. Compiling nrpe to not use ssl is not an option.
I followd the knowledgebase artice for making different nrpe's work together and got this:
~]# /usr/local/nagios/libexec/check_nrpe -2 -H strongcipherservername
/usr/local/nagios/libexec/check_nrpe: invalid option -- 2
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 2.12
Last Modified: 03-10-2008
License: GPL v2 with exemptions (-l for more info)
SSL/TLS Available: Anonymous DH Mode, OpenSSL 0.9.6 or higher required
I want to verify that you are using the old version of the check_nrpe (Version 2.15) and you want to connect to the new 3.x.x NRPE Agent, is that correct?
Can you post your nrpe.cfg file from one of the system using the new NRPE Agent?
Also, can you check the /var/log/messages file for any errors when you run the check_nrpe test and post them as well.
What OS and release is the system running you are trying to install the Agent on?
ddolecki108
I think that the Nagios server check_nrpe version is 2.12
the nrpe.cfg file is at: https://pastebin.com/8dmUnfBL
nothing in /var/log/messages on the Nagios server
Nagios server:
[lnxvm02:~]# uname -a
Linux 2.6.18-419.el5 #1 SMP Fri Feb 24 22:06:09 UTC 2017 i686 i686 i386 GNU/Linux
Nagios client:
Linux 3.10.0-514.10.2.el7.x86_64 #1 SMP Mon Feb 20 02:37:52 EST 2017 x86_64 x86_64 x86_64 GNU/Linux
ddolecki108
I guess compiling NRPE w/o SSL is an option on the new strong cipher servers, and the Nagios server is able to connect using the -n switch.
How do I modify the Nagios configuration file to pass the "-n" switch to ONLY those new strong cipher servers?
current checks look like this:
# SERVICE DEFINITIONS - servername
#### Server template ####
name generic-servername
host_name servername
contact_groups UNIX_admins
register 0
# Disk checking definitions
use generic-servername
service_description root
check_command check_nrpe!check_root
service_description boot
check_command check_nrpe!check_boot
service_description tmp
check_command check_nrpe!check_tmp
ssax
Dreams In Code
Post by ssax »
Please post your command definition for check_nrpe so that we can help you adjust them.
Thank you
ddolecki108
Some Nagios clients are fine with SSL enabled while it is disabled on others.
ddolecki108
commands.cfg attached
commands.cfg
(8.42 KiB) Downloaded 402 times
ssax
Dreams In Code
Post by ssax »
Try this:
register 0
check_command check_nrpe!check_root -n
check_command check_nrpe!check_boot -n
check_command check_nrpe!check_tmp -n
