hi tacolover101
Do I need add the hsotname in windows server etc/host
Edwin
Website URL monitoring for site hosted on IIS windows 2012
edwinkamal
Re: Website URL monitoring for site hosted on IIS windows 20
hostname does not need to be added to the Windows host. Nagios does need to be able to resolve the destination hostname to an IP though.
edwinkamal
Hi Team
I have tried with below options with check_website plugin.
Even for this also we get HTTPS/HTTP unknown for both port 80 and 443
In commands.cfg:
command_name check_website4
command_line $USER1$/check_website -p $ARG1$ -u $ARG2$ -s -w 500 -c 1000 '$HOSTADDRESS$'
In your monitor file:
use windows-server ; Inherit default values from a template
host_name xyz.net ; The name we're giving to this host
alias xyz.net ; A longer name associated with the host
address xxx.xx.xx.96 ; IP address of the host
host_name xyz.net
service_description check website4
check_command check_website4!443!/tala
I am getting this messsge:
[root@ip-xxx-xx-xxx-137 objects]# /usr/local/nagios/libexec/check_website -p 443 -u /tala -s -w 500 -c 1000 'xyz.net'
HTTPS UNKNOWN: N/A - https://xyz.net:443/tala
Could you please advise on this
In commands.cfg:
host_name xyz.net
- Former Nagios Staff
I would suggest downloading a trial of XI. You can run one of the wizards in XI and just copy that check to your Core server.
There is a giant caveat to this though. You cannot install XI on top of core. You need a different VM for XI.
