BPI Errors
Re: BPI Errors
Thanks for the output. I was able to recreate the issue and filed a Bug Report for the issue.
You can refer to this NEW TASK ID 11721 for any information.
Right now, the only workaround is to manually edit the BPI Config file and make sure the define is on it's own line.
askewdread
Re: BPI Errors
Post by askewdread »
Oh great thanks for that :) it's not a bit deal to work around for now :)
Re: BPI Errors
Your welcome. If you don't have any other questions, shall I close and lock the post for you?
askewdread
Re: BPI Errors
tgriep wrote:Your welcome. If you don't have any other questions, shall I close and lock the post for you?
Feel free to close it :)
