Is it possible to verify that all the MIBS present in the tar are processed properly.ericssonvietnam wrote:Got the message apr_sockaddr_info_get() failed for nagiosxi which i do not usually get after restarting httpd service can you suggest.lmiltchev wrote:Try doubling the value:then restart apache:Code: Select all
upload_max_filesize = 4MLet us know if this helped.Code: Select all
service httpd restart
[root@nagiosxi NEWMIBS]# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: httpd: apr_sockaddr_info_get() failed for nagiosxi
httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
[ OK ]
But still status is running for httpd
I which configuration file should i check for the processed mibs.
I have the below configuration in the ini file /etc/snmp/snmptt.ini
[TrapFiles]
# A list of snmptt.conf files (this is NOT the snmptrapd.conf file). The COMPLETE path
# and filename. Ex: '/etc/snmp/snmptt.conf'
snmptt_conf_files = <<END
/etc/snmp/VNM_snmptt.conf
END
Do i require to restart the snmptt service
ISSUE WHILE UPLOADING MIBS
ericssonvietnam
Re: ISSUE WHILE UPLOADING MIBS
- Former Nagios Staff
First step, are they showing up at http://YOURSERVER/nagiosxi/admin/mibs.php ?
The quickest thing to do, assuming you have a test device and test server, is just to test it and see if it works as anticipated. Please note that each XI install allows for both a test and a backup instance, so there's no reason why you shouldn't be able to test on the XI side.
ericssonvietnam
I am still getting the below errordwhitfield wrote:First step, are they showing up at http://YOURSERVER/nagiosxi/admin/mibs.php ?
Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs/DISMAN-SCHEDULE-MIB)
Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs/DISMAN-EVENT-MIB)
Unknown object identifier: DISMAN-EVENT-MIB::The
Unknown object identifier: SNMPv2-SMI::
Unknown object identifier: NOTIFICATION-LOG-MIB::The
I have the following in the file below
[root@nagiosxi ietf]# grep zeroDotZero ../../../mibs/SNMPv2-SMI.txt
zeroDotZero OBJECT-IDENTITY
addmib /usr/share/snmp/mibs/mibfilename
do I need to install any module for this???
Kindly suggest i have more mobs which i have to process.
It looks like the SNMPv2-SMI mib file is corrupted as the 'zeroDotZero' option is defined in that file.
Can you run the following as root and post the output so we can see the files in that folder are correct?
ls -l /usr/share/snmp/mibsBe sure to check out our Knowledgebase for helpful articles and solutions!
ericssonvietnam
Attached is the output of ls -l commandtgriep wrote:It looks like the SNMPv2-SMI mib file is corrupted as the 'zeroDotZero' option is defined in that file.
Can you run the following as root and post the output so we can see the files in that folder are correct?Code: Select all
I have large number of file.Can you suggest the way ahead on the issue.
It also give be below message while service restart as well.
[root@nagiosxi ietf]# service snmptt restart
Stopping snmptt: [ OK ]
Starting snmptt: Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs//DISMAN-EVENT-MIB)
Did not find 'zeroDotZero' in module SNMPv2-SMI (/usr/share/snmp/mibs//DISMAN-SCHEDULE-MIB)
PID file: /var/run/snmptt.pid
[ OK ]
There are a lot of files that have been uploaded to the server and I am guessing that some of them do not have the required SNMP definitions and that is causing the errors.
When you need to upload a MIB file, for the most part, you do not want to upload over an existing file or a file with a similar name but with different contents as that will generate the errors you are having.
In that folder, are many copies of this file (slightly different name) and the settings in one of them are bad causing the error.
To fix this, delete all of the above files except this one
There are also a lot of .cfg files in the folder, you should look at them to see if they are valid and it not, remove them as well.
-rw-rw-r-- 1 root nagios 8932 Jun 30 01:09 SNMPv2-SMI
-rw-rw-r-- 1 root nagios 744 Jun 13 2016 snmpv2-smi.cfg
-rw-rw-r-- 1 root nagios 1398 May 15 21:17 SNMPv2-SMI.mib
-rw-rw-r-- 1 root nagios 8924 Jan 20 2016 SNMPv2-SMI.txt
-rw-rw-r-- 1 root nagios 666 Jun 13 2016 SNMPv2-SMI-v1.cfg
-rw-rw-r-- 1 root nagios 1414 May 15 21:17 SNMPv2-SMI-v1.mibCode: Select all
-rw-rw-r-- 1 root nagios 8924 Jan 20 2016 SNMPv2-SMI.txtBe sure to check out our Knowledgebase for helpful articles and solutions!
ericssonvietnam
Now i am not getting any error while service restart and processed most of the mibstgriep wrote:There are a lot of files that have been uploaded to the server and I am guessing that some of them do not have the required SNMP definitions and that is causing the errors.
To fix this, delete all of the above files except this oneCode: Select all
-rw-rw-r-- 1 root nagios 8932 Jun 30 01:09 SNMPv2-SMI -rw-rw-r-- 1 root nagios 744 Jun 13 2016 snmpv2-smi.cfg -rw-rw-r-- 1 root nagios 1398 May 15 21:17 SNMPv2-SMI.mib -rw-rw-r-- 1 root nagios 8924 Jan 20 2016 SNMPv2-SMI.txt -rw-rw-r-- 1 root nagios 666 Jun 13 2016 SNMPv2-SMI-v1.cfg -rw-rw-r-- 1 root nagios 1414 May 15 21:17 SNMPv2-SMI-v1.mibThere are also a lot of .cfg files in the folder, you should look at them to see if they are valid and it not, remove them as well.Code: Select all
1.Is there any way to get the mibs directly added in my custom file /etc/snmp/VNM_snmptt.conf instead of /etc/snmp/snmptt.conf
2. I have processed most of the mibs but would like to share the output for Ericsson mibs for which i do not see any EVENT and EXEC statement attached is the output of processed Ericsson MIBScan you check and suggest.
3. I observed 2 errors as well
Usage: /usr/local/bin/addmib <mibfile>
Configure snmptt.conf for a given MIB file
1. There are a couple of ways you can create your custom files, run the addmib command which will add them to the default file and then you can rename it.
Or you can edit the /usr/local/bin/addmib script and change the name of the output file.
You will have to edit the /etc/snmp/snmptt.ini file and add the custom file to the list at the bottom so the snmptt daemon will load it.
2. Not all MIB files contain TRAP entries so if the files you added did not have any, then there is nothing to import.
3. The DISMAN-EVENT-MIB and the NOTIFICATION-LOG-MIB MIB files look like they were replaced on the system.
Delete this copy of the NOTIFICATION-LOG-MIB file. The without the .txt extension
Then delete the DISMAN-EVENT-MIB file and replace it with the one that is attached to the post.
cmd='/usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*"'
snmpttconvertmib --in="$1" --out=/etc/snmp/VNM_snmptt.conf \
--exec "$cmd" >> /tmp/snmpttconvertmib.log2. Not all MIB files contain TRAP entries so if the files you added did not have any, then there is nothing to import.
ericssonvietnam
I have uploaded all my MIB file and everything is fine now but when i restart the service i get failed but when i checked it my service was already running still i have failure.tgriep wrote:1. There are a couple of ways you can create your custom files, run the addmib command which will add them to the default file and then you can rename it.
You will have to edit the /etc/snmp/snmptt.ini file and add the custom file to the list at the bottom so the snmptt daemon will load it.Code: Select all
cmd='/usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*"' snmpttconvertmib --in="$1" --out=/etc/snmp/VNM_snmptt.conf \ --exec "$cmd" >> /tmp/snmpttconvertmib.log
[root@nagiosxi ~]# service snmptt restart
Stopping snmptt: [FAILED]
Starting snmptt: PID file: /var/run/snmptt.pid
[ OK ]
Can you suggest what should i do to fix this.
Post all of the files from the /etc/snmp folder so I can view the settings.
Take a look in the /var/log/messages file to see if you can find the error on why the snmptt daemon will not start.
