Logstash Daemon dead but pid file exists
Re: Logstash Daemon dead but pid file exists
Can you run the following command and post the output so we can see the logstash errors?
tail -100 /var/log/logstash/logstash.log
Nags007
Post by Nags007 »
[root@NagiosLogserver ]# cd /var/log/logstash
[root@NagiosLogserver logstash]# ll
total 0
[root@NagiosLogserver logstash]# pwd
/var/log/logstash
total 0
[root@NagiosLogserver logstash]# ls -ltr
total 0
As informed earlier, this log file is not getting generated. there is no LOG file in the /var/log/logstash directory.
Thank you,
nagesh
Lets run the logstash command manually and see if the error is displayed in the console.
Login to the logserver as root, run the following command and post the output.
nice -n 19 runuser -s /bin/sh -c "exec /usr/local/nagioslogserver/logstash/bin/logstash agent -f /usr/local/nagioslogserver/logstash/etc/conf.d --verbose" nagios
Then, run the following commands as root and post the /tmp/ls.txt file.
ls -lR /usr/local/nagioslogserver >/tmp/ls.txt
ls -l /var/log/ >>/tmp/ls.txt
ls -l /var/run/ >>/tmp/ls.txt
