Check number of files on a directory
cocoyanouck
Re: Check number of files on a directory
Post by cocoyanouck »
Arf ... :cry:
root@nagios-debian:/home/nagios# /usr/local/nagios/libexec/check_nrpe -H 10.20.2.12 -c check_files -a path='C:\\Windows'
CHECK_NRPE STATE CRITICAL: Socket timeout after 10 seconds.
Erreur de segmentation
nsclient.log
(25.14 KiB) Downloaded 355 times
Edit the nsclient.ini file and remove all of nagios-debian entries,
Find this entry and change it from
allow nasty characters = 1
to
allow nasty characters = true
level = info
to
level = debug
save the file and restart the NSClient++ service.
Then run the check_nrpe command with the log file enabled to see if it captures any errors.
/usr/local/nagios/libexec/check_nrpe -H 10.20.2.12 -g /tmp/nrpe.log
If it fails, post the /tmp/nrpe.log file from the Nagios server and the nsclient.log file and the updated nsclient.ini file from the Windows Host.
One question, do you have the check_nrpe command working with other Windows servers?
cocoyanouck
I have made all the modification, then :
root@nagios-debian:/home/nagios# /usr/local/nagios/libexec/check_nrpe -H 10.20.2.12 -g /tmp/nrpe.log
I (0.5.0.62 2016-09-14) seem to be doing fine...
And the nsclient.log :
2017-05-22 18:03:19: debug:c:\source\master\include\nrpe/server/protocol.hpp:72: Accepting connection from: 10.20.2.33, count=1
2017-05-22 18:04:36: debug:c:\source\master\include\nrpe/server/protocol.hpp:72: Accepting connection from: 10.20.2.33, count=1
I already use this file "nsclient.ini" and the command check_nrpe in order to check how many files there are in specifics folders. But not on this nagios-srv (which is located in a different country).
What do you mean by " But not on this nagios-srv (which is located in a different country)."
It looks like the check_nrpe test is working now without generating the Segmentation Error, and the nsclient.log file is not showing any errors.
Is the check_nrpe command that is checking the files in the D:\import\faxin folder functioning for you now?
cocoyanouck
I want to tell you that the command check_nrpe with the check_files was working on my another nagios server but not on this one.
root@nagios-debian:/home/nagios# /usr/local/nagios/libexec/check_nrpe -H 10.20.2.12 -c check_files -a path='D:\\import\\faxin' pattern=*.* 'warning=count>100' 'critical=count>150'
And on the nsclient.log :
root@nagios-debian:/home/nagios# /usr/local/nagios/libexec/check_nrpe -H 10.20.2.12 -c check_files -a path='C:\\Windows'^C
So strange :/
Ok, I understand now.
Lets replace the check_nrpe plugin on the Nagios server and see if that fixes the issue.
Look at this link
https://support.nagios.com/kb/article/n ... ource.html
search for this section in the link for the instructions on installing the check_nrpe plugin.
Install check_nrpe Plugin Only
cocoyanouck
So, the installation of nrpe 3.1.0 is OK.
Launched these commands :
Results :
2017-05-24 17:29:29: debug:c:\source\master\include\nrpe/server/protocol.hpp:72: Accepting connection from: 10.20.2.33, count=1
2017-05-24 17:29:29: debug:c:\source\master\include\check_nt/server/protocol.hpp:58: Accepting connection from: 10.20.2.33
2017-05-24 17:29:29: debug:c:\source\master\modules\NSClientServer\NSClientServer.cpp:302: Real command: check_drivesize drive=c warn=free<0 crit=free<0 filter=type='fixed' and mounted = 1 perf-config=used(unit:B)free(unit:B)
2017-05-24 17:29:31: debug:c:\source\master\include\nrpe/server/protocol.hpp:72: Accepting connection from: 10.20.2.33, count=1
2017-05-24 17:29:31: debug:c:\source\master\include\check_nt/server/protocol.hpp:58: Accepting connection from: 10.20.2.33
2017-05-24 17:29:36: debug:c:\source\master\include\check_nt/server/protocol.hpp:58: Accepting connection from: 10.20.2.33
2017-05-24 17:29:36: debug:c:\source\master\modules\NSClientServer\NSClientServer.cpp:302: Real command: check_uptime warn=uptime<0
In the folder that you recompiled the check_nrpe command is a log file called config.log, can you post that file?
Can you run the following commands as root and post the output?
uname -a
cat /etc/*release*
Can you run the check_nrpe command to another remote host without it crashing?
cocoyanouck
Config.log :
root@nagios-debian:/home/nagios/nrpe-nrpe-3.1.0# ls -l
total 532
-rwxrwxr-x 1 root root    283 avril 17 16:21 aclocal.m4
drwxrwxr-x 2 root root   4096 avril 17 16:21 build-aux
-rw-rw-r-- 1 root root  16286 avril 17 16:21 Changelog
-rw-r--r-- 1 root root  64616 mai   24 11:19 config.log
-rwxr-xr-x 1 root root  33002 mai   24 11:19 config.status
-rwxrwxr-x 1 root root 248809 avril 17 16:21 configure
-rw-rw-r-- 1 root root  11228 avril 17 16:21 configure.ac
drwxrwxr-x 2 root root   4096 avril 17 16:21 contrib
drwxrwxr-x 2 root root   4096 avril 17 16:21 docs
drwxrwxr-x 2 root root   4096 mai   24 11:19 include
-rw-rw-r-- 1 root root    441 avril 17 16:21 LEGAL
-rw-rw-r-- 1 root root  18092 avril 17 16:21 LICENSE
drwxrwxr-x 2 root root   4096 avril 17 16:21 macros
-rw-r--r-- 1 root root   6787 mai   24 11:19 Makefile
-rw-rw-r-- 1 root root   6768 avril 17 16:21 Makefile.in
-rw-r--r-- 1 root root   5871 mai   24 11:19 nrpe.spec
-rw-rw-r-- 1 root root   5884 avril 17 16:21 nrpe.spec.in
-rwxrwxr-x 1 root root   3248 avril 17 16:21 paths.in
-rw-rw-r-- 1 root root   7011 avril 17 16:21 README.md
-rw-rw-r-- 1 root root  11738 avril 17 16:21 README.SSL.md
drwxrwxr-x 2 root root   4096 mai   24 11:19 sample-config
-rw-rw-r-- 1 root root   3335 avril 17 16:21 SECURITY.md
drwxrwxr-x 2 root root   4096 mai   24 11:20 src
drwxrwxr-x 2 root root   4096 mai   24 11:19 startup
-rw-rw-r-- 1 root root    757 avril 17 16:21 THANKS
-rw-r--r-- 1 root root  10675 mai   24 11:19 uninstall
-rwxrwxr-x 1 root root  10637 avril 17 16:21 uninstall.in
-rwxrwxr-x 1 root root   4326 avril 17 16:21 update-cfg.pl
-rwxrwxr-x 1 root root   3071 avril 17 16:21 update-version
root@nagios-debian:/home/nagios/nrpe-nrpe-3.1.0# vi config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by nrpe configure 3.1.0-rc1, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = nagios-debian
uname -m = i686
uname -r = 3.16.0-4-686-pae
uname -s = Linux
uname -v = #1 SMP Debian 3.16.43-2 (2017-04-30)
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
## Core tests. ##
configure:2540: checking for a BSD-compatible install
configure:2608: result: /usr/bin/install -c
configure:2628: checking what the operating system is
configure:2695: result: linux
configure:2706: checking what the distribution type is
configure:2818: result: debian
configure:2828: checking what init system is being used
configure:2971: result: systemd
configure:2981: checking what inetd is being used
configure:3070: result: systemd
configure:3114: checking for which paths to use
configure:3796: result: default
configure:3810: checking for which init file to use
configure:3853: result: default-service
configure:3856: checking for which inetd files to use
configure:3878: result: default-socket
configure:5027: checking for gcc
configure:5043: found /usr/bin/gcc
configure:5054: result: gcc
configure:5283: checking for C compiler version
configure:5292: gcc --version >&5
gcc (Debian 4.9.2-10) 4.9.2
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
"config.log" 2196 lines, 64616 characters
Output :
root@nagios-debian:~# uname -a
Linux nagios-debian 3.16.0-4-686-pae #1 SMP Debian 3.16.43-2 (2017-04-30) i686 GNU/Linux
root@nagios-debian:~# cat /etc/*release*
PRETTY_NAME="Debian GNU/Linux 8 (jessie)"
NAME="Debian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=debian
HOME_URL="http://www.debian.org/"
SUPPORT_URL="http://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
I have installed the latest version of nsclient++ and copy the nsclient.ini which i already use on the other servers => same issue.
root@nagios-debian:~# /usr/local/nagios/libexec/check_nrpe -H 10.20.2.34 -c check_files -a path='D:\\WSUS'
I wonder if this is not my nsclient.ini which is the cause of the problem.
It seems that when the command option or an argument is specified for the check_nrpe command, that is when it fails so let's recompile the check_nrpe plugin by following this procedure.
cd /home/nagios/nrpe-nrpe-3.1.0
./configure --enable-command-args
make check_nrpe
make install-plugin
Try that and see if it fixes the issue.
