The check timeout being 180 seconds is from attempts to monitor windows servers via WMI. We found a number of servers took over 2 mins to respond back with the results. So the timeout got set to 180, since we shifted out focus to using SNMP. I can look at drawing that back to something reasonable. I doubt it is something that would help this problem.
I will look into setting up a Ramdisk for the perfdata.
The security team adjusted the logging to force everything to go into /var/log/messages, which they export to a log server. The amount in information is very little in the nagios.log. If you need it, I can get it for you.
mod_gearman server runs on the same server as the Nagios server.
ndo2db
- Former Nagios Staff
Re: ndo2db
I suppose I should clarify. Are the workers also on the same server? If so, that is definitely going to be a problem with that many checks.chicjo01 wrote: mod_gearman server runs on the same server as the Nagios server.
If WMI checks take two minutes, I would try 130 for the timeout. The longer checks run, the more resources you are using on the system.
Re: ndo2db
The mod gearman workers do run out of the same Nagios server currently. I have not had enough time to get the remote worker server cleared of firewalls and permissions to perform all the checks we need. For the mod gearman workers, I have 300 workers setup to run, so when a large number of monitors are being checked, it performs the task without using up tons of resources.
Re: ndo2db
The checks are still occurring on the Nagios server itself and taking resources so following Doug's recommendation of moving the workers to a separate server should be something to work towards. I would also strongly push to install the ramdisk. It's simple to setup and can improve things pretty drastically in most cases.
Re: ndo2db
I am working on getting the ramdisk setup and tested on one of the Nagios servers. It is a slow process, since I need to go through change control. I will provide updates when I get more information. Thank you for the information, I have two things to work towards.
Re: ndo2db
We totally understand. We'll be here!chicjo01 wrote:It is a slow process, since I need to go through change control.
